Electronics Post your electronic questions here!
Messed with radio - now no power to radio, PL
Old 01-27-2009
bob95065's Avatar
bob95065 is an unknown quantity at this point
I was working on my car and had to get behind the factory radio the other day. I put everything back together and expected to enter the security codein the radio and everything woudl go back to normal. This wasn't so.
When I turned the key I didn't see "CODE" on the radio. In fact the radio was totally unresponsive, like it was getting no power. I took everything apart and the connectors were installed correctly and tight. I couldn't get the radio to power up.
I also noticed that my power door locks would only work when the ignition is on. I usually hold the driver's door handle and use the PL switch to lock the door. It woudln't work but did work when I put the key to on.
Anyone seen anything like this? Where should I start? Is there another security system that is affecting the radio and PL?
Old 01-27-2009
CraigW's Avatar
Re: Messed with radio - now no power to radio, PL
"Back Up" fuse in under hood box is open.
Old 01-27-2009
bob95065's Avatar
Where is this fuse? What number is it?
I didn't short any wires. What could have caused the fuse to blow?
Old 01-27-2009
bob95065's Avatar
I checked my under hood fuse box and you nailed it! The radio works great now. Thanks!
Old 01-27-2009
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
^^ you should rep him click the scale looking thing under his name and leave that man some rep! dont forget to leave your name so he can rep you back too ..
Old 01-28-2009
CraigW's Avatar
Thanks for the rep guys !!
I just wish more people would post up what they found wrong, So many threads are left hanging with no final answer.
Old 01-01-2018
skypie17's Avatar
skypie17 is an unknown quantity at this point
do you know which fuse is the back up fuse on an 03 civic
Old 01-01-2018
https://ww2-secure.justanswer.com/up...e_relay_ID.gif
Old 06-21-2018
brandon816's Avatar
brandon816 is an unknown quantity at this point
Almost same situation with my 2012 si coupe. Any suggestions?
Old 06-21-2018
What did you do to it?
Blown back up fuse? Engine compartment fuse box. One of the two marked with a bold outline on the diagram in the lid.
Old 06-21-2018
brandon816's Avatar
I was messing with my radio (aftermarket) and I'm pretty sure I shorted something since now I'm not getting 12V into the radio and my key wont work and dome lights wont turn on while engines off. I will definitely look into that fuse though
Old 06-21-2018
brandon816's Avatar
UPDATE: it was the backup fuse #29 10A, thanks brother.
Old 11-18-2020
Travisjk's Avatar
Travisjk is an unknown quantity at this point
Thank you so much!! Same exact problem, and same exact solution!! FUSE #29 10A!! You guys are the best!!
Old 11-19-2022
Phiz347's Avatar
Phiz347 is an unknown quantity at this point
I had same/similar issue on 02 Civic... radio, door chime, light chime & door locks were not working. The Back Up fuse(10A) under hood was the culprit.
Mikalraps
09-15-2018 09:49 AM
BCivDays
09-18-2016 10:38 PM
WillEl1.7
10-21-2015 09:53 PM
abawade
10-04-2012 08:45 PM
Aw614
08-27-2008 09:37 PM
Quick Reply: Messed with radio - now no power to radio, PL
