Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
Reload this Page
fuse problem
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
LinkBack Thread Tools
Old 03-02-2006   #1 (permalink)
shmik1
shmik1's Avatar
fuse problem
so I get in my car and turn on my music and it starts for 3 seconds then stops...WTF? I knew right away both amps werent working, deck was 'fine,' so when i got home I checked over the remote wiring etc, then I tested my power wire just to be sure, well it was dead.
more testing, then i find the fuse isnt working, its not blown. just doesnt work.
swap fuses, problem fixed...
so my question is, what was wrong with the fuse, it has some white junk on it (inside on the metal piece) it looks like glue, couldn't say for sure if it was there before or for how long, but a new fuse works fine and heres a pic if u can see it.. hard to get a fuse pic...
if anyone knows what happened with this fuse, or why... let me know please.
fyi: fuse was used for atleast 2years and the car has been outside almost its entire life in IL weather. so anything from 90+ heat in the summer to negative temps in the winter. and sometimes weird temperature changes... 30+ degree changes within 12-24hours.
maybe this is a weather thing?
shmik1 is offline   Reply With Quote
Sponsored Links
Old 03-02-2006   #2 (permalink)
EM2 Shinobi
Senior Member
EM2 Shinobi's Avatar
EM2 Shinobi is an unknown quantity at this point
the air tight seal prolly became not air tight and the contacts oxidised
EM2 Shinobi is offline   Reply With Quote
Old 03-02-2006   #3 (permalink)
grenloch101056
Diamond Member
grenloch101056 is an unknown quantity at this point
thats one of the downsides of ANL fuses. the fusible link could look fine but it'll still break the circuit. only way to test for sure is to test for continuity
grenloch101056 is offline   Reply With Quote
Old 03-03-2006   #4 (permalink)
shmik1
shmik1's Avatar
Quote:
ok i figured it was just something to do w/ it just getting old, which is good. atleast its not a real problem.
i just used a cheapy light up tester, did the trick for me.
thanks guys!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
fuse problem? gh0st Lighting 4 05-27-2005 11:50 AM
Fuse Problem ? jdm_bb Honda Civic DIYs and Civic Tech Chat 0 05-18-2004 11:17 AM
Fuse problem!!! sadboy916 I.C.E. & Electrical 34 02-09-2004 10:49 PM
Fuse problem player I.C.E. & Electrical 1 12-09-2003 11:19 PM
WHICH FUSE??? whitey I.C.E. & Electrical 5 04-08-2002 11:38 PM
User Login
Our Partners
used new
Top 10 Threads
DIY: Amp Wiring 2k1civic coupe
DIY: Head unit install
Sound Deadening DIY
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
MTX Jackhammer! Don't they know when to draw the line?
DIY: Custom Trunk II !with access to spare tire!
*** The big I.C.E. & Electrical sticky (DIY's, links, POSTING GUIDELINES, more) ***
HID in TYC setup. With no projector conversion. Video on pg 17.
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
