Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
Reload this Page
Head light removal help
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
LinkBack Thread Tools
Old 07-09-2008   #1 (permalink)
osk
New Member
osk is an unknown quantity at this point
I'm wanting 2 remove my passenger head light so I can replace the 2 signal bulbs. I removed the required top bolts but the light still seems fastened down at the bottom somewhere.
Is there a trick to remove the headlight assembly??:confused
Thanks,
Osk
osk is offline   Reply With Quote
Sponsored Links
Old 07-09-2008   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant future
Re: Head light removal help
um first, you do not remove the assembly just to change bulbs. if you do that you have to reaim the beam because the position of the light will have changed. all you do is take off a few clips from the fender lining above the wheel and reach your hand inside to the back of the lamp. just like the manual says. if you still insist on taking the whole light off, then you need to first remove the bumper and then there are two more bolts holding it down.
gearbox is offline   Reply With Quote
Old 07-10-2008   #3 (permalink)
sniperscout
You VTEC...I-VTEC
sniperscout's Avatar
sniperscout is just really nicesniperscout is just really nicesniperscout is just really nicesniperscout is just really nicesniperscout is just really nice
Quote:
that made me laugh
sniperscout is offline   Reply With Quote
Old 07-10-2008   #4 (permalink)
sl33pyriceboi
Ultimate Member
sl33pyriceboi's Avatar
sl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to behold
^do it like that....but i have a hard time because id have to jack up my car n stuff...
if you want to actually remove ur headlight....you needa remove ur bumper.
to do that, you need to:
1. remove all the little black clips at the bottom.
2. on the side of the bumper where the fenders meet near the wheel, there are two screws, use a #8 socket to take them out.
then jsut pop off ur bumper.
then to remove ur headlights, there are one at the top. one on the side. and one hidden benieth the headlight which you will need an extension socket to take out.
sl33pyriceboi is offline   Reply With Quote
Old 07-10-2008   #5 (permalink)
manahoonie
manahoonie's Avatar
manahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questioned
well, i'm hoping you're asking because you got the car used from another dealership, and it didn't have the manual in it....
manahoonie is offline   Reply With Quote
Old 07-10-2008   #6 (permalink)
twiztedD17A1
Member
twiztedD17A1's Avatar
twiztedD17A1 is just really nicetwiztedD17A1 is just really nicetwiztedD17A1 is just really nicetwiztedD17A1 is just really nicetwiztedD17A1 is just really nice
click on my headlight install below
twiztedD17A1 is offline   Reply With Quote
Old 07-10-2008   #7 (permalink)
osk
New Member
Quote:
Yup!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Amp Wiring 2k1civic coupe
DIY: Head unit install
Sound Deadening DIY
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
MTX Jackhammer! Don't they know when to draw the line?
DIY: Custom Trunk II !with access to spare tire!
*** The big I.C.E. & Electrical sticky (DIY's, links, POSTING GUIDELINES, more) ***
HID in TYC setup. With no projector conversion. Video on pg 17.
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
