Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-26-2005   #1 (permalink)
MegaHurtz
MegaHurtz's Avatar
MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of
Send a message via AIM to MegaHurtz Send a message via MSN to MegaHurtz
DIY: Stock sunvisor LCD monitor install
So to precede my thread on putting monitors in the sunvisors, here is the DIY that resulted. I thought it was going to be difficult, but it was really quite easy. The monitors fit in no problem. I had a BIT of a problem getting the driver side visor to close all the way, but we worked on it and it doesn't look too bad. I would say the hardest part was doing the wiring, not the actual monitor install. Unfortunately the camera died during the install process (we did pictures of the second visor so I couldn't fill in the gaps), but you will get a basic idea of how it works. Now, without further adieu, here is the install...
1) Here are the monitors I started with. NESA NSV-6523. Nice monitors indeed.
2) Removal of the visor is easy... simply get a flathead screwdriver, and pop off the little cover that goes over the 2 screws, then remove the 2 screws using said flathead driver. I think those screws can also use a torx bit, but easier to use flathead since its already on your lap. Careful not to break the little screw covers. I broke one of mine but not in half so I am still using it.
3) We used a flathead screwdriver to pop the visor open and we removed the 3 parts that go with the mirror. The visor is just a clamshell that comes apart quite easily. It's almost as if they were made to have nice shiny screens in them. Getting the mirror out is easy, I don't have pictures of exactly how we did it, but I cut off these little knobby things that held in the piece that goes around the mirror, took it out, removed the mirror, then cut the clips that hold that little door on and took it off, leaving us with what you see here.
4) This is the inside of the visor before it was cut apart. Not much to see really.... but if you are interested, this is what it looks like.
5) The monitors that I used are designed for use in visors. They came with these handy shrouds that go inside the visor, then the monitor snaps into the shroud. What we did was cut a hole in the plastic in the back of the visor (left all fabric intact) and then inserted the shroud from the back. It was actually pretty easy to get it in. Easier than I thought. We did have to trim off one side of the shroud because of the way that our visors are angled on the outside edge, but whatever. I don't have an exact picture of the shroud, but it is what the monitor is sitting inside in this pic. You can kind of make out what is monitor and what is shroud.
6) We took the shroud and marked out where it had to be cut out to fit. As I said before, we cut it out for the monitor to sit in and then slipped the shroud in from the backside. Again, this was pretty easy.
7) Now here is where the camera died. You don't really need pics of this part anyway. Basically we cut the hole out and slipped the shroud in like I said, and then got glued it in place to where it fit and put the monitor in. We didn't cut any fabric off of the visor, so we just tucked it around the inside edge of the shroud, then put the monitor in to hold it in place. Came out looking very nice and flush, like it was meant to be there. Also putting the shroud in from the back and under the fabric made it look very sleek and stealthy. I could rant for hours about how good it looks, but look at the next pic and see for yourself. Aside from the edge of the shroud poking out at the fabric I think it looks factory or pre-manufactured. It was really easy to get back together too. The passenger side was a bit more friendly to work with than the drivers side, but both look good. The problem on the drivers side is that not all of the clips that hold the visor together wanted to go back in no matter what we did, so there are 2 tiny gaps, but its not very noticable, and at car shows they will be angled down and out of view anyway. We ran the wire down each A pillar to the ignition harness.
8) Here they are installed. This was before they were wired up with either video or power. Thank God for the buddies that let you use their install bays. Thanks Rob at AUDIO VAULT, I owe you .
9) Here they are a couple hours later with power and video. I had some trouble taking a good picture, but you can see them and get the idea. These screens are really nice and good quality. Unfortunately right now I have no audio (new deck and I need a special plug to get aux in), but that will be fixed soon and I'll be pimpin'
__________________
Proud member of West Coast Extreme SPL
Come to the Mid-A meet 2007! This could be you!
MegaHurtz is offline   Reply With Quote
Sponsored Links
Old 04-26-2005   #2 (permalink)
booba5185
7thgen Terminator Ninja
booba5185's Avatar
booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold
Send a message via AIM to booba5185 Send a message via Yahoo to booba5185
nice diy, how much were those monitors?
__________________
I am the South West CLIT Commander
Quote:
Originally Posted by My Father
A friend bails you out of jail, a best friend is sitting next to you in jail saying, "She didn't look like no cop did she?"
Sportin the DX with the high performance piston return springs, are you?
http://www.cnw.com/~seagull/public_h...y%20ninja1.gif Ninja #9 of the 7thgen Ninja Clan http://www.cnw.com/~seagull/public_h...y%20ninja1.gif
booba5185 is offline   Reply With Quote
Old 04-26-2005   #3 (permalink)
AzNmiKex215
2k1civic.com O. G.
AzNmiKex215's Avatar
AzNmiKex215 will become famous soon enough AzNmiKex215 will become famous soon enough
Send a message via AIM to AzNmiKex215
hmm i like this DIY ITS GOOD!!
i dont want visor screens or headrest screens. But i would like a center flip down for the rear. What i dont like is how bulky the center flip down setups usually are. Maybe i can make my own "visor" and rig up a hinge of some kind and attach it to the center of the headliner in the rear so the rear seats have one center ceiling mounted screen without the bulkyness.
AzNmiKex215 is offline   Reply With Quote
Old 04-26-2005   #4 (permalink)
MegaHurtz
MegaHurtz's Avatar
I had a nice 8.4" overhead LCD in a dropdown console with a dvd player and the whole nines, but sold it. It was quite bulky though
__________________
Old 04-26-2005   #5 (permalink)
boombazokajoe91
I survived that B*tch Katrina !!!
boombazokajoe91's Avatar
boombazokajoe91 is an unknown quantity at this point
Send a message via AIM to boombazokajoe91
dude thats an awesome DIY thanks for doing it. im def. gonna use this in months to come..
boombazokajoe91 is offline   Reply With Quote
Old 04-26-2005   #6 (permalink)
SugaFree
Senior Member
SugaFree's Avatar
SugaFree is an unknown quantity at this point
Send a message via AIM to SugaFree Send a message via Yahoo to SugaFree
Kick-ass DIY. Where'd ya get the monitors?
SugaFree is offline   Reply With Quote
Old 04-26-2005   #7 (permalink)
PopcornPlaya
Electric Boogaloo...
PopcornPlaya's Avatar
PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold
Other than throwing in a few pics showing how to actually remove the visors, that's a pretty decent DIY.
I'm also curious to know how you hid your wires? You drill out the arm that the visor hinges on?
__________________
"Can you imagine what it feels like to have someone sit you down and tell you that you're dying? The gravity of that, hmm? Then the clock's ticking for you. In a split second your awe is cracked open. You look at things differently - smell things differently..... But most people have the luxury of not knowing when that clock's going to go off. And the irony of it is that that keeps them from really living their life. It keeps them drinking that glass of water but never really tasting it."
PopcornPlaya is offline   Reply With Quote
Old 04-27-2005   #8 (permalink)
MegaHurtz
MegaHurtz's Avatar
I didn't hide the wires
stay tuned for pics on how to remove the visor, you will see in that pic what I did with the wires, it's not bad. not great, but not bad.
__________________
Old 04-27-2005   #9 (permalink)
ncirom2003
ncirom2003's Avatar
Send a message via AIM to ncirom2003
cool diy, id rather have them where i cant see them just to keep myself safe but with the whole in the headrests it would look dumb to put those in so maybe ill do this after all
lets see bout some prices!
__________________
03 nissan 350Z
02 honda civic turbo----for sale, check below.
TURBO AND ELECTRONIC GOODIES FOR SALE.
I NEED TO SELL ASAP SO I HAVE LOW LOW PRICES.
[/color]
http://www.civicforums.com/forums/19...ool-d17er.html
MYSPACE
ncirom2003 is offline   Reply With Quote
Old 04-27-2005   #10 (permalink)
MegaHurtz
MegaHurtz's Avatar
originally I thought it might be kind of neat that I could put the visor all the way foward like I normally would to block the sun and then play an mp3 cd (or mp3 dvd) and be able to glance up at the OSD to navigate the tunes, but upon testing that in my garage, didnt seem like a good idea
another idea was to put the passenger side screen down and roatet it over so I can see it better and look at that one to see the music, but again, bad idea.
more pics in 1 min
__________________
Old 04-27-2005   #11 (permalink)
MegaHurtz
MegaHurtz's Avatar
btw here is what my wires look like on the passenger side
that isn't too bad, but I used the passenger side wires for a reason. The wires on the screen are located in such a way that they are long enough to reach inside the a-pillar and connect in there on the passenger side, but on the drivers screen, the wire is on the wrong side and is not long enough, so there is a red and black wire coming out of there, plus a blue video rca (becuase I tucked the monitors cable inside the visor and ran the RCA out. To hide the red and black wire, we took a short piece of blue 4ga wire and took all the wire out and put the pos and neg for the screen inside the wire. Fixed the problem of hiding the seperate red/black wires, but now I have a big 4ga wire instead of 2 neat black wires (we just wanted it to look neat and have matching blue wires.
I am going to remove the 4gauge from around the pos/neg for the screen and replace it with shrink tube and make a very short 6" or so black rca to get rid of the thick blue RCA so that there are small, neat, matching black wires on both sides instead of neat on one side and 2 big blue wires on the other.
The little tail going into the a pillar doesn't look so bad, and I didn't want to cut my headliner, so it works for me
__________________
Old 04-27-2005   #12 (permalink)
ncirom2003
ncirom2003's Avatar
that aint bad at all^^
__________________
03 nissan 350Z
[/color]
MYSPACE
Old 04-27-2005   #13 (permalink)
paradoxblue
Ultimate Member
Send a message via ICQ to paradoxblue Send a message via MSN to paradoxblue
looks hot
how bout some prices! and where youg ot em damn it?
haha awesome! i lvoe it. i'm next!!
paradoxblue is offline   Reply With Quote
Old 04-27-2005   #14 (permalink)
paradoxblue
Ultimate Member
oh also hwo thick are them screens. did it bubble the back out?
Old 04-27-2005   #15 (permalink)
paradoxblue
Ultimate Member
atually ehre's wut i think im going to get
only concernt is.. if it fits
http://www.mp3playerstore.com/stuff_...al/IN-720V.htm
Tags
2001 , civic , honda , install , sun , visor
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
MONITOR HELP!! LCD gurus cdmx Computer & Gaming 17 12-16-2004 06:17 AM
lcd in visor DrivenConcepts I.C.E. & Electrical 4 08-22-2004 07:59 PM
LCD screen legallity. norek Legal Questions and the Law 2 07-20-2004 11:51 AM
CRT vs LCD WannaBFast Computer & Gaming 24 06-27-2003 04:19 PM
OT: Daytek LCD *SPECIAL* $395 - This Week ONLY!! MSoft Canada East 10 02-10-2003 04:01 PM
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
