Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-18-2009   #1 (permalink)
hondaguy2582
Member
hondaguy2582's Avatar
hondaguy2582 is an unknown quantity at this point
Max depth of front speakers?
Looking to install either some image dynamics ctx65cs components, or possibly the polk momos. Problem is, they are 2.75-3" for the depth of the speaker. I know I will need a spacer(assuming .75 mdf ring), but will that be enough to fit the speaker itself? To remove this ad, register today for free or log in if already registered!
hondaguy2582 is offline   Reply With Quote
Sponsored Links
Old 06-18-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Max depth of front speakers?
you can use up to a 1 inch spacer (use plastic, mdf is wood and will rot from water over time) AND shave the plastic off the back of the door panel. theres a stupid plastic lip around the speaker grill that serves no purpose. that will give you some more room so the panel goes back on properly.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 06-19-2009   #3 (permalink)
electric130
I.C.E. Mod
electric130's Avatar
electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned
if you look at my DIY, you'll see some measurements. it's in my sig. i used 3/4" MDF, but gear is right, 1" will fit most likely. you need to look at the top mount height also to see how much it will stick out past the spacer.
electric130 is offline   Reply With Quote
Old 06-19-2009   #4 (permalink)
gearbox
Super Moderator
if you go with 1 inch, you must trim the back of the door panel otherwise it wont completely snap back together.
__________________
www.lubecontrol.com
Member 1025782
Old 06-23-2009   #5 (permalink)
hondaguy2582
Member
Ok thanks guys. I was just wondering how big of a spacer you can put in these civics. Looking at Morel, Hertz, and the higher end Polk speakers, the magnets are at least 2.5 inches. Guess I will have to use a 1" spacer.
Old 06-23-2009   #6 (permalink)
electric130
I.C.E. Mod
the clearance without a spacer is 1.875" between the door panel and the window when rolled down.
Old 06-29-2009   #7 (permalink)
hondaguy2582
Member
I noticed the speaker I want to purchase is an oversized 6.5(6 3/4). Any of you fit similar components in the door of this size?
Here is the specs of the Polk mm6501s:
http://www.crutchfield.com/p_107MM65...01.html?tp=106
Old 06-30-2009   #8 (permalink)
electric130
I.C.E. Mod
i've got Infinity Reference CS6010's and was able to get them in with a 3/4" MDF spacer and no modifications. looking at the pics of what you linked, i think depth wise, it will fit with a 3/4" spacer (very tight), but a 1" would give more room. either way, based on the pic and how the back of the basket comes straight down, and then tapers flat, i think you're going to have to cut the opening of the metal in the door to make it work. see how the back of this Rockford Fosgate is more tapered? so by the time the magnet penetrates the door opening, the diameter is much smaller than the whole speaker. i think you'll have the opposite. if you're prepared for that, then cool. go for it. can't go wrong with Polk's or Infinity's IMO.
Old 07-08-2009   #9 (permalink)
hondaguy2582
Member
Purchased these from Sonic Electronix(free shipping ): http://www.sonicelectronix.com/item_...PPI+356CS.html
Looks like I will be fine with a 3/4" mdf spacer!!! Can't wait to run these puppies!!!
Tags
2001 , 2002 , 2006 , 2007 , civic , depth , door , front , gen , honda , mounting , si , spaeker , speaker , speakers
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
