Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
Reload this Page
rear fill is too loud...
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
LinkBack Thread Tools
Old 04-04-2005   #1 (permalink)
tripledoublegs
Euro-Spec
tripledoublegs's Avatar
I have some cheap pioneer 6x9 speakers in the back, which I just hooked up to my cd player to run them as rear fill. The thing is the speakers are too freaking loud. I'm running my front components with a 4 channel and they are bi-amped but those damn rears are louder, and they are only running from the head unit. Is there any way I can tone them down a bit?? Btw, 4 channel is a infinity 111x4 rms, head unit is alpine 9833 26x4 rms... It just doesn's seem right...LOL. Any suggestions are appreciated.
tripledoublegs is offline   Reply With Quote
Sponsored Links
Old 04-04-2005   #2 (permalink)
MegaHurtz
MegaHurtz's Avatar
turn the fader towards teh front
MegaHurtz is offline   Reply With Quote
Old 04-04-2005   #3 (permalink)
tripledoublegs
Euro-Spec
that's not gonna work man, I tried it. If I turn the fader towards the front I can only hear my front tweeters, if I turn the fader towards the rear, I can hear my front mids, and rear speakers...Weird..LOL
Old 04-04-2005   #4 (permalink)
manahoonie
manahoonie's Avatar
manahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questioned
sounds like you did some crazy wiring when you did all that. sure all your wires are correct?
manahoonie is offline   Reply With Quote
Old 04-04-2005   #5 (permalink)
tripledoublegs
Euro-Spec
Ok, here's how I have my shit wired. My two preamps from the head unit go to my 4 channel amp, and from the amp to the crossovers, and my rear speakers are hooked up the regular way, directly to the wire harness from the head unit.
Old 04-04-2005   #6 (permalink)
tripledoublegs
Euro-Spec
here's a picture of how I have it hooked up.
Old 04-04-2005   #7 (permalink)
evilone
The Nightraid crew - Sensible Ownage
evilone's Avatar
evilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the rough
HU's that only have 2 pairs of preouts are usually rear and sub.....so if the fronts are amped, then I'd say you probably have the front midranges hooked up to the rear channel from the HU. Check into it.
evilone is offline   Reply With Quote
Old 04-04-2005   #8 (permalink)
LiKEaFeRiO
Ultimate Member
LiKEaFeRiO's Avatar
Quote:
Bingo.
I'd get that checked too.
LiKEaFeRiO is offline   Reply With Quote
Old 04-04-2005   #9 (permalink)
kornsined
Ultimate Member
kornsined's Avatar
are you bi-amping? if you are and you are using the deck high out to power the rears then that's why.
kornsined is offline   Reply With Quote
Old 04-04-2005   #10 (permalink)
tripledoublegs
Euro-Spec
mine has 3 sets of preamps
front, rear and sub. forgot to add sub in diagram
Old 04-04-2005   #11 (permalink)
grenloch101056
Diamond Member
grenloch101056 is an unknown quantity at this point
since your bi-amping your fronts, your using the front and rear inputs to feed your amp. You need to buy one femail to two male rca splitters from here so the amp will only see a signal from the front rca's. Once those are installed, you'll be able to fade the rears out while still sending the full range of sound to your front components
grenloch101056 is offline   Reply With Quote
Old 04-04-2005   #12 (permalink)
J187
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Head units that have 2 sets are usually front and rear.
You should fade everything to the right front, check it. Then left front, check it, then rear left, rear right and check it that way.
J187 is offline   Reply With Quote
Old 04-04-2005   #13 (permalink)
PopcornPlaya
Electric Boogaloo...
PopcornPlaya's Avatar
Run a single set of RCA's off the HU off the pre-outs labeled Front (if there's 3 or more sets, you'll have 2 that are fading which are front and rear, and one that's non-fading or sub out, wit 2 pre-outs, there'll be fading adn non-fading). From there, do as everyone says and split them at the amp.
PopcornPlaya is offline   Reply With Quote
Old 04-04-2005   #14 (permalink)
eye_see_you
let the devil out
eye_see_you's Avatar
eye_see_you has much to be proud ofeye_see_you has much to be proud ofeye_see_you has much to be proud ofeye_see_you has much to be proud ofeye_see_you has much to be proud ofeye_see_you has much to be proud ofeye_see_you has much to be proud ofeye_see_you has much to be proud ofeye_see_you has much to be proud ofeye_see_you has much to be proud ofeye_see_you has much to be proud of
sounds like your cableing to me.
eye_see_you is offline   Reply With Quote
Old 04-04-2005   #15 (permalink)
tripledoublegs
Euro-Spec
Quote:
what does that mean?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
When they do tint in our Civics... MegaHurtz Off Topic 13 11-04-2004 11:51 AM
Surround repair J187 I.C.E. & Electrical 7 10-09-2004 09:54 AM
4" mid in the a-pillar, should i do it?... slick I.C.E. & Electrical 14 08-10-2004 10:20 AM
best components HaLcYoN I.C.E. & Electrical 59 12-15-2002 11:14 PM
Kick Panels for the 7th gen civic on the way! JohnDoe I.C.E. & Electrical 28 10-28-2002 03:36 PM
User Login
Our Partners
used new
Top 10 Threads
DIY: Amp Wiring 2k1civic coupe
DIY: Head unit install
Sound Deadening DIY
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
MTX Jackhammer! Don't they know when to draw the line?
DIY: Custom Trunk II !with access to spare tire!
*** The big I.C.E. & Electrical sticky (DIY's, links, POSTING GUIDELINES, more) ***
HID in TYC setup. With no projector conversion. Video on pg 17.
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
