Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-16-2008   #1 (permalink)
AkaDeathstar
Member
AkaDeathstar is an unknown quantity at this point
Changing stock dim instrument cluster bulbs LEDS
I have a 2004 Honda Civic DX Sedan. Does anybody know what type of bulbs
replace the stock dim yellow bulbs behind the instrument panel? I want some
nice bright LED bulbs. Blue ones if i can, thanks for the help.
AkaDeathstar is offline   Reply With Quote
Sponsored Links
Old 11-16-2008   #2 (permalink)
valenzuela
Member
valenzuela's Avatar
valenzuela should not be trusted valenzuela should not be trusted valenzuela should not be trusted
Re: Changing stock dim instrument cluster bulbs LEDS
t-5 bulbs
__________________
valenzuela is offline   Reply With Quote
Old 11-16-2008   #3 (permalink)
DieMaster
Senior Member
DieMaster's Avatar
DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light
IMO i wouldent do blue very glary at night. red is best. but white makes it look cleaner.
look here: http://www.ledautomotive.com/OrderInfo/01-04Civic/
DieMaster is offline   Reply With Quote
Old 11-16-2008   #4 (permalink)
baron340
Senior Member
baron340's Avatar
baron340 is just really nice baron340 is just really nice baron340 is just really nice baron340 is just really nice
dont order from them^^ its WAY over priced. all you need are 3 and 5 mm led's and mini 10 ohm resistors, and some soldering knowledge. its time consuming and a bit of a pain to get it all done, but its not that hard. another thing, be sure and file down the end of the leds some, it will make the light diffuse some so you dont get big hot spots. i still have some hot spots in mine, even with the filing.
baron340 is offline   Reply With Quote
Old 11-17-2008   #5 (permalink)
AkaDeathstar
Member
The kits dont sound like a bad idea, do these actually replace the instrument panel with the speedometer, pedometer and tachometer though? Also my main needles are red, anyway to change those to like white or not realy?
Old 11-17-2008   #6 (permalink)
baron340
Senior Member
baron340's Avatar
wow...i just gave it to you right there.. even with the kits you have to tear the dash out, pull the old bulbs out and do some soldering. it took me weeks of researching to find out those resistors are 10 ohm. go to oznium.com order 5 mm led's in whatever color you want they are like a dollar a piece. go to radioshack tell the guy you want mini 10 ohm resistors, they are about the size of a grain of rice. those dont mess with your instrument cluster though. you cant really swap the lights behind your tach and stuff. the only real way to do that is to swap the whole cluster with an rsx cluster.
Old 11-17-2008   #7 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
older style cluster only uses maybe 5 bulbs, and if you change with leds, you will just have a bright spot where the led is. unless you get wide angle hi power leds i sometimes see but those always burn out fast.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 11-17-2008   #8 (permalink)
AkaDeathstar
Member
oh okay thanks baron, sorry i thought those bulbs would replace the bulbs behind the tachometer etc... I just wanted a different illuminating instrument panel. So i think i mite just look into the rsx cluster, will it fit in there easily or will there have to be some custom fabrication?
Old 11-17-2008   #9 (permalink)
baron340
Senior Member
baron340's Avatar
it takes a little custom fab, but its not too bad. there is a diy floating around somewhere, i'm pretty certain there is one on 7thgenhonda.com if not here.
Old 11-20-2008   #10 (permalink)
AkaDeathstar
Member
alrite cool so im gona go with the bulbs off oznium, way cheaper, does the hyper white look cleaner than the blue?, and how much faster would the wide angle lens bulbs burn out ?
Old 11-20-2008   #11 (permalink)
DieMaster
Senior Member
DieMaster's Avatar
white looks more OEM-ish than blue. IMO
also it's a common mis-conseption that led's burn out. truth is, THEY DONT if wired and cared for correctly.
Old 11-20-2008   #12 (permalink)
AkaDeathstar
Member
haha oh okay sounds good, and exactly how many 5mm or 3mm bulbs would i need just to be accurate?
Old 11-20-2008   #13 (permalink)
gearbox
Super Moderator
i used to do cluster with leds and i usually ended up using 40 5mm leds. you might be able to do less but the light wont be as smooth. you could also get some premade strips maybe and wrap them around the edges pointing inward, that way it will spread the light without shining it dtraight up thru the numbers.
__________________
www.lubecontrol.com
Member 1025782
Old 11-20-2008   #14 (permalink)
AkaDeathstar
Member
wow 40 it cant be tht many, i thought it was like 10 or less, and u wuld have to get 10 ohm resistors for each one?
Old 11-20-2008   #15 (permalink)
gearbox
Super Moderator
you can wire several together in series and then figure the resistor for it.
http://ourworld.compuserve.com/homep...Bowden/led.htm
__________________
www.lubecontrol.com
Member 1025782
Tags
2004 , bright , bulb , bulbs , change , civic , cluster , dash , extra , honda , instrument , led , make , needles , swap , tachometer , white
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
