Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-22-2005   #1 (permalink)
diskreet
diskreet's Avatar
diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold
DIY: Custom Trunk II !with access to spare tire!
I did this cause I wanted a sexy, functional trunk, that allowed EASY access to my spare tire. Hope this gets stickied and added to DIY section!
Warning: There is alot of reading here, so I hope it is more in-depth than you need. Don't think i'm talking down to you, I just want to make this as easy to understand as possible. Hope you guys like.
Part I
Suplies Needed:
  • Large uncut piece of MDF, or other strong wood. If buying MDF get 1/2" or 3/4". I used 3/4".
  • Carpeting (Link to carpeting I used, from crutchfield.com )
  • 3M Super 77 spray adhesive, or comprable adhesive (worked well for this kind of carpeting)
  • Wire, Wire, more Wire. Power, Ground, Signal, Amp turn-on, etc.
  • Wire management (distribution block(s), etc)
  • Wire ends!!!! Get em!
  • Zip Ties
  • my email address: diskreet(at)gmail.com
  • Many, many screws. Like 10+ wood scerws, and 5+ metal screws. More is better!
  • Set of hinges. 4 or 6 screw hinges from lowes for like $5 will do.
  • L brackets, from lowes. small 4 screw ones are fine. About $5.
  • Handle, also about $5 at lowes. MAKE SURE THE SCREWS ARE ABOUT 1" LONG!!!
Tools Needed:
  • Screwdrivers, all kinds. More is better here also
  • Cordless Drill
  • Batteries for drill
  • Pliers
  • Jig saw
  • Circular saw
  • Horses
  • Flashlight
  • Zip Ties
  • Safety Goggles
  • SHARP razor
  • Shears for carpet
  • pens, markers, paper for designing and sketching
  • other stuff I am forgetting!
  • Dremel
Remove everything from trunk; including the plasic piece surrounding the latch hook, the carpeting, the floor, the spare and tools, and the carpeting on the sides. Keep all screws and mounting hardware from the removal.
Take the Carpet that covered the floor board before. Place it over your MDF and trace the edge of the carpet onto your MDF. Leave a few inches of clearence on each of the 3 sides and the 4th should be about 1/2 in the large piece of wood you have.
UPDATE: Here is a pic with the sizes I used (all measurements are rounded to the nearest 1/2". I also measured these after putting the carpet on! Yours may be a bit smaller:
Using the circular saw, cut off the other like 1/2 of the MDF which you will not need. This is the part with nothing stenciled on it. If you dont understand me here I dont think you need to go any firther with this project.
Now that you have a more managable piece of wood with less edge space, get out the Jig Saw.
Saw the odd little shape out, taking your time with each bend. If you cut a little off its perfectly OK! When you carpet over you will not see the mess-ups, but try to sand/dremel and edges to something smooth. Especially where the wood chips off, which it will.
Test fit the cut out MDF you have now, it should somewhat fit in there well.
Put the side carpeting back on (vertical, with lips touching the floor of trunk) and put the wood back in. Because of the lip of this stiff carpet type stuff, it will not fit perfectly, but thats ok. thats what the razor is for later.
Mark lines on each side of the wood to get something like this shape here:
Make sure that the pieces you cut will be supported on each side by the floor! We dont want you making the middle too skinny and falling in!!!!
I recommend 33" wide in a sedan trunk!
Obviously get out the circular saw and cut these pieces out.
Test fit again, this time with the spare tire in its place!
Put sub box in this time. Make a line a few inches in front of box, but make sure if you cut there that you will have enough room to get the spare out with only the front piece open!
Remove, and cut on that line. Now test fit one more time to make sure!
One last piece to cut, if you want it like mine. Measure from the top of the MDF floor you created in the side corner right in front of the tail light to the top of the trunk interior. measure the rough width of the area you are working in. With a 3/4" MDF floor I used a piece 14 1/2" x 18" in my sedan.
Ok so take it out, its time to carpet!
To carpet place one piece of wood at a time over the carpet. Cut out the piece with about 1 1/2" - 2" extra all around. I recommend getting all pieces cut first then carpeting.
Spray the Carpet and wood with a medium coat of adhesive. let get tacky for about 1-2 mins. Spray again then apply the carpet. make sure you pull tight over the whole piece and smooth on so you dont get bubbles and wrinkles.
If you have tight corners cut a slit in the carpet and cut excess so it doesnt fold on itself. any parts that lift just spray over and push hard, keeping pressure until it is set.
Let set for a while - 15 mins+.
Now lets get the handle on. Cut some carpeting away in that area and drill 2 holes just big enough to get the handle screws in. Rest is self explanitory.
Now lets get the razor out for some fun. Too bad I dont have any good pics for this. Pretty much just put the wood back into place in the trunk, with all carpeting and trim in place. Using the razor cut any spots of carpet that prevent the MDF floor you made from lieing flat. Usually any place the carpeting sidewall stuff curves horizontally to touch the floor cut it off. Now everything sits very level.
Now take the 2 middle piece out and install the hinges. Drill + screws + common sense = finished installing hinges. You may want to drill countersunk pilot holes before carpeting but good luck finding them later.
Put the spare back in now, and the tools if you want, since the wood is staying in place now.
Run all wires you the side now, behind the carpeting stuff that makes the "sides" of the trunk. Dont cut anything yet...
Put the box in now, using L brackets to secure it. I nice trick is mock-mount everything and mark the edge of the L brackets, seating them under the box like I did. Now take the box out. Keep the L brackets in place and screw them in using screws and the drill.
After that you want to put the box back in and screw in to the L brackets. The reason we did this is so you dont have the bottom of the L bracket sticking out, the box is actually sitting ON it! Good idea eh?
So we are down to the home stretch; the amplifier (and possibly capacitor too.)
Mock fit the wood into place. What we want to do it first take the carpeted wood piece we cut earlier and make sure your amp fits well on it. If so we are ready to proceed.
Cut a nice complete slit in the carpeting on the wall, so we can place this new piece we made behind it. You can drill holes in the carpet to run wires through to the front or just cut it and glue it to our board later on like I did. Either way works, but Maybe the way I didn't do it will look cleaner.
This is the hard part: The way I mounted the board is slightly tricky. 2 L brackets on the bottom are no problem, but the top is another story. With the board in place the very top should be resting on a large metal tab of the inner trunk frame usually hidden behind the carpet. You need to get a screw through the wood and the metal to secure this in. It took me many many tries to get it in the metal and a burn or two but if you have a helper hold the wood firmly into place you are set! Once mounted plug in the amp and mount (screw) it on.
Like in the pic you want to get everything routed nicely. Spray carpet adhesive and trim as necessary to get the carpet into place over the piece we made that the amp is mounted on.
If you want the amp lit like mine replace your bulb with an LED bulb from LEDautomotive.com cause it shies right over in that direction.
Night Shot:
Clean up and enjoy!!!
Part II
Here is how you can secure your tools and your spare tire for $5
Parts needed:
  • Hard foam block (Wal*Mart sells them for under $5)
  • Marker
  • X-acto knife
  • Optional: Drill with hole cutting bits (for spare lug nuts)
Make sure the foam fits in the trunk under the wood floor. If not, cut it down to size.
Lay everything out on top of the foam and figure where you want it. When you have it all in place, outline everything with the marker.
Remove everything from the foam.
Use the knife to cut along the lines you drew on the foam.
Put the knife in a slit you cut and turn it. It should take out the foam in chunks.
If you carry anything round (fuses, lug nuts, wheel lock key, etc) use a drill to drill out holes, a little smaller than the object, about 1/2 way down the foam.
When you have the foam with all the little channels for the tools, test fit everything. Make some adjustments as necessary.
When you are finished you will have this:
To keep it in place put a sponge between the foam and the spare tire. It will all stay in place perfectly. Enjoy!
diskreet is offline   Reply With Quote
Sponsored Links
Old 06-22-2005   #2 (permalink)
tuner04civic
spell check pwns you
tuner04civic's Avatar
tuner04civic has much to be proud of tuner04civic has much to be proud of tuner04civic has much to be proud of tuner04civic has much to be proud of tuner04civic has much to be proud of tuner04civic has much to be proud of tuner04civic has much to be proud of tuner04civic has much to be proud of tuner04civic has much to be proud of tuner04civic has much to be proud of tuner04civic has much to be proud of
Send a message via AIM to tuner04civic
nice job...looks good
tuner04civic is offline   Reply With Quote
Old 06-22-2005   #3 (permalink)
AggressiveAdam
Platinum Member
AggressiveAdam's Avatar
AggressiveAdam is on a distinguished road
good job, clean!
AggressiveAdam is offline   Reply With Quote
Old 06-22-2005   #4 (permalink)
boombazokajoe91
I survived that B*tch Katrina !!!
boombazokajoe91's Avatar
boombazokajoe91 is an unknown quantity at this point
Send a message via AIM to boombazokajoe91
very nice job...
__________________
http://www.7thgencivic.com/forums/at...chmentid=57406 rep me and ill rep you back ....
boombazokajoe91 is offline   Reply With Quote
Old 06-22-2005   #5 (permalink)
diskreet
diskreet's Avatar
thanks guys. Anyone who reads through and sees something unclear or whatever just ask or pm or email me! I did this to help out as many people as possible.
Old 06-22-2005   #6 (permalink)
booba5185
7thgen Terminator Ninja
booba5185's Avatar
booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold
Send a message via AIM to booba5185 Send a message via Yahoo to booba5185
did u make the actual box?
__________________
I am the South West CLIT Commander
Quote:
Originally Posted by My Father
A friend bails you out of jail, a best friend is sitting next to you in jail saying, "She didn't look like no cop did she?"
Sportin the DX with the high performance piston return springs, are you?
http://www.cnw.com/~seagull/public_h...y%20ninja1.gif Ninja #9 of the 7thgen Ninja Clan http://www.cnw.com/~seagull/public_h...y%20ninja1.gif
booba5185 is offline   Reply With Quote
Old 06-22-2005   #7 (permalink)
hookitup34
Senior Member
hookitup34's Avatar
hookitup34 is an unknown quantity at this point
i like the looks of that alot
hookitup34 is offline   Reply With Quote
Old 06-22-2005   #8 (permalink)
MegaHurtz
MegaHurtz's Avatar
MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of
Send a message via AIM to MegaHurtz Send a message via MSN to MegaHurtz
looks awesome dude, I wonder where I've seen it before? oh thaaaat's right, it was in my trunk when I did almost the same thing last year
just buggin it really does look good, I'm glad I could be used for inspiration
__________________
Proud member of West Coast Extreme SPL
Come to the Mid-A meet 2007! This could be you!
MegaHurtz is offline   Reply With Quote
Old 06-22-2005   #9 (permalink)
Ashhole
Ashho-san 7thgen Ninja
Ashhole will become famous soon enough Ashhole will become famous soon enough
Send a message via ICQ to Ashhole Send a message via AIM to Ashhole Send a message via Yahoo to Ashhole
hell ya thx for hte DIY. looks like i got a project coming up. my spare is totally in accessible wiht my box back there
__________________
1/4: 16.659
@: 82.61 mph
7th Gen Ninja #19
My Myspace
My Cardomain
DIY: Blacked out Altezza Tail lights
7thGen.MT.C.
Ashhole is offline   Reply With Quote
Old 06-22-2005   #10 (permalink)
vccivic
Not a Noob, Had to reregister
vccivic's Avatar
vccivic is an unknown quantity at this point
Looks good. Has anyone tried or thought of putting the hinges on the bottom so they are hidden.
vccivic is offline   Reply With Quote
Old 06-22-2005   #11 (permalink)
speedricerx
Platinum Member
speedricerx's Avatar
speedricerx is a glorious beacon of light speedricerx is a glorious beacon of light speedricerx is a glorious beacon of light speedricerx is a glorious beacon of light speedricerx is a glorious beacon of light speedricerx is a glorious beacon of light
do u just slide the spare tire out?... don't you have to lift it out or something?
speedricerx is offline   Reply With Quote
Old 06-22-2005   #12 (permalink)
cubanmike26
cubanmike26's Avatar
cubanmike26 is a glorious beacon of light cubanmike26 is a glorious beacon of light cubanmike26 is a glorious beacon of light cubanmike26 is a glorious beacon of light cubanmike26 is a glorious beacon of light cubanmike26 is a glorious beacon of light
Great job Diskreet. Thanks for the DIY man!
I thought you said there wasn't much to write for the DIY ...yeah right, whenever one jumps on a project as such there's always lots of writing to do...but it came out great.
Rep added!
cubanmike26 is offline   Reply With Quote
Old 06-22-2005   #13 (permalink)
Graphicdude
Creative Mind Extraodinare
Graphicdude's Avatar
Graphicdude will become famous soon enough Graphicdude will become famous soon enough
Great minds think alike. I was already thinking of the same thing you did a few months ago. Sweet job dude!
Graphicdude is offline   Reply With Quote
Old 06-22-2005   #14 (permalink)
diskreet
diskreet's Avatar
Thanks for the compliments. hope i either will guide you through this or have inspired you in some way.
the box is a JL High Output enclosure and came with the subs as one package
Old 06-22-2005   #15 (permalink)
draganjr
Senior Member
draganjr's Avatar
draganjr is an unknown quantity at this point
This isn't stickied yet?!?
Looks really good, I think I shall do this myself soon, very soon!
I have tons of that MDF at my parents house!
draganjr is offline   Reply With Quote
Tags
board , boards , box , civic , custom , customer , customized , cutting , diy , honda , led , mdf , spare , tips , tire , trunk , trunkii
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
WTB: One Stock OEM Tire With or Without Rim streetglower Texas 4 10-07-2004 08:37 PM
Hey guys quick question... Civic02playa I.C.E. & Electrical 11 10-10-2003 09:32 AM
Pics of custom trunk with one 12" sub in 7th gen civic macrossranma I.C.E. & Electrical 7 01-31-2003 11:23 PM
DIY building a custom trunk ? Diablo Honda Civic DIYs and Civic Tech Chat 5 01-07-2003 03:28 PM
Updated: DIY Relocating spare tire under the car (with pics) pheaton Honda Civic DIYs and Civic Tech Chat 38 10-08-2002 05:44 PM
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
