Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-18-2008   #1 (permalink)
mjlenz
New Member
mjlenz is an unknown quantity at this point
Alpine 9874 install
I am going to install an Alpine 9874 receiver in my 2002 Civic coupe. I would like to keep the remote lock feature functional so I'll probably have to keep the stock stereo hooked up (correct?). Also does someone make a Y cable to keep the stock stereo hooked up plus plug and play the Alpine? There's a lot of great info on this site but I couldn't find the answer to this one. If there is one already posted then I appologize and could someone point me in that direction?
Thx
mjlenz is offline   Reply With Quote
Sponsored Links
Old 11-18-2008   #2 (permalink)
G617
New Member
G617 is an unknown quantity at this point
Re: Alpine 9874 install
Are you referring to keyless entry? If so, if I remember correctly, 7th gens didn't have the keyless entry tied into the radio. That was one of the 6th gens like 97' or 98'. As far as a "Y" harness, you're gonna have to make one. I've been out of the Car Electronics field for a few years now, so I'm a bit rusty, but I believe what I said is right.
__________________
2001 Honda Civic LX
Kamakazie Header, Magnaflow Exhaust,Injen SRI,Progress Front Sway Bar, Tokico Shocks & Struts
Progress Rear Sway Bar, Yokahama Avid ES 205/40/17, Tanabe DF210 Springs, Proline 928 16",Viper 791VXR, DEI 556HW Immobilizer Bypass, DEI 530T Window Automation, Pioneer DEH-7800MP,Pioneer 1671R 6.5", Pioneer 6971R 6x9",Power Acoustik NB-20 Tweeters, Rockford P3001 Mono block,Rockford P212S4 (2).... and.... 2nd D17a1
G617 is offline   Reply With Quote
Old 11-18-2008   #3 (permalink)
SITNLOW97
Senior Member
SITNLOW97's Avatar
SITNLOW97 will become famous soon enough
Your stock headunit has NOTHING to do with ur keyless entry in a 7t gen. It only effects 98 or older civic. Go ahead with the install.
SITNLOW97 is offline   Reply With Quote
Old 11-18-2008   #4 (permalink)
mjlenz
New Member
Thx for the info. I thought an 02 civic needed the stock stereo for the keyless entry. But the stock stereo harness won't be the same as what the Alpine needs will it? If the answer is no where is a good place to find an adapter? Thx again!
Old 11-18-2008   #5 (permalink)
EnvyX
Member
EnvyX will become famous soon enough
parts-express . com
EnvyX is offline   Reply With Quote
Old 11-18-2008   #6 (permalink)
sp4rt4n
Member
sp4rt4n's Avatar
sp4rt4n is an unknown quantity at this point
Send a message via AIM to sp4rt4n Send a message via Yahoo to sp4rt4n
just go buy a wire harness from you local car stereo shop. and wire it up to your alpine harness.
__________________
MECP BASIC CERTIFIED
myEM2 build
http://www.myspace.com/black_knight21
05 CIVIC EX---DD
07 R6 RAVEN--MY TOY
sp4rt4n is offline   Reply With Quote
Old 11-19-2008   #7 (permalink)
electric130
I.C.E. Mod
electric130's Avatar
electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned
the head unit has nothing to do with the keyless entry on 7th gens.
electric130 is offline   Reply With Quote
Old 11-21-2008   #8 (permalink)
mjlenz
New Member
Thanks for all your help!
Tags
01 , 2002 , 2003 , 9874 , alpine , civic , civicwiring , harness , honda , install , installation , radio , stereo , wire , wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
