| Just wondering, who EVER said stock front speaker is 6.5"?
6.5" speaker will FIT front door hole but does not FUNCTION properly...Stock speaker is roughly 155mm, meaning it's roughly a 6" speaker. The stock speaker is also built on (embedded) spacer, if I remember it, it is about 1" height by 6" diameter spacer...If you use at least 0.75"x6" spacer and 6" speaker, it will bring the speaker almost to the surface of the PLASTIC door panel.....If you don't use spacer, or put 6.5"+ speaker in it, 2 things might happen.
1. The rubber surround might hit the plastic door trim ring, causing distortion
2. The outer area of speaker (greater than the door trim ring) will fire midbass directly to the plastic panel, causing tons of resonance, cancellations, etc..... |
