I.C.E. & ElectricalPost all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
Re: HID in TYC setup. With no projector conversion
if you want brighter tyc halogens, get a +50 H1 bulb for the main projector. like philips VP or osram silverstar (not sylvania). both are clear bulbs and increase lumen output from 1500 stock to 1800 for the +50. (thats 600 lumen total increase which is noticably brighter). here are my old tyc with osram silverstar clear bulbs. its decent output, enough to see with. but the uneven beam is kinda stupid. still, the three bright spots are more intense than the stock lights. check www.powerbulbs.com and autolamps-online.com or suvlights.com
__________________
Restore Performance, Reduce Costs www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
Sponsored Links
Just since we're talkin' bout HID's... I have 8000K on Projector's. I love them... should definately go with Projectors and HID combo! What do ya'll think?
anyone have picture of HID light output in the stock housin head lamp? Would it make a big diff. if the blub came wit a glare shield or not ? cuz the stock housin head lamp already have a shield.
Quote:
Originally Posted by ryox82
Pardon me for being ignorant on the subject, but what is the fire hazard? Wire gauge? Lack of fuse? No addition grounding?
The reason you need a harness is because the ballasts take a lot more amps to ignite the hid bulbs then halogens. The stock harness is not designed to more a significant amount of amps. Thats why people eventually fry there stock harness.
After the initial startup, the amp useage is the same as stock bulbs.
Hid harness = $40-60.
New factory harness from honda = bending over to the dealership
take your pick.
i would save for a retro. i say do it right the first time or not at all.
Example
my tsx retrofit on my jdm lights
see how sharp the cut off is?
My car also flicker's blue and purple from a distance like a bmw or mercedes
__________________ 04 Civic Coupe with aero kit =sold
94 Integra 3dr= sold
02 c32 mercedes amg = new project
Quote:
since YOU asked, i think they look rice. way to blue to be practical. but that's just my opinion. that's not what OEM HIDs look like at all. OEM are pure white. that's what mine are. 4300k. i wouldn't go any darker either. i've driven with blue headlights before and you can't see jack at night compared to 4300k HIDs.
back to the OP, i will ditto everything said here about harnesses. you DEFINITELY NEED one. depending on the ballast, the HID's can pull 2-4 times more current than stock halogens during startup. cheap ebay PNP kits tend to pull more current than high quality OEM ballasts. i have both on my car so i'm speaking from experience. i run all 14ga wire on the harnesses i made. stock is more like 20ga.
I say let them learn from first hand...I know it sounds mean....but for some people seeing them with their own eyes are better than telling....
There are three kinds of people dumb, regular, and smart
dumb ones never learn from his own mistakes...making same mistakes over...
regular ones learn from his own mistake and takes the right direction...
smart ones are those who learn from other's mistakes and takes right direction...
But back to topic, I also have 4300K bulbs as well...also Matsushita Gen 3 ballasts for my projector with wire harness....I also keep spare ballasts and relays in the car....even my wife is impressed by the amount of light that my car gives compared to her car....
__________________ 2001 EX Coupe Rally Red 5 Speed..(RIP)
2009 Civic SI Alabaster Silver Metallic Sedan
A wiseman fears and departs from evil but a fool rages and is self-confident.
the only time you need a glare shield is for H4 hid kits (01-03 civic headlights). this is required because the stock halogen bulb also has a glare shield, it just happens to be built into the bulb on the bottom of the lo beam filament. so for hid bulb, you NEED the shield for it to work right in the headlight. even then, you will still have a lot of glare since the housings were designed that way. even the halogens are made to glare a little, to light up road signs. as for that 8000k kit, id be surprised if those bulbs are even making the same lumen as a halogen bulb. with 6000k, you are already down to 2400lumen, im sure yours is much less. so whats the point in having a blue light thats barely as bright as halogen, stuck in a terible projector that cannot even make use of the light properly, to give less overall light than stock? idk. when youve seen an s2k or TL in action, you will know what real hid performance looks like.
anyway, here is a pic of hid kit 4300K color in stock 01-03 headlamp. it doesnt look too bad, but there is not as much light as you would have from using a real hid projector.
stock housing with H4 sylvania xtravision clear halogen bulbs running at 15v (my current setup).
for comparison, here is an s2000 projector retrofit running 6000k hids (about 2000 lumen dimmer than the normal 4300K bulbs).
i am looking for some more pics to show you but this will work for now.
__________________
Member 1025782
You people are still as helpfull as ever and thats why I still come by here. Thanks for the heads up on the brighter halogen bulbs. I will use them until I can save for a retro or while I think about it. It is a pretty big investment but the light output looks like it is worth it to me.
some of the best projectors for hid... if you have no clue about retrofitting and want a good job, and have around $1k to spend sometime, head over to www.retro-solutions.com they do great work.
acura TL (bixenon, has lo and hi in same projector)
s2000 (single xenon, lo beam only)
__________________
Member 1025782
no the nightbreakers are not as good as people thought. the coating robs light and makes them burn out faster. and theyre not as bright as others of the same type.
__________________
Member 1025782
heres a review of H1 +50 bulbs. i would stick with osram silverstar. the philips vp has a small blue cap and over time it tends to fade and make the colors look weird. stick with all clear bulbs.
yeah, as long as you get the H4 size kit. its basically a d2s hid bulb with the capsule mounted on a H4 base so it fits the stock housing. but since reflector was not made to use hid, the output is not always that good. and alot more glare for other dirvers.
__________________
Member 1025782
