Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-22-2009   #1 (permalink)
Byrd
New Member
Byrd is an unknown quantity at this point
Weird electrical issue
I installed infinity components about 2 months ago and for the last couple of weeks they have been cutting out every now and then. Its the weirdest thing because the highs and mids only cut out when im taking a hard left turn or braking hard. before i open my door panels i thought i would throw it out there to see if you all could shed some light on the weird behavior. i have the crossover mounted in my door right next to the handle but i think its odd that they cut out only on left turns(not right) and hard braking. thanks for the help everyone. To remove this ad, register today for free or log in if already registered!
Byrd is offline   Reply With Quote
Sponsored Links
Old 06-22-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Weird electrical issue
yeah its a common problem caused by the connectors jiggling or getting corroded. just wrap the speaker wire directly to the speaker terminals.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 06-22-2009   #3 (permalink)
wallydude03
Senior Member
wallydude03's Avatar
wallydude03 will become famous soon enough
Send a message via AIM to wallydude03
its loose wiring
wallydude03 is offline   Reply With Quote
Old 06-22-2009   #4 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
Also check to see if the speaker terminals for the lower door mounted speakers are shorting against the metal of the door, If they are twisted when mounted they can short to ground easily.
It will kick in the protection circuit to prevent damage to amplifier circuit.
CraigW is offline   Reply With Quote
Old 06-28-2009   #5 (permalink)
Byrd
New Member
Thanks for the help. If the door speakers are grounding would that cause all of the speakers to completely cut out? (even the rears) If this is the root of the problem what can i do to fix it? thanks alot everyone
Old 06-29-2009   #6 (permalink)
CraigW
Platinum Member
CraigW's Avatar
Yes, It can cause all 4 to stop (most likely the same output chip drives all 4 speakers)
You just need to take a look and see which on has the terminals close to metal. Very tight area to start.
You can take the speaker loose and try to twist it back away from the metal or you could insulate the exposed metal or the speaker terminals with electrical tape.
Old 07-12-2009   #7 (permalink)
Byrd
New Member
Yep it was shorting out on the left side of the door, I figure thats why it was only cutting out on hard left turns and bumps. Thanks for the help guys.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
