Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-27-2009   #1 (permalink)
brokedown711
New Member
brokedown711 is an unknown quantity at this point
add-a-circuit vs. ? gps/laser jammer/rd install
Just getting things planned out in my head for the upcoming electronics install I'll be doing.
2003 civic lx sedan: beltronics RD above rearview, possible tomtom gps hardwire, blinder laser jammer in the near future, viper alarm since I can't find anyone with an OEM keyless for sale (I HATE cutting factory wires)
For the RD, I have to run a wire across the headliner, down the A-pillar and to the fuse box right? there's no ign. switched 12v in the rearview access panel of the dome light? What circuit should I use? One of those "add-a-circuits" that plugs into a fuse spot and has space for two fuses (one for the original fuse and one for the new circuit)
For the tomtom and laser jammer, would the cig. plug be fine? or just tap into the "add-a-circuit" line?
Also, for the alarm that male spade connector on the fuse box is a constant 12v?
brokedown711 is offline   Reply With Quote
Sponsored Links
Old 06-27-2009   #2 (permalink)
lowlife9
Super Member
lowlife9's Avatar
lowlife9 will become famous soon enough
Re: add-a-circuit vs. ? gps/laser jammer/rd install
how about not speeding your car around then you won't need all that and the roads will be a littel safer .
__________________
lowlife9 is online now   Reply With Quote
Old 06-27-2009   #3 (permalink)
brokedown711
New Member
thanks for your opinion, didn't really ask for it though. that still doesn't cover the gps or alarm.
and im not speeding around residential neighborhoods, actually quite the opposite. as for the highway, your gonna tell me you stick to the posted speed limit? at all times?!
there's been plenty of times that i've been alerted with the RD, i was probably speeding by 5-10mph but having a modified + relatively loud car i'd rather not give any officers a reason to pull me over and hassle me.
besides, your assumptions about my intent are grossly inaccurate. having a RD or laser jammer doesn't give you the license or ability to drive around with excessive speed. At most it gives you time to slow down from a reasonable speed to the posted limit.
Consider these facts: officer hits you with laser @ 1000ft, many jammers are defeated and allow "punch through" (or a speed reading) at a distance <= 500ft, the better systems obviously give you more time to slow down (by either overpowering the gun completely, or not being punched through until 100ft or less)
Either way, you need to be relatively close to the posted limit so you can slow down to that speed limit, then turn off the jammer as not to alert the officer you jammed his gun.
.... "the more you know"
Old 06-27-2009   #4 (permalink)
lowlife9
Super Member
lowlife9's Avatar
just how fast do you plan on going ???
__________________
Old 06-27-2009   #5 (permalink)
brokedown711
New Member
i'll give you the answer you want. 10000 mph. good thing my giant rear spoiler keeps me from flying away.
Old 06-28-2009   #6 (permalink)
electric130
I.C.E. Mod
electric130's Avatar
electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned
the problem with the add a fuse is that the wires behind the original fuse are still only sized for the original fuse. by adding another, you could exceed the capacity of the wire and cause a fire.
electric130 is offline   Reply With Quote
Old 06-28-2009   #7 (permalink)
brokedown711
New Member
that was my concern exactly. so what's the best plan of action here? tapping the ignition wire at the ignition harness (this goes to the ignition cylinder at the steering while right?) and running that to a fused distribution block?
I ran my RD off of very small wiring to the dome light in my last car, I had a fuse right at the tap and never had an issue.. but since I have to run he wire all the way down the pillar and to the dash for this car....
Old 06-28-2009   #8 (permalink)
DieMaster
Senior Member
DieMaster's Avatar
DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light
Jammers are illiegal to own and operate. a Detector isint.
i got mine and a few other audio things off the cigeret lighter. i wired them behind it so i still have the plug w/o ugly wires hang allover the place.
also i HATE cuting factory wires too. when posible i use pigyback harness. i've made my own for the ECU, and both kinds of clusters i have (hybrid and LED) so i can plug any cluster in my car now and go back to stock anytime. (after updating the milage of course )
DieMaster is offline   Reply With Quote
Old 06-28-2009   #9 (permalink)
electric130
I.C.E. Mod
best solution would be to run a new fused wire from the battery to a relay. use an ignition wire to turn the relay on. then put in-line fuses off the relay as needed. most cheap automotive relays are good for 30A. so you could power all the devices off that. the alarm would need constant power, so you could run that off the battery side.
Old 06-28-2009   #10 (permalink)
brokedown711
New Member
No issues with multiple devices on the cig. lighter circuit? what exactly do you have run off that?
RADAR JAMMERS are illegal to own and operate, without the proper FCC licensing I presume. LASER JAMMERS are not regulated by the FCC, but by the FDA (believe it or not).. Only illegal to operate in a state that specifically outlaws them. If you wanna learn more about the stuff check out radardetector.net
I would be very interested in seeing your "piggyback" harnesses for the cluster and ecu.. curious to see how you accomplished this?!!!
Quote:
Just run multiple wires off the correct relay terminal? I've always considered this but never had enough "gadgets" to require doing so. If I run a power wire for an amp, is it wise to tap that for the relay? or just run two lines?
Old 06-28-2009   #11 (permalink)
electric130
I.C.E. Mod
Quote:
yeah. a typical relay will have the coil on 85 and 86. that would be the ignition and a ground. 87 and 30 will be the contacts. put an in-line fuse off the battery (like an amp would have, they're cheap from autozone) and run it to terminal 30. you can power your alarm from 30 as you want it constant power. 87 is the switched side of the relay. this will power whatever else you want when the key is turned on. cheap relays and bases:
http://www.parts-express.com/pe/show...number=330-073
you want this base with the "kick back" diode. when relays de-energize, they have a lot of energy that can damage components. the diode allows this to dissipate safely:
http://www.parts-express.com/pe/show...number=330-076
shipping will likely cost more than the parts!
Old 06-28-2009   #12 (permalink)
DieMaster
Senior Member
DieMaster's Avatar
the harnest thing is finding the plugs. i had to sacrafice a cluster and a ecu to get the maiting plugs. also i'm a OEM nut! so much so that when i make them all the wires must be the right collor.
the hbrid harness has about 15 wires that arnt used and some of them are hooked up to **censored** and **censored** for a project i'm doing. with summer coming up and because **censored** dosent work yet i swaped back my LED cluster so i have engine temp back.
but yea the hardest part is finding plugs and then repining them w/ the right colors.
Old 07-14-2009   #13 (permalink)
badhabits
Member
badhabits's Avatar
badhabits is an unknown quantity at this point
Send a message via AIM to badhabits Send a message via MSN to badhabits
Late post..
When I set up my amps, I put a distribution block on the inside of the bottom dash panel (under the steering wheel). Then ran from the DB to the trunk for my amps. This way I could hardwire directly into that distribution block. I used 0G from the battery to the DB, and 2x 4G wires from the DB to my 2 amps.
Now I have easy access to a 12v line when I need it.
badhabits is offline   Reply With Quote
Tags
98 , add , addatap , ato , circuit , civic , detector , fuse , fusebox , gps , honda , installation , jammer , laser , time
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
