Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
Reload this Page
Question about my amp???
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
LinkBack Thread Tools
Old 05-10-2008   #1 (permalink)
FerioCivic_DX
New Member
FerioCivic_DX's Avatar
FerioCivic_DX is an unknown quantity at this point
I've got an MTX thunder 5601
http://www.sonicelectronix.com/item_...nder+5601.html
It says it's 600 watts at 2 ohms. Can I bridge it , and run 600 though each 12 in. sub i have?
Thanks!
FerioCivic_DX is offline   Reply With Quote
Sponsored Links
Old 05-11-2008   #2 (permalink)
FGCOUPE
Super Member
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
Re: Question about my amp???
600W Amplifier
Subwoofer:
run a 600W SVC sub to it
(or)
run a DVC sub which is 300W each coil = 600W total
(or)
run x2 300W SVC subs to it
basically keep it at 600W no matter what sub(s) you use!
FGCOUPE is offline   Reply With Quote
Old 05-11-2008   #3 (permalink)
EggRollBandit05
Super Member
EggRollBandit05's Avatar
EggRollBandit05 will become famous soon enoughEggRollBandit05 will become famous soon enough
depends on what kind of sub/s you have and how you wire them.
If each sub has a single 4 ohm then wire them in parallel so amp sees a 2 ohm load and pushes out 600w(each sub gets 300w)
if both your subs are dvc then it gets complicated from there depending if they are 2,4, or 8 ohm coils
EggRollBandit05 is offline   Reply With Quote
Old 05-11-2008   #4 (permalink)
FerioCivic_DX
New Member
My subs are 2 DB drive speed series 12's.
Old 05-11-2008   #5 (permalink)
Envy
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
we still need the rms rating and amount of coils.
Envy is offline   Reply With Quote
Old 05-11-2008   #6 (permalink)
phuviano
Slowest 7thgen in the GTA
phuviano's Avatar
Thanks!
Simple answer is no, you can't have 600 watts rms going to each sub. If you have 2 subs, the most you have to each sub is 300 rms. It depends on how your subs are wired though.
If you have 2 subs, and want to produce 600 rms to each sub, you need an amp that can produce 1200 watts rms.
phuviano is offline   Reply With Quote
Old 05-12-2008   #7 (permalink)
FerioCivic_DX
New Member
Good news this amps actually pushes 777 watts instead of 600. According to something I read.
Does anyone know if this amp is 1 ohm stable?
Old 05-12-2008   #8 (permalink)
Envy
Diamond Member
umm its rated at 600rms at 14.4 volts. theres no way its going to push 777 watts at your cars 12 volts.
Old 05-12-2008   #9 (permalink)
fallout
Senior Member
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
Quote:
Battery is around 14 volts when car is on and it has nothing to do with how many watts the amp can push. If you wire it in parallel @ 2ohm load, it could go up to 750+. It also depends on many other things such as length and thickness of wire, resistance of the subs, single/dual voice coils... etc. Also, companies under-rate their amps and no amps/subs run exactly as their rated wattage. Plz learn some general electric before you make suggestions/comments.
To answer your question, you cannot bridge it. This is a monoblock amp. This means it only has one channel. If you have 2 or more channels, you can bridge it into one. This is NOT one ohm stable so don't even try. If you have 2 subs you can wire them in parallel and it will be 2ohm load. Or you can wire them in series and have a 4ohm load. This is of course, based on the sub(s) you buy and how you want to wire them.
fallout is offline   Reply With Quote
Old 05-12-2008   #10 (permalink)
Envy
Diamond Member
umm i realize that companies underrate theyre amps. and yes, your battery puts out 14.4 volts. but the AMP in the trunk will not see that number. In our car, with a stock alternator outputting 80amps, the amplifier will likely only see 12 volts at optimal conditions (no a/c, headlights, dome lights, power windows etc)
EDIT: The amp is fused to 60 amps. Using some basical electrical formulas of watss = amps * votls, you can conclude that at
14.4 volts * 60 amps = 864 watts.
The birthsheet rating was 777rms, so
777Watts / 14.4 Volts = 53.4 amps. Becaues its less than .5, well round down to 53 amps.
12volts * 60 amps = 720 watts. so 720 is actually a feasible number, although unrealistic because if it exceeded 60 amps, itd blow the fuse. So we know its not hitting 60 amps. So:
lets say:
12 volts * 53amps = 636 watts. still undderated, but thats 318 rms per sub. Thats acutally pretty good.
I realize conclusions have been drawn between amps/volts/alternator output, but it has been simplified for the sake of simplification. If im wrong here, please correct me.
Second Edit: I have an Infinity 611a Monoblock Class D amp. It has 2 sets of terminals. According to the owners manual, one sub per terminal is normal mode @ 4ohms. Using the outer pos/neg terminals, it refers to this as "Bridged mode" This bridged mode should be used in a 2Ohm configuration for a total output of 657RMS @ 2ohms at 14.4 volts. It is CEA-2006 compliant, just like your MTX amp, meeting it has been certified to meet its advertised rating. In nonbridged 4Ohm mode, it runs 465RMS@4ohms. This bridgeable configuration has been confirmed by local audio shops.
Old 05-12-2008   #11 (permalink)
Envy
Diamond Member
So if the batterys volts have nothing to do with the wattage an amp pushes, then what does? Cause you know, all amps are just magical blocks that produce power from no volts.
Why do you think you need a power cord from the battery to the amp!?!? To power your pretty little LEDS?
silly goose.
Maybe YOU should learn some "general electrical knowlege." the amount of volts the battery pushes has EVERYTHING to do with how many watts the amp can push.
Watts = VOLTS * Amps
But I will acknowlege there is more to it than this...
Old 05-13-2008   #12 (permalink)
christmaspie
Super Member
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Voltage at the amp with engine on will be between 12.6-14.4 depending on vehicle load. That number is tightened up with a cap.
Amp output is not 100% of amp input, there are efficiency issues at hand.
Don't misspell the units if you want to look like you know what you're talking about.
Bridged implies there is more than one configuration. You can't "bridge" a mono amp because there's not two channels (or more) to bridge into a smaller number of channels. The 611a does have two sets of terminals, they are wired internally in parallel as one channel.
http://www.crutchfield.com/App/Produ...,_and_Controls
christmaspie is offline   Reply With Quote
Old 05-13-2008   #13 (permalink)
christmaspie
Super Member
Certainly, if the amp has a regulated power supply.
For some well done math: http://www.bcae1.com/regunreg.htm
Old 05-13-2008   #14 (permalink)
Envy
Diamond Member
yea i didnt know how they are wired internally, but on the owners manual, it states using them both as one equals "Bridged Mode." i agree this is not a true bridged mode though.
if you wanna get more techincal, its usually accepted that a Class D amp is about 80% effiicient. The other 20% is lost in heat. So we will take
636 solid watts * .8 (efficiency) and get - 509 real rms watts [probably on the lower side that youll ever see, especially considering its CEA-2006 compliant.
Old 05-13-2008   #15 (permalink)
Envy
Diamond Member
So all in all, its a good amp. But youll never get 1200rms out of it. Also, its unlikeley youll get 1200rms out of your stock electrical system without a cap for extended periods of time. what are the rms ratings of your subs?
For 1200rms:
I reccommend the Kicker zx1000.1
or the Alpine MRP-M1000
i find those to be the most cost effective for that amount of REAL power. Sure you can get a hifonics 3000watt amp, for a little cheaper, but its overrated.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Amp Wiring 2k1civic coupe
DIY: Head unit install
Sound Deadening DIY
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
MTX Jackhammer! Don't they know when to draw the line?
DIY: Custom Trunk II !with access to spare tire!
*** The big I.C.E. & Electrical sticky (DIY's, links, POSTING GUIDELINES, more) ***
HID in TYC setup. With no projector conversion. Video on pg 17.
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
