Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-25-2005   #16 (permalink)
PopcornPlaya
Electric Boogaloo...
PopcornPlaya's Avatar
PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold
Quote:
Originally Posted by jackburton
yeah rms, never max power. Dimming of the head lights is not the only reason, a cap allows the subs to hit harder, and does not strain your battery an alt as much, if its not too big.
No, caps do not make the sub hit harder. That's a well circulated internet myth. Capacitors can possibly effect dimming, that's their only use, period. Can you guarantee they will do anything? Nope, absoloutely not. If someone tells you that they'll make your bass better, kick them square in teh jimmy and tell them to shut up. If they tell you they can gurantee an effect, kick them in the nuts again, because they can't tell you how they'll effect your charging system. Caps store power, and supply it to the amp at voltage spikes (when the amp/draw is asking for more than teh battery/alternator can supply). This causes dimming. The caps provide the surge of power, even if for a breif second to supply your electrical with that surge, or at least attempts to. Still, there is never a consistent effect. Some people have great results with them, some have no results with them. My advice, big 3 wires, then battery, then alternator. If that doesn't fix it, I'd try adding a second battery, colser to the amp, and isolated from the one supplying teh motor. Then, after all this, I'd possibly try a cap. I'd never advocate using one, as they never increase voltage, again that's a circulated myth, and they don't increase bass response. Anyone that tells you they do is doing one of several things: 1. Trying to sell you something you don't need. 2. Believing marketing ploys of manufacturers. 3. Circulating and buying into the lies and hype circulated on internet forums. I could go on...
__________________
"Can you imagine what it feels like to have someone sit you down and tell you that you're dying? The gravity of that, hmm? Then the clock's ticking for you. In a split second your awe is cracked open. You look at things differently - smell things differently..... But most people have the luxury of not knowing when that clock's going to go off. And the irony of it is that that keeps them from really living their life. It keeps them drinking that glass of water but never really tasting it."
PopcornPlaya is offline   Reply With Quote
Sponsored Links
Old 08-26-2005   #17 (permalink)
jackburton
Diamond Member
jackburton will become famous soon enough jackburton will become famous soon enough
If the cap supplies power when the battery cannot, then with out the cap, the subs are not gettin as much power, even if its only brief, it still will get more power to your subs, thus making them louder. Caps definitely take a little strain off the electrical system. An upgraded battery will prob do more than a cap, but they are both useful.
__________________
Have you paid your dues jack?
The check is in the mail
jackburton is offline   Reply With Quote
Old 08-26-2005   #18 (permalink)
PopcornPlaya
I'll be willing to bet you $100, on a mic that if you add a cap you will not see an increase in SPL. You're not very educated about capacitors are you? Search for capacitors, there's a therad here I posted a long time ago that'll teach you a thing or 12 about them. By the way, the bet above would be easy money, so I'm not going to rip you off like that. Caps are never guranteed to be useful, and that's teh problem. They have adverse effects as many times as they have positive effects. Fact of the matter is caps only help dimming. Nothing more, nothing less. They don't increase voltage and they don't keep voltage steady at 14.4 v and they don't increase SPL numbers. That's a myth.
__________________
Old 08-26-2005   #19 (permalink)
Mystic3030
Yup, i'm an A$$hole.
Mystic3030 has a spectacular aura about Mystic3030 has a spectacular aura about
Send a message via AIM to Mystic3030 Send a message via Yahoo to Mystic3030
Caps are an added strain, its one more thing that has to be charged. The time it takes a cap to discharge is counted in fractions of a second, so it is literally impossible for it to have an affect on the voltage/volume of the system. All they do is have a slight potential to reduce dimming.
Mystic3030 is offline   Reply With Quote
Old 08-26-2005   #20 (permalink)
jackburton
Diamond Member
I still dont get how it can help with dimming and not power to the sub, it just dont make sense????
__________________
Old 08-29-2005   #21 (permalink)
hdave
Super Member
hdave is an unknown quantity at this point
Send a message via MSN to hdave
theres so much ppl talking crazyness here.
a cap wont save your alt or battery or anything.
it doesnt serve any purpose at all except it reduces NOTICABLE dimming.
the first think you guys should do is the big 3 wiring upgrade.
second could be upgrade to a deep cycle battery.
third is a H/O alt.
cap is just a complete waste of money IMO.
hdave is offline   Reply With Quote
Old 08-29-2005   #22 (permalink)
hdave
Super Member
listen to popcornplaya and mystic3030.
they know what they are talking about in regards to car audio.
Old 08-29-2005   #23 (permalink)
ihjoon
New Member
ihjoon is an unknown quantity at this point
Send a message via AIM to ihjoon
u know what, unless you have a HARD CORE class D amp, for your SUB or subs, you don't need a new alternator or a cap. if you have a decent sub amplifier, than i'd suggest a cap, a cap does put out better bass,
like me, i have a JL 12w7 with the 1000/1. mines on the lowest setting, and it's still draining power like a bitch. even with a cap. a cap is just temporary power. a new optima battery will provide a longer steady power. but a alternator will just make it so you just need the alternator. unless you don't put 1000+ dollars in to ur sub//amp i'd highly doubt you need an alternator. a cap, i'd suggest.
ihjoon is offline   Reply With Quote
Old 08-29-2005   #24 (permalink)
PopcornPlaya
Caps don't put out better bass, period.
__________________
Old 08-29-2005   #25 (permalink)
jackburton
Diamond Member
Okay i have done some research and this is one of the most highly debated topics whne it comes to car audio if not the most.
"The only reason a capacitor prevents lights from dimming is by smoothing out the voltage rails. those rails will still be sagging though if the alternator can't keep up. this just emans you'll have non dimming lights getting about 10 to 11 volts instead of the 12 to 15 they should."
READ THESE:
http://pub14.ezboard.com/fcaraudiota...picID=10.topic
http://pub14.ezboard.com/fcaraudiota...picID=23.topic
There are still come discrepencies, but bottomline caps are useful for more than dimming lights.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
with this combo kill my alt....? pyrofoam I.C.E. & Electrical 21 03-17-2005 11:58 PM
Aem Pulleys civiclx4dr Other Honda Civic Parts and Products 33 09-12-2004 01:19 PM
Alternator? Goatboy Honda Civic DIYs and Civic Tech Chat 2 01-14-2003 09:05 AM
I hope someone can help me with this question? Rollin0n18s I.C.E. & Electrical 5 12-23-2002 02:53 AM
ohio generator bake I.C.E. & Electrical 2 05-18-2002 05:47 PM
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
