Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-22-2005   #1 (permalink)
TyroneShoelaces
New Member
TyroneShoelaces is an unknown quantity at this point
Question Lights dimming from this setup?!
I recently replaced my stock deck with a Pioneer DEH-4600MP, left the stock speakers intact, and put my 11 year old profile 250W x 2 Amp with an 11 year old kenwood box containing 2 x 10" subs, 2 mids and 2 tweets.
The stuff is very very old, but still sounds ok for now.
However, if I turn it up fairly loud, everything dims when the subs hit.
I don't think this old hunk of junk amp should be pulling enough power to cause this to happen.
The car is an 04 Civic Special Edition.
A few weeks after I purchased the car from the dealer it started making a strange vibrating whining noise whenever I came to a stop and it was idling.
The guys at the honda dealer said they weren't sure where it was coming from and replaced the power steering pump. The noise went away for a day or so, but I think it was probably just a coincidence. The noise came back the next day and is noticeable whenever I am sitting at an idle.
After putting in this new deck and noticing the lights dim, I'm thinking perhaps the noise is the alternator.... I don't know much about full size cars, being more of an RC junkie, am I on the right track here? Should I take it back and get them to check the alternator, or is it normal for my lights to dim like this in this car? My old car never had this problem with a virtually identical stereo setup.
TyroneShoelaces is offline   Reply With Quote
Sponsored Links
Old 09-22-2005   #2 (permalink)
PopcornPlaya
Electric Boogaloo...
PopcornPlaya's Avatar
PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold
It depends on the amp draw of the amp honeslty. I've had 1000 watt plus setups not cause any noticable dimming in my civic when I had it, but I put a different amp in there that was power hungry and significantly less wattage yet the lights dimmed. I'd still get them to double check everything just to be safe. From there, you might want to try upgrading the big 3 wires, putting a better battery, maybe a higher output alternator (I'd do this last) or you may want to try a cap. I don't like caps, but in some instances they help with dimming issues.
__________________
"Can you imagine what it feels like to have someone sit you down and tell you that you're dying? The gravity of that, hmm? Then the clock's ticking for you. In a split second your awe is cracked open. You look at things differently - smell things differently..... But most people have the luxury of not knowing when that clock's going to go off. And the irony of it is that that keeps them from really living their life. It keeps them drinking that glass of water but never really tasting it."
PopcornPlaya is offline   Reply With Quote
Old 09-24-2005   #3 (permalink)
TyroneShoelaces
New Member
Guess I'll take it in to have the alternator checked.... Turning the AC on before I installed this deck had the same effect, noticeable drop in RPM and lights dimming.
On a side note, I have some SPL55g 5.25" speakers collecting dust here, is it possible to mount them in the front doors, or do I have to buy new 6.5" ones?
Old 09-28-2005   #4 (permalink)
2k1_Stockie
Member
2k1_Stockie's Avatar
2k1_Stockie is an unknown quantity at this point
Send a message via AIM to 2k1_Stockie
I believe the front doors were suppose to be fitted with 5.25's but i shoved 6.5"s in my 2001 Civic Sedan if this helps...
2k1_Stockie is offline   Reply With Quote
Old 09-28-2005   #5 (permalink)
jeffsta17
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
Send a message via AIM to jeffsta17
its made for 6.5"s but with some work anything will fit
__________________
http://www.civicforums.com/forums/19...-oem-tail.html
BUY MY STUFF PART OUT SALE!!!!^^^^^
I wish my grass was emo, that way it would cut itself...
Currently looking for blinker fluid of the right viscosity...PM me if you find some
jeffsta17 is offline   Reply With Quote
Old 09-28-2005   #6 (permalink)
WhiteRabbit
Ultimate Member
WhiteRabbit's Avatar
WhiteRabbit should not be questioned WhiteRabbit should not be questioned WhiteRabbit should not be questioned WhiteRabbit should not be questioned WhiteRabbit should not be questioned
Send a message via AIM to WhiteRabbit
what size power wire are you using to go from your battery to the profile amplifier?
WhiteRabbit is offline   Reply With Quote
Old 09-28-2005   #7 (permalink)
ruckerheadz
New Member
ruckerheadz is an unknown quantity at this point
upgrade the amps ground and alternator. if the lights still dim upgrade to a bigger cca battery, dont waste ur money on a cap. they will help stop the dimming but they also drop the voltage tot eh amp which means it will be weaker making the sound quiter. so double check ur grounds and upgrade if u need to with the power ur runnin 4gauge wire will be fine but if u plan to upgrade in the future bigger will work and will be less work in the future. also a bigger battery will help the alternator from whining cause it cant keep up with the ampers bein drawn. so bigger battery perferablly over 1200cca and bigger ground that are directly on the frame not the seat belt things or lil pieces of metal in the trunk, frame only. depending on the class of amp a good way to know the current it draws is the fuses on the amp, alot of cheaper amps claim 1000watt but only have 60amp fuse, but theres class ab amps that draw alot more but in return they have better sound.
ruckerheadz is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
with this combo kill my alt....? pyrofoam I.C.E. & Electrical 21 03-17-2005 11:58 PM
when the bass hits.... civic4dizoor I.C.E. & Electrical 18 01-21-2004 03:31 AM
power needs... Cypher I.C.E. & Electrical 8 11-21-2002 05:40 PM
short term effects of 1860 RMS on stock electricals WhiteRabbit I.C.E. & Electrical 24 11-05-2002 02:20 PM
Opinions on which capacitor is better????? noahnoah I.C.E. & Electrical 24 07-21-2002 07:47 AM
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
