Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
Reload this Page
Alarm help for door unlock and lock
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
LinkBack Thread Tools
Old 03-31-2005   #1 (permalink)
pupil george
New Member
pupil george is an unknown quantity at this point
i recently got a alarm from a friend and i dont no what kind or anything. my first qestions is that it has a green wire that goes to the (-lock output) which i was told is the white blue wire behind hte driver kick panel. it also has a a blue wire which is the (-unlock output) which i was told was the white green wire. i made htese conections and when i arm and un arm the alarm the dorrs to not lock or unlock. i was told i may need a relay but i saw a diy posted on here about install a DEI keyless entry and it doesnt show a realy. i f anyone could help it would really help me out. i have been trying to figure this out for a few days
pupil george is offline   Reply With Quote
Sponsored Links
Old 03-31-2005   #2 (permalink)
ex_03
Godlike member
ex_03 is on a distinguished road
yep they may need relays, First off what car/year, Second what alarm is it excactly. Did you test the wires your on with a digital multi meter, do you have DMM if not radio shack has them for 35.00. A little more info..
Once we have established that your on the right wires, I'll show you how to wire a relay for lock / unlock, You'll 2 of them.
ex_03 is offline   Reply With Quote
Old 03-31-2005   #3 (permalink)
pupil george
New Member
the box he gave to me says "impulse" if that helps the car is a 2003 civic sedan . and im almost postive im on the right wires because when i first put them to gether they unlock and lock the doors. thats y i figured i needed relays and i didnt know how to wire them or what one i needed
Old 03-31-2005   #4 (permalink)
pupil george
New Member
thanks for the help so what kind of relay and to what wire and such . i have refered to directwire when i first put the alarm in i jsut need to know how to wire the relay and what kind a where i can get it
Old 03-31-2005   #5 (permalink)
skipbarber
A1, A3, A4, A5, A6, A8, L1
skipbarber's Avatar
are you sure the alarm is outputting ground on arm and disarm? I have never had to use relays on any honda using a quality alarm, because honda lock wires are sensitive. I don't think using a door lock relay or two relays would help anything, not in a 7thgen.
skipbarber is offline   Reply With Quote
Old 03-31-2005   #6 (permalink)
pupil george
New Member
thats what i heard from a few people to . is there anyway u can post how you wired and at what location u taped into them on. its werid because when i first touch them together to connect them they unlock my door or lock my door
Old 04-01-2005   #7 (permalink)
darklegacy540
Super Member
darklegacy540's Avatar
darklegacy540 is on a distinguished road
The alarms we install at work have built in relays so you don't have to go through the hassle of wiring in your own unless the locks are reverse polarity (in which our cars arent) so you won't need those. I'm not sure about the alarm you're using so it's hard to give you advice on what to do. I went behind the fuse box.
darklegacy540 is offline   Reply With Quote
Old 04-01-2005   #8 (permalink)
ex_03
Godlike member
Thats what I figured, mine didnt need relays. Have you tested the output of the alarm? do you have a DMM?
Old 04-05-2005   #9 (permalink)
darklegacy540
Super Member
I didn't need to test the output. Our alarms come with both positive and negative outputs so it's pretty straight forward for whatever car we're putting it on. If a car needs a negative pulse for the lock/unlock, we'll just pull out the positive pulsing wire because it'll just get in the way and we're not using it an yways. Yes I have three DMMs actually and an analog multimeter as well although I don't use that one very much.
Old 04-05-2005   #10 (permalink)
skipbarber
skipbarber's Avatar
in rare occassions, the positive output of the locks interfere with the operation(when you lock, lock goes ground, unlock goes 12v+) you could just diode isolate them, so that the car only sees ground.
Old 04-07-2005   #11 (permalink)
pupil george
New Member
alright everyone is giving good imfo but can anyone provide a wire diagram usasing relays i have two of them.this way i can try that before i try diode isolating them
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
What to swap manual door locks chicohonda02 Honda Civic DIYs and Civic Tech Chat 4 10-11-2003 11:36 AM
Door Problem Chunie1stcivic North Cali 12 09-20-2003 09:55 PM
pwr locks AntDeezy Mechanical Problems/Vehicle Issues and Fix-it Forum 2 05-29-2003 08:33 PM
Passenger Door Lock? ZSKCivic01 I.C.E. & Electrical 1 04-17-2003 01:33 PM
*PLEASE READ* EX's are EASY to break into.... slick General Automotive Discussion 44 01-28-2003 09:16 PM
User Login
Our Partners
used new
Top 10 Threads
DIY: Amp Wiring 2k1civic coupe
DIY: Head unit install
Sound Deadening DIY
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
MTX Jackhammer! Don't they know when to draw the line?
DIY: Custom Trunk II !with access to spare tire!
*** The big I.C.E. & Electrical sticky (DIY's, links, POSTING GUIDELINES, more) ***
HID in TYC setup. With no projector conversion. Video on pg 17.
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
