Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-04-2009   #1 (permalink)
motherfnmike
New Member
motherfnmike will become famous soon enough
Trunk Light and Wiring
So I have a 2001 Civic LX that I've finally found time to work on. Cleaning it up as best I can, still have to clean up the engine bay, touch up some of the scratches and most importantly, take out and fix my almost-completely-off headliner which I could most definitely use some info on if anyone has any.
Anyhow, the problem at hand is the trunk light. I thought the light itself was out so I replaced it with a brand new LED and it still didn't turn on. After pushing the wires into the clip, not the clip into the light itself, it lights but only after applying pressure. I'm assuming the wiring is loose but I'm not so sure how to go about opening this clip so that I can strip some more wire and make sure it's a solid connection.
I haven't been able to find my camera so I've provided the only pic I've found.
motherfnmike is offline   Reply With Quote
Sponsored Links
Old 06-04-2009   #2 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
Re: Trunk Light and Wiring
Bad pic... better one?
TRIZ is offline   Reply With Quote
Old 06-04-2009   #3 (permalink)
motherfnmike
New Member
I'll try and get better pictures in the morning.
Old 06-04-2009   #4 (permalink)
motherfnmike
New Member
Here we go. The 2nd to last is without any pressure and the last is how I have to squeeze it in before it'll light.
ID:	76628   Click image for larger version
ID:	76629   Click image for larger version
ID:	76630   Click image for larger version
ID:	76631   Click image for larger version
Old 06-05-2009   #5 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
i think you might just need a new blue connector. maybe your terminals are corroded. it should light up the bulb when the blue connector is only 1/2 way pushed in the housing.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 06-05-2009   #6 (permalink)
motherfnmike
New Member
It's not the blue connector piece that I'm pushing in. Rather, it's the wires that I have to push in for it to light. I'm just not sure how to open the piece up so that I can reseat the wires in the connector piece. I don't even know what it's called so I can google it. Tried searching a buncha different terms but no luck.
Old 06-05-2009   #7 (permalink)
gearbox
Super Moderator
oh okay the wires are loose. im not sure but i dont think it opens up. usually with a small screwdriver you can push down the tab from the front and pull the wire out. you may need to bend that tab out more so that next time you push it in it will stay in the right spot. i have a similar connector to that one except its grey (from a jdm sidemarker) that im not using. if you want i can try to find it and post pics. it might work and the wires are nice and tight. its brand new plug never been used. actually the connector i have is the same one as the license plate light one. so try that on your trunk light and if it fits, the one i have will work.
__________________
www.lubecontrol.com
Member 1025782
Old 06-05-2009   #8 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
The connectors pins have little release tabs, you may be able to get them out with a paper clip or dental pick. Not real easy in most cases.
Make sure when you push the connector in that the 2 brass tabs for the light are going into the pins and not above or below them. See if the connectors look bent or out of place.
I used one of those assemblies in the back of my console near the floor for rear illumination. I just soldered wires to the brass tabs and added an inline 2 pin connector.
CraigW is offline   Reply With Quote
Old 06-05-2009   #9 (permalink)
motherfnmike
New Member
So I tried plugging it into the license plate lights and it's the same problem so I guess I was wrong with the wire's being bad.
I checked the the 2 brass tabs and they were very slightly bent. I tried to straighten them out so they go right into the pins and it did light up but once I started to put the trunk light back in, it would turn off as if it's still not making contact. The next 20 minutes of tinkering it would light and then go out. It's raining pretty heavy out right now so I'll have to wait to try it some more.
Old 06-05-2009   #10 (permalink)
gearbox
Super Moderator
yeah sounds like a connection problem with the housing. try putting some dielectric grease in the plug and then push it on. the grease will kinda clean up any corrosion and lock out moisture.
__________________
www.lubecontrol.com
Member 1025782
Old 06-09-2009   #11 (permalink)
motherfnmike
New Member
A friend of mine ended up soldering a bit more to the brass tabs so it could make a connection easier in addition to soldering all the points on the lens that he thought were loose and viola, I have trunk light! Thanks for the help guys.
Tags
07 , 1995 , civic , clip , find , honda , light , lights , liscense , open , plate , problem , screwdriver , si , trunk , wire , wiring , working
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
