Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
Reload this Page
DIY: Push Button Starter w/o S2000 button
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
LinkBack Thread Tools
Old 04-20-2006   #16 (permalink)
bOoStEd042dr
Diamond Member
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
that's pretty cool idea besides wasting alot of cash for the s2k button
bOoStEd042dr is offline   Reply With Quote
Old 04-20-2006   #17 (permalink)
diskreet
diskreet's Avatar
thats exactly why i did it the way I did!
diskreet is offline   Reply With Quote
Old 04-21-2006   #18 (permalink)
zachgeyer
zachgeyer's Avatar
nic diy
zachgeyer is offline   Reply With Quote
Old 04-21-2006   #19 (permalink)
jay78
Diamond Member
jay78's Avatar
jay78 is on a distinguished road
Quote:
Originally Posted by diskreet
you NEED the key in the ignition the way I have it, but you can get around the system with relays and crap... far more work than I have the time to do right now, especially since I do not have a remote starter and I dont want to start the car without the key!
Search this site and the12volt.com forums for more info though. You will get answers!
are car key has chip so i dont know putting more relays would work..
has any body else try this with remote starter.....putting key in the box ring around the ignition...see if it works ??? w/o having key in the ignition
jay78 is offline   Reply With Quote
Old 04-22-2006   #20 (permalink)
WhiteRabbit
Ultimate Member
WhiteRabbit's Avatar
WhiteRabbit should not be questionedWhiteRabbit should not be questionedWhiteRabbit should not be questionedWhiteRabbit should not be questionedWhiteRabbit should not be questioned
yes, I have done my own remote start using the DEI 555U transponder bypass, it works like a champ.
thats the other option to do this, by the way.
you cna purchase a cheap remote start for $60 or less. if its an addon, it will have a negative input used generally for alarms to activate the remote start.
to skip remote start and wire it to a pushbutton, you would merely wire the pushbutton to ground out the remote start activation, with a relay inline that fires with ACC, so you cant use the push button starter with out the key in the ignition.
you get a great deal more refinements in the system, too. albeit an order of magnitude greater cost!
WhiteRabbit is offline   Reply With Quote
Old 04-23-2006   #21 (permalink)
noooorb
Member
noooorb is an unknown quantity at this point
great post mate! real helpful
noooorb is offline   Reply With Quote
Old 05-11-2006   #22 (permalink)
realitycheck
Super Member
realitycheck's Avatar
realitycheck is an unknown quantity at this point
Diskreet, did you hook it up so that the button will not work once the car is cranked?
Is there a way to do this or probably not huh? J/W
realitycheck is offline   Reply With Quote
Old 05-11-2006   #23 (permalink)
diskreet
diskreet's Avatar
You could do it a few different ways. One way is with a latch so that the thing would only work once and when the car is off it resets.
You can probably do it with relays alone.
There are many ways, but They can get really complex and time consuming and even expensive, so I didn't do it.
Old 05-11-2006   #24 (permalink)
realitycheck
Super Member
I was only concerned cause I have an ex so I have sunroof all that. So i'd have to put my button on the center cigarette lighter panel. So I didnt want people pushing while I was riding down the road, going whats this for?
Old 05-11-2006   #25 (permalink)
diskreet
diskreet's Avatar
HAHA I'm on my second starter already so that would NOT be good! I would kill anyone who would touch it. My first one just was bad so it was replaced under warranty no problems.
Anyway you can do it, if you really want to. I may look into redoing it safer, later, but not for a while (weeks).
Old 05-11-2006   #26 (permalink)
realitycheck
Super Member
One last question is that switch made to work with that much amp draw?
And if I figure out how to wire it up so that it doesnt work once the engine is running you want me to pm you?
Old 05-11-2006   #27 (permalink)
diskreet
diskreet's Avatar
Switch doesnt have more than 100mA running through it. The relay is sucking up 20-40 amps.
sure!
Old 05-11-2006   #28 (permalink)
Shifty
Ultimate Member
Shifty's Avatar
suscribed!
Shifty is offline   Reply With Quote
Old 05-11-2006   #29 (permalink)
WhiteRabbit
Ultimate Member
purchase an aftermarket remote start. they arent too expensive. when you get one designed to be an add-on to an alarm, its triggered by a voltage pulse, which you will provide via switch
after that, you simply add what interlocks you want between the starter and your switch. whether the door needs to be closed, the key in or not, etc etc etc.
Old 05-11-2006   #30 (permalink)
realitycheck
Super Member
Wow whiterabbit I didnt know you could do all that with the alarm. Thanks for the info bud man i've got alot to learn.
I found a little loophole to our probem though. I have a manual so I read something on here and I tried it when I left work. Since I have a five speed you have to push in the clutch to crank the car. So once the car was running I left it in neutral turned over the key and nothing happened. So unless they push the button right when I change gears I wont have any problems. So theres a little tiny bit of info for you guys.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Push Button Starter ??? VTECnique Honda Civic DIYs and Civic Tech Chat 18 03-27-2007 11:56 AM
DIY for s2000 push button starter kit? Spoolin Honda Civic DIYs and Civic Tech Chat 11 03-15-2006 07:23 PM
Push button starter gringo62 Honda Civic DIYs and Civic Tech Chat 2 05-27-2004 12:08 PM
DIY on cigar lighter s2000 button starter iginition. Got Vid:) iluvbritney Honda Civic Member's Rides 22 04-30-2004 08:46 PM
Push Button Starter ivonesh Other Honda Civic Parts and Products 8 02-27-2002 10:49 PM
User Login
Our Partners
used new
Top 10 Threads
DIY: Amp Wiring 2k1civic coupe
DIY: Head unit install
Sound Deadening DIY
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
MTX Jackhammer! Don't they know when to draw the line?
DIY: Custom Trunk II !with access to spare tire!
*** The big I.C.E. & Electrical sticky (DIY's, links, POSTING GUIDELINES, more) ***
HID in TYC setup. With no projector conversion. Video on pg 17.
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
