amp problem
Old Aug 16, 2005
kronickz's Avatar
kronickz is an unknown quantity at this point
amp problem
i need help with my system. everytime i turn my on my cd player, the amp powers on but when i turn the volume up, it goes into protection and won't let the speakers hit. I was wondering if my amp is blown or is it not getting enough power? let me know. Thanks.
Old Aug 16, 2005
05civicexse's Avatar
05civicexse is an unknown quantity at this point
does it work when volume is lower?? explain the problem better i know car audio fairly well. or im me on HowBoutThemApplz
Old Aug 16, 2005
robbclark1's Avatar
Retired suspension supermod.
please post in the right forum. Not everything goes in GAR. Thank you.
Old Aug 16, 2005
shut up ***
Old Aug 16, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
Originally Posted by 05civicexse
shut up ***
Protection mode can mean so many things. Bad wiring, bad amp, and a bunch of other things... please give more detailed info
Old Aug 16, 2005
robbclark1's Avatar
shut up ***
Obviously, you need chill out. Nothing was directed toward you and I was just doing my job as a moderator.
Old Aug 16, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
^yeah damn man chill out LOL.
It could be alot like whats his name said.
I would check your ground, make sure surface is sanded and its part of or welded to chassis. That is all i am going to tell you cause people need to do some searching. Try google there should be sites which list problems with solutions. We should write up a sticky, but i guess everybody is blazed and lazed out, like me.
Old Aug 16, 2005
MegaHurtz's Avatar
shut up ***
locked. learn to have some respect for the mods.
roverben
Jan 21, 2019 05:16 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
jackoncruzpr
May 24, 2015 12:24 AM
0100010
Dec 1, 2001 03:27 PM
PimpBot5000
Nov 26, 2001 07:15 PM
