Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-14-2009   #1 (permalink)
Zigroyd
New Member
Zigroyd is an unknown quantity at this point
OEM Fog Switch Question
This is an OEM switch for an 02 civic. Anyone know what each of the 5 pins are for? I'm assuming there is a power in, power out to relay, ground, and two for the two different switch illuminations, one for the green on light and one for the white lighting when the dash lights are on. I don't know which is which and thought someone here might have a diagram or might previously have figured this out. Any help would be appreciated as I don't want to blow the switch putting the power onto the wrong pin. Thanks! To remove this ad, register today for free or log in if already registered!
ID:	76702   Click image for larger version
Zigroyd is offline   Reply With Quote
Sponsored Links
Old 06-14-2009   #2 (permalink)
DDragon7
Ultimate Member
DDragon7's Avatar
DDragon7 is a glorious beacon of light DDragon7 is a glorious beacon of light DDragon7 is a glorious beacon of light DDragon7 is a glorious beacon of light DDragon7 is a glorious beacon of light
Re: OEM Fog Switch Question
Here you go, http://www.7thgenhonda.com/forum/showthread.php?t=6813
__________________
I <3 My Honda
(Rep Me and I Rep Back)
2001 Civic SiG, 5spd, Eternal Blue, 126k km
www.ottawahondaclub.com - Admin
DDragon7 is offline   Reply With Quote
Old 06-14-2009   #3 (permalink)
Zigroyd
New Member
Awesome! Thanks so much, can't believe I couldn't find this myself. I'll be hooking everything up tonight so I'll let you know how it works out.
Old 06-15-2009   #4 (permalink)
DDragon7
Ultimate Member
DDragon7's Avatar
I've done this and the only thing I dont like is that the switch is recessed into the switch hole in the console and I had to trim a bit of the console to get it to fit.
__________________
I <3 My Honda
Old 06-16-2009   #5 (permalink)
Zigroyd
New Member
I finally got everything hooked up and working. I actually have five different wires running into the switch to get everything working properly, which is a little different then what the other guy did. In order for me to get the white light on the switch to light up, I had to tap into the dash light illumination on the cruise control switch, this way the switch lights up white like all the other lights in the car. It took me some time to figure everything out, even with the other post you linked, but here are the conclusions I came to. Some of the stuff the other guy figured out in that other forum was right, but I figured some other things out as well.
Going along with the same number scheme he used,
1 is Ground
2 is White light 12v in (source supplied when head/parking lights on)
3 is 12v out (to relay)
4 is White light ground
5 is 12v in
At first everything was working but the white light and I couldn't figure it out for the life of me. I realized by accident with a test light that there was actually a ground needed for the white light. I thought the bulb might have been bad or there was a shitty connection in the switch, but once I realized there actually has to be two grounds going into the switch everything worked fine. Now, everything is working as an OEM switch should. Maybe someone else could make these findings useful. Thanks again!
Old 06-17-2009   #6 (permalink)
DDragon7
Ultimate Member
DDragon7's Avatar
That's pretty much what was listed and I wired up the illumination pin to my radio.
__________________
I <3 My Honda
Tags
06 , 12v , 98 , 99 , civic , diagram , difference , ek , fog , install , light , oem , parking , sedan , source , switch , switched
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
