Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-24-2009   #1 (permalink)
chuan
New Member
chuan is an unknown quantity at this point
Where is the parking signal control for DVD unit?
Hello guys!
I've just fitted a Kenwood DNX5220 in my 7th gen Civic. At the moment, it does not allow me to watch DVD cos the parking terminal has not been properly wired. Where could I find the parking signal control in my Civic? In addition, I am also planning to install a reverse camera. Hence, I will also need to find the reverse gear control? Any ideas?
I am a newby in this and I would appreciate any advice. Many thanks!
chuan is offline   Reply With Quote
Sponsored Links
Old 04-24-2009   #2 (permalink)
lowlife9
Super Member
lowlife9's Avatar
lowlife9 will become famous soon enough
Re: Where is the parking signal control for DVD unit?
i had mine rigged to a switch so i can play dvds while im driving.
__________________
lowlife9 is offline   Reply With Quote
Old 04-24-2009   #3 (permalink)
MidnightCivic
MidnightCivic's Avatar
MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light
Send a message via Yahoo to MidnightCivic
On most units you can ground the parking terminal so you can watch dvds while driving..that's what i did and works perfect
__________________
Current Mods
• DIY BOH • Progress Rear Sway
• Yellow Fogs • Altezza Grill
• 16 red/black te37 replicas • ep3 side markers
• Hayame Cat Back • K&N fipk intake
• D2's • 04 Smoked Taillights
• Cf Hood • Neuspeed Strut Bar
• Aero Sides • Oem Rear Lip
• Type B Front Lip • D3S Retro Headlights
Future Mods
• CF Trunk
MidnightCivic is offline   Reply With Quote
Old 04-24-2009   #4 (permalink)
technick03
Member
technick03's Avatar
technick03 is an unknown quantity at this point
^^ Yup ground it and it works while driving. Thats what I did too !
technick03 is offline   Reply With Quote
Old 04-25-2009   #5 (permalink)
CaliDanSD
New Member
CaliDanSD has a spectacular aura about CaliDanSD has a spectacular aura about
Mine i hooked under the center console. there is a wire there by the e-brake cable (sorry no picture). Yea I tried to do it the other way, but since its a gps one it tells me there is something wrong because the car is moving and the e-brake is up. good luck.
__________________
CaliDanSD is offline   Reply With Quote
Old 04-25-2009   #6 (permalink)
mrplow123456
Senior Member
mrplow123456's Avatar
mrplow123456 will become famous soon enough mrplow123456 will become famous soon enough
Yeah you can do what the others said and just ground it or you can ground it to the parking brake. Another option is setting a relay up and hook the signal wire to your park gear selector, if it is an automatic, and have the source wire be a ground. As for the back-up camera, they should be able to be viewed at any time but if the unit requires it to only be in reverse, then you can tap the reverse wire in the gear selector or if you have a manual, you will need to find a backup light to tap into. If you don't feel comfortable doing this stuff yourself there are plenty of people willing to help explain further or even go as far as to help you install. Good luck with your goals.
mrplow123456 is offline   Reply With Quote
Old 04-26-2009   #7 (permalink)
chuan
New Member
Quote:
Thanks for all your replies guys! As you all suggested, I grounded the parking sensor wire to the negative port of the cigarette lighter, and it WORKED!!! It's that easy! Now I'll just have to wait for my reverse cam to arrive (bought one on eBay just now). I'll keep posting if I manage to find the reverse gear control. My Civic is manual by the way.
Tags
backup , brake , civic , dnx5220 , dvd , ebrake , find , gear , kenwood , light , parking , reverse , signal , watch , wire , works
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
