Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
Reload this Page
Best way to install Sirius into '05 Civic EX w/ OEM 6 Disc?
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
LinkBack Thread Tools
Old 12-13-2005   #1 (permalink)
2005CivicCPEXSE
New Member
2005CivicCPEXSE is an unknown quantity at this point
I apologize for starting a new thread, thought maybe I'd get more responses from an apropriate title.
I have the 2005 special edition 6 Disc OEM HU with the AUX jack in the front. I just bought the portable sirius sportser with the suction cup mount...what is the best way to install this for sound quality and to make the install look as clean as possible? I want to avoid any exposed wires if possible, and I will already have the dash apart to install other components. I have a friend who tells me to use an inline FM modulator, while reading on here it appears this causes some feedback of sorts. I've also read to use a PIE adapter or something similar. What the heck is that? Lastly, is it possible to hard wire the power to the 12 volt socket so I can still use it to charge my cell at the same time as listening to sirius? Thanks again everyone.
one other thing...has anyone found somewhere cool to mount it other than the dash?
2005CivicCPEXSE is offline   Reply With Quote
Sponsored Links
Old 12-13-2005   #2 (permalink)
MegaHurtz
MegaHurtz's Avatar
If that's the unit I think it is, there is an FM modulator already built in. Is it the ST1?
If you are looking for the best sound quality though, FM modulators are NOT the way to go, they sound heinous. Best way would be to run a wire from the unit into your aux jack.
Where did you buy your Sirius tuner and where are you from?
MegaHurtz is offline   Reply With Quote
Old 12-13-2005   #3 (permalink)
2005CivicCPEXSE
New Member
It is the SIR-STRC1. I bought it online, and recently moved to Virginia. I know it already has a modulator, but I was going to put an inline one behind my console that would block other signals and hopefully boosting the signal so it wouldn't sound too bad. I'd sacrifice a little (but not a lot) of sound quality so I wouldn't have to see that wire plugged into the front of my HU. Is there anything I can do to plug it into the back, or is that just wishful thinking? Any creative idea's as to where to mount it would be appreciated as well, I don't plan on taking it out of the car so it could be permanent.
Old 12-13-2005   #4 (permalink)
MegaHurtz
MegaHurtz's Avatar
It will sound just as bad with an inline module, the one built in will be as good as any
Old 12-13-2005   #5 (permalink)
2005CivicCPEXSE
New Member
Anyone know of a way to plug it in directly without having wires in the front?
Old 12-13-2005   #6 (permalink)
MegaHurtz
MegaHurtz's Avatar
no not unless you solder wires to your head unit and put an aux in in the back
Old 12-13-2005   #7 (permalink)
05reverb
Super Member
05reverb's Avatar
05reverb is an unknown quantity at this point
if i were you, i'd take out the HU, openen it up, and solder the wires from the output of the sirrus receiver right to where the aux jack is inside the HU (so there would be no wires at all in front of the HU, just the wire going from the receiver to the back of the HU), but that's just me, i know alot of people would not be comfortable doing that, but if your installer wants to do it. Anyways, i never used a fm modulater, so can't really tell if it sounds that bad, but alot of people say it sounds like s**t. If your not too fussy about the quality of the music, I'd say you'd be fine with the modulater. If you want to solder in the HU, you could solder the wire inside the HUthen run it to the blank panels that is next to the lighter, then install a minijack there in the panel, so then you would just need a wire with 2 male ends to go from that minijack, to the one on your receiver.
05reverb is offline   Reply With Quote
Old 12-13-2005   #8 (permalink)
thefivespeeder
Super Member
thefivespeeder's Avatar
thefivespeeder has a spectacular aura aboutthefivespeeder has a spectacular aura about
Just so you know I've had people return the sportster replays because they are on recall, the screen short out or something.
Don't cut the power adapter and hardwire it in because, the inverter is built into the plug, it operates on 5volts. At BestBuy we install another power socket behind the dash, usually tapped off an ignition feed.
Is the factory radio SAT radio ready?
thefivespeeder is offline   Reply With Quote
Old 12-13-2005   #9 (permalink)
05reverb
Super Member
05reverb's Avatar
Quote:
Originally Posted by thefivespeeder
.....Don't cut the power adapter and hardwire it in because, the inverter is built into the plug, it operates on 5volts. At BestBuy we install another power socket behind the dash, usually tapped off an ignition feed.
i'm not talking about the power adapter, i'm talking about the minijack audio output on the sirius receiver (not sure how it's made, never saw the receiver, but should have one, right?). you could plug a minijack into the sirius receiver to send your audio to the back of the HU. Not sure what you mean, that the 5 volts is with the audio output? please explain more.
Old 12-13-2005   #10 (permalink)
2005CivicCPEXSE
New Member
I'm almost positive it is not SAT ready. Looks like I'll be deciding between plugging it in to the front and an inline FM mod. Thanks everyone for your replies, just need to find a good place to mount it.
Old 12-13-2005   #11 (permalink)
MegaHurtz
MegaHurtz's Avatar
You're wasting time and money if you install an inline FM mod, just warning you.
Old 12-13-2005   #12 (permalink)
grenloch101056
Diamond Member
grenloch101056 is an unknown quantity at this point
Quote:
I have to disagree with that, with howard stern coming on soon I get to install about 8 sirus tuners a day, mostly the replays and the starmates.
Both of these units operate off of 12 volts, so its no problem cutting off the power adapter and hardwiring it, just make sure to fuse it. The xm units operate off of 5 volts so there the ones that need to be hardwired with a female cig. lighter.
The internal fm transmitter is garbage, the pigtail that's included does absolutly nothing and belongs in the The inline fm modulator that sirus sells does quite a good job on most cars, granted its not as good of a solution as using the minijack output on the back of the dock to connect to an aux in. Usually the XM FM direct modulators work a bit better than the sirus fm modulators, dont know why or how, but our bay was out of the sirus ones and we had to use an xm one.
grenloch101056 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
F/S 2005 Civic EX SE Radio ( 6 Disc ) In Dash OEM AlpJLFan Honda Civic Parts for Sale 21 03-15-2008 12:42 AM
WTB: OEM In-dash, 6-disc changer for 7th Gen Civic Ex holokaustos Honda Civic Parts Wanted 4 12-13-2005 05:27 PM
Remote Control for OEM 6-Disc HU. I FuSe I I.C.E. & Electrical 1 02-01-2005 02:15 PM
OEM 6 disc indash 2k1sscivic I.C.E. & Electrical 2 12-26-2002 09:33 PM
Is there a OEM alarm install on the 2001 civic EX coupe? SuperCivic2k1 Other Honda Civic Parts and Products 6 01-28-2002 08:42 AM
User Login
Our Partners
used new
Top 10 Threads
DIY: Amp Wiring 2k1civic coupe
DIY: Head unit install
Sound Deadening DIY
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
MTX Jackhammer! Don't they know when to draw the line?
DIY: Custom Trunk II !with access to spare tire!
*** The big I.C.E. & Electrical sticky (DIY's, links, POSTING GUIDELINES, more) ***
HID in TYC setup. With no projector conversion. Video on pg 17.
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
