Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
Reload this Page
power door lock actuator
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
LinkBack Thread Tools
Old 09-13-2008   #1 (permalink)
wschw2
New Member
wschw2 is an unknown quantity at this point
Hi Im new here, In read just about every thread i could find on power door lock on the civic 2002. I was able to isolate the problem thanks to the input on this forum. I have to change the acuator, but this causes a bit of a problem, I couldnt find any guidelines on how to do this. Can anybody help. I am thinking the best way would be to take the complete lock out which unscrews from the door . Trying to remove the actuator by the inside panel, looks impossible as i cant see anything unless somebody knows how. Anybody help please,
Thanks
wschw2 is offline   Reply With Quote
Sponsored Links
Old 09-13-2008   #2 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
tfnaaf should not be questionedtfnaaf should not be questionedtfnaaf should not be questionedtfnaaf should not be questionedtfnaaf should not be questionedtfnaaf should not be questionedtfnaaf should not be questionedtfnaaf should not be questionedtfnaaf should not be questionedtfnaaf should not be questionedtfnaaf should not be questioned
Re: power door lock actuator
never done one and alldata dont show a procedure. do you have the door pannle off yet?
tfnaaf is offline   Reply With Quote
Old 09-13-2008   #3 (permalink)
IMSHANE
New Member
IMSHANE's Avatar
IMSHANE will become famous soon enough
Here's a link to one i found in the DIY section of the forum.
CLASSIC DIY: replacing door lock assembly and actuator
Hope that helps.
IMSHANE is offline   Reply With Quote
Old 09-13-2008   #4 (permalink)
wschw2
New Member
Smile Re: power door lock actuator
Thanks for your reply. The site that you referred me to is exactly what i wanted. He explains everything in detail and I thought that this would be how to do it, but I wasnt sure about the details such as which rod to disconnect etc.
Thanks Again.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Amp Wiring 2k1civic coupe
DIY: Head unit install
DIY: Installing Rear Speakers in a Sedan
Sound Deadening DIY
Post pics of your trunk w/ subs, amps and whatever!
MTX Jackhammer! Don't they know when to draw the line?
DIY: Custom Trunk II !with access to spare tire!
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
*** The big I.C.E. & Electrical sticky (DIY's, links, POSTING GUIDELINES, more) ***
**FINISHED** HU relocation
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
