I.C.E. & ElectricalPost all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
its worth it yes, more for sound quality not really road noise. for that you should buy a few cans of rubber undercoat and do the rear wheel wells and the area under trunk. can also put BB or other deadener in the doors.
fatmat works real well for sound deadening. I got like 100 square feet of it for around 110 bucks on ebay. And 100 square feet is plenty. I did my doors, and my trunk floor(2 layers) and only used roughly 20 sq. ft
__________________ You know sometimes they let me look up at that East Texas sky, and the rain on the pines, oh Lord, how it shines.
I have to disagree about FatMat for both value and effectiveness. It's better than nothing as long as it doesn't fall off, but there are MUCH better products for not very much more money.
^I've had it on through the texas heat... it's stuck pretty well. When you buy items like this, it's my opinion that you're buying a name, not a "quality" product. The specs, or if that's even what you want to call them, for sound deadening material is basically the same.
Not to hijack, but i've got a question about sound deadening and i figured i wouldn't make an alternative thread about it.
Do you do everything in your trunk, including the floor, wheel wells, etc? or just the bottom of the trunk door? I've got a small vibration problem from the outside at the back, and i think it's my spoiler, but it's probably a number of other things.
It usually is a number of things - spoiler, license plate, tail lights, rear deck, etc. - all kinds of stuff back there to rattle. Sound deadening will reduce the energy available to generate rattles, but it really is best to treat the rattles first. Make sure everything is tightened down. Use silicone caulk to keep pieces apart, foam tape, expanding foam, bits of foam rubber, all are useful tools. You want to prevent any two hard surfaces from making contact.
Once you've done that, you can apply as much or as little sound deadening, really vibration damping, products as you want. I've always found it best to use less of a better quality product when budget is an issue. Wheel wells are big if you want to block exterior noises. Generally, you want to treat any place the panels are resonant. If you can tap on them and they ring, they are worth treating.
Sheets of 1/8" of 1/4" closed cell foam like Ensolite or Neoprene are really useful. I like to cover every surface I treat with vibration damper and use it to gasket trim panels.
^There have been tons of things known to rattle in a civic. I've seen it all the way from taillights and the rear panel to small stuff like, hinges and whatnot. It's just a matter of figuring out exactly where the vibration is coming from and eliminating the problem.
As far as where you sound deaden the trunk. It depends on what you like. I don't like to be standing outside my car and hear shit rattling everywhere, so for starters I did my entire trunk, wheel well, spare tire well, sides, trunk door, everything. From there, I figured out where the other rattles were coming from, and took every step to eliminate them.
dynamat doesnt reduce rattle, you need to find what it is and stuff foam pads inbetween so the surfaces dont touch. you cant get rid of everything but some places are easy like rear deck and door panels. i had my window rail vibrating so i stuffed in some foam and now silent.
