Civic Wire Harness for trailer
Old 04-15-2008
ronaldo9's Avatar
Does anyone know if there is a plug n play wire harness for a 2003 Civic? I'd like to trailer my bike with my civic but can't find the correct wire harness to connect to the trailer for my year. I only see them for the 06-08 civic. Much help appreciated. Thanks.
Old 04-15-2008
This is Myspace
DsevenEm2's Avatar
Re: Civic Wire Harness for trailer
well... i dont know if this will help but for trailers you should have a brown wire, green wire, white and yellow.
yellow=left side of trailer
green=right side
brown=every light on the trailer
white=ground
thats how trailer wire packages come.. that probably doesnt help much but thats my .02 cents lol
Old 04-15-2008
Rough, Tough, Real Stuff.
Unevolved's Avatar
Unevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to behold
It wouldn't be that hard to make one yourself, in theory. Just splice into the blinkers and brake lights. In theory, of course.
Old 04-16-2008
electric130's Avatar
you'll need a converter harness to go from 3-wire to 2-wire. that's what i did for my trailer. preferably buy a powered converter that gets power from the battery. otherwise, you'll risk burning up your stock wires by trying to power the trailer if it has a bunch of lights. 2 tail lights and 4 or less marker lights and you should be fine with an unpowered converter. it all depends on the type of bulbs and the total wattage draw. but no, there are no PNP t-harnesses commercially available for 7th gens.
powered converter:
http://www.etrailer.com/pc-ELEBF~118176.htm
you'd still need the wire to go to the battery and a fuse. they sell that for another $10.
Default_Slayer
Electrical DIY
12-04-2022 07:56 AM
CarStuff
12-06-2020 12:52 PM
Jon-Ohio
06-30-2018 08:10 PM
NROD315
04-16-2015 08:40 AM
Quick Reply: Civic Wire Harness for trailer
