Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-25-2007   #16 (permalink)
Keigo
Senior Member
Keigo's Avatar
Keigo is an unknown quantity at this point
Re: DRL electrical woes ... How screwed am I?
.... To remove this ad, register today for free or log in if already registered!
__________________
Here We GO...
Keigo is offline   Reply With Quote
Sponsored Links
Old 06-26-2007   #17 (permalink)
Keigo
Senior Member
Keigo's Avatar
__________________
Here We GO...
Old 06-26-2007   #18 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
See the larger solder joints near the center ?? The problem connections will in most cases have a black ring around the solder joints. I see some on your board. Use a 30-40 watt iron (avoid a solder gun if possible) Unless you can work quickly with the joints. It will not hurt to do most of the larger connections in the center area. I would also touch up the solder joints for the connector at the board.
CraigW is offline   Reply With Quote
Old 06-26-2007   #19 (permalink)
Alpha 5
Ultimate Member
Alpha 5's Avatar
Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned
Send a message via AIM to Alpha 5 Send a message via MSN to Alpha 5 Send a message via Yahoo to Alpha 5
Off topic:
Key Keigo,
I just noticed you have heated mirrors. That is cool. Also since you have the DRL switch where the U.S. moon roof switch is. Where is the Canadaian model moon roof switch?
Alpha 5 is offline   Reply With Quote
Old 06-26-2007   #20 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
drl switch? wheres that. i didnt think stock cars came with em its automatic turn on with ignition.
gearbox is offline   Reply With Quote
Old 06-26-2007   #21 (permalink)
Alpha 5
Ultimate Member
Alpha 5's Avatar
It might actualy be the fogs but I thought that the fog switch was in the center console in front of the shifter. Regardless of what it is where would the Moon roof switch go? It would seem kinda silly to put it in the center.
It is the first link he posted.
Here it is
Old 06-30-2007   #22 (permalink)
dandan05
New Member
dandan05 is an unknown quantity at this point
I recently had this problem with my Civic and I can 100% confirm it the the DRL relay. Its a grey box located under the steering wheel. The problem is a short in the relay causing the solder points to release. It can be fixed your self or just buy a new one on eBay for $30. Takes 2 minutes to fix. This will cause sometimes one of your Daytime running lights to not turn on at all and the buzzing. If you turn your headlights on it will go away. I don't understand why is buzzes under the glove box, but thats the DRL relay.
dandan05 is offline   Reply With Quote
Old 09-05-2008   #23 (permalink)
poups
New Member
poups is an unknown quantity at this point
Quote:
The little gray box behind the glove box is the daytime running light relay, and the component you solder is the daytime running light control unit. you might need to replace the little gray box too
poups is offline   Reply With Quote
Old 01-17-2009   #24 (permalink)
atlmapas
New Member
atlmapas is an unknown quantity at this point
I had the exact same problem on my '02 Canadian Civic LX (DRL buzzing until you turned on headlights and right high beam inop). If not for this forum and the posting of the fix for this problem I would have been pulling what little hair I have left out of my head. Thanks for the solution of resoldering the connections on the DRL module behind the cruise control switch/side mirror adjustment panel. I resoldered the connections that looked burned and it worked like a dream. Thanks for everyone's help!!
atlmapas is offline   Reply With Quote
Old 01-17-2009   #25 (permalink)
gearbox
Super Moderator
glad you got it fixed. its due to the high heat of the module that causes the solder to come loose over time. those wires carry alot of current too.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
Old 01-17-2009   #26 (permalink)
sl33pyriceboi
Ultimate Member
sl33pyriceboi's Avatar
sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold
Send a message via AIM to sl33pyriceboi
Quote:
thank you for SEARCHING and not just posting a question (like every other noob on here). +1 for you.
__________________
7thGen.MT.C.
Quote:
Originally Posted by gearbox View Post
alot of people just talk to say something. most of the time they have no idea wtf is going on lol
Quote:
Originally Posted by manahoonie View Post
lol. well we got newbs to use the SEARCH button.... NOW the next step is to look at the date
Step 1) SEARCH
Step 2) DATE CHECK
sl33pyriceboi is offline   Reply With Quote
Old 03-19-2009   #27 (permalink)
babzog
New Member
babzog is an unknown quantity at this point
Hey folks,
I am going to give this a try. One Q: How do I pull the panel holding the switches that's covering the DRL module? Don't want to break anything with excessive force.
Thanks!
babzog is offline   Reply With Quote
Old 03-19-2009   #28 (permalink)
gearbox
Super Moderator
you mean the one with cruise button? open the coin tray and remove the one screw on top. then the whole piece just yanks out.
__________________
www.lubecontrol.com
Member 1025782
Old 03-20-2009   #29 (permalink)
babzog
New Member
Cool, thank you. I hope to try this on the weekend. Hopefully it cures my buzzing woes.
Old 06-26-2009   #30 (permalink)
babzog
New Member
Well, procrastination (it was intermittent, after all) got the better of me and I put it off till tonight. LOL Changed out the pollen filters and then decided to get into the other side of the dash as well and yank that little box. I thought it would just slip off the mounting bracket but, no. After unbolting it and yanking the PCB, there were 4 solder points that looked cracked and another that looked like it was on its way to letting go. A bit of heat and some solder fixed it right up - no more buzzing! Thanks to everyone for a great tip!
Tags
06 , 08 , 98 , civic , drl , hiddrl , honda , light , mitsuba , module , moonroof , relay , running , rz0126 , si , wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
