Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-04-2008   #1 (permalink)
army12bc
Member
army12bc's Avatar
army12bc is an unknown quantity at this point
Send a message via Yahoo to army12bc
Coil Stick
http://aempower.com/ViewCategory.aspx?CategoryID=123
does anyone know if these will fit the d17a2? if so how good r they?
army12bc is offline   Reply With Quote
Sponsored Links
Old 09-04-2008   #2 (permalink)
drunkenmagnum
drunkenmagnum's Avatar
drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light
Send a message via AIM to drunkenmagnum
Re: Coil Stick
There was another company making some that would fit the D17 but where $400 a set (saw it in Honda tuning). I dont see there being any benifit to having them since people are already making so much power without them.
__________________
196 hp
194 fpt @ 10psi - Before the rebuild
"My d!ck feels like corn"-Dane Cook
R.I.P 7thgencivic.com
Type-S Fuel Injectors for sale.
WTB: 02-04 ep3 (si) rear brake assembly
T.E.A.R.S crew member #1
Car for Sale
drunkenmagnum is offline   Reply With Quote
Old 09-04-2008   #3 (permalink)
rutscivic
Senior Member
rutscivic's Avatar
rutscivic is an unknown quantity at this point
Send a message via AIM to rutscivic
Re: Coil Stick
dont waste your money
rutscivic is offline   Reply With Quote
Old 09-04-2008   #4 (permalink)
bomerman19
Super Member
bomerman19's Avatar
bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned
Re: Coil Stick
http://www.okadaprojects.com/usa/products_direct.htm
there $735 for the d17 ones not worth it
bomerman19 is offline   Reply With Quote
Old 09-04-2008   #5 (permalink)
skipbarber
skipbarber's Avatar
skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all
Send a message via AIM to skipbarber
Re: Coil Stick
the stock coils are extremely powerful. Using a tester, Ive been able to make them shoot about a 2 inch arc.. dont waste your money. besides, the aem's i believe are for people who are looking to convert from distributor to CDI.
__________________
sig by speedfoos
The DX resource site.
-2002 SSM EM2 - D17A1/A2 hybrid turbo(vtec, non-egr, steel oil pan, Hondata managed) 240 fwhp, 210 lb/ft tq @ 9.5 psi
-1991 MK3 Toyota Supra turbo (full cage, track setup) TBA
-2008 Honda NPS50 Ruckus - Stock 5 rwhp
skipbarber is offline   Reply With Quote
Old 09-04-2008   #6 (permalink)
army12bc
Member
army12bc's Avatar
Re: Coil Stick
i found the okada ones too the aem ones i found are 6.54 in and 5.54 in i have to measure. i'm not looking for power i'm looking for more constant spark mine are new and just dont burn fuel i'm running really lean
Old 09-05-2008   #7 (permalink)
skipbarber
skipbarber's Avatar
Re: Coil Stick
running lean with no spark? that doesnt make sense. misfiring causes rich readings because the fuel isnt being ignited. unless youre having lean misses, in which case you need to figure out why youre running lean and the air fuel mixture is being ignited before the plug fires.
__________________
sig by speedfoos
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
