Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
Closed Thread
LinkBack Thread Tools
Old 01-01-2002   #1 (permalink)
Dmitri
Member
Dmitri is an unknown quantity at this point
Send a message via ICQ to Dmitri Send a message via AIM to Dmitri
DIY: Amp Wiring 2k1civic coupe
I know there are many different ways to wire your amplifier if placed in the trunk, but this may give some of you a good start. I'm no pro and there is probably a better way of doing this.
Power Wire:
There are 3 plastic panels that will need to be removed. The first is right above where the passenger's feet are. There are 3 spots towards the back of the vehicle that snap on. Pop these off by pulling down.
The other two plastic pieces to remove are the one at the bottom of the passenger door opening and the one just next to it towards the front of the vehicle. These simply pull off.
Once removed, you will have to pull back the carpet a little just below where you pulled off the first plastic panel. There's just a piece of velcro holding it in place.
Behind that, there is a rubber grommet. Using a completely straightened wire coat hanger, poke it through the grommet where there is an opening. You may have to try a few times to get it to go through.
Once through, look in the engine bay where it came out and pull it up enough so that you can tape about 5 inches or so of the power wire to the coat hanger. Make sure you don't pull the coat hanger all the way through. You will want to tape it so that it can easily go through the first small hole created, expanding it with just the wire to expand it.
Pull the wire back through, and there you go. One of the hard parts done.
Now route the wire behind the carpet (stay under the velcro piece), and over to the other two panels that you removed. You can tie the power wire directly to another wire running along the same path.
When you get to the rear passenger panel, simply push the wire underneath the panel and up to the seats. You may have to pry it up just a bit.
Run the wire next to and just under the back seats. You can then push it under the folding part of the seats and grab it in the trunk.
The remote wire can be ran along the same path.
RCA Wires:
The lock for the gas cap and trunk presented a problem for me. So all I did was run it the same way as the power wire, but just cram it underneath, making sure to not damage the wire.
And that's that. I haven't done the rest yet, because my new Kenwood X717 isn't in yet, so I still have to suffer for a bit with the stock tape deck.
Dmitri is offline
Sponsored Links
Old 01-02-2002   #2 (permalink)
vietnam
Member
vietnam is an unknown quantity at this point
thanks i really need that
vietnam is offline
Old 01-02-2002   #3 (permalink)
astigmatik
Senior Member
astigmatik's Avatar
astigmatik is an unknown quantity at this point
Dmitri, what are the lengths for the power and rca wires?
astigmatik is offline
Old 01-05-2002   #4 (permalink)
LJ
Fernando The Donkey Lover
LJ's Avatar
LJ is an unknown quantity at this point
Dude, a few things, always run your wire from the outside in, don't run your wire from the inside of the car, then try to get it through the firewall, you may not have enough wire if you do it that way, then you just have toi run it all again
DON'T run your rca's down the same side as the power wire, big big mistake, you will get road noise out the wazoo, people say you won't, but trust me you do
an easier way to get it through the firewall, try this, ram some needle nose pliers through the grommet, open, put wire in opening, pull back through
cheers [IMG]i/expressions/beer_yum.gif[/IMG][IMG]i/expressions/beer_yum.gif[/IMG][IMG]i/expressions/beer_yum.gif[/IMG]
LJ is offline
Old 01-07-2002   #5 (permalink)
CIVIC9782
Member
CIVIC9782 is an unknown quantity at this point
That's right .........always outside in not inside out ...
CIVIC9782 is offline
Old 01-20-2002   #6 (permalink)
Dmitri
Member
If you read a little more closely, I ran the RCA's down the driver side and power down the passenger side. And it's not too hard to measure the length of cable you'll need and get a little extra.
__________________
That's as cheap as bulk bags of rice.
http://keysdigital.com/~jeremy/sig.jpg
-{ Dmitri }-
Kenwood X717, Fusion 500w amp, 10" sub, and Magnaflow dual tip exhaust
Dmitri is offline
Old 01-20-2002   #7 (permalink)
Dmitri
Member
Oh, BTW.. I did the wire from inside out cause I had no clue where it was going to come out in the engine bay. Someone had posted some pics on here, but I couldn't tell from those where it would be. Just takes less effort to do it from the inside, too.
__________________
-{ Dmitri }-
Dmitri is offline
Old 01-20-2002   #8 (permalink)
nrrhgreg
Senior Member
nrrhgreg's Avatar
nrrhgreg is an unknown quantity at this point
Send a message via AIM to nrrhgreg
You can also run the RCA's through the middle of the car, underneath the middle console, carpet, and seat. Not that hard since the back seat just pops up, the carpet is easy enough to get under. That's how I did mine.
nrrhgreg is offline
Old 01-31-2002   #9 (permalink)
Marker02
Member
Marker02 is an unknown quantity at this point
Send a message via AIM to Marker02 Send a message via Yahoo to Marker02
How easy was it to get the back seat out? Maybe you can me where to look to get it out.[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Marker02 is offline
Old 02-09-2002   #10 (permalink)
dawg311
New Member
dawg311 is an unknown quantity at this point
Send a message via ICQ to dawg311 Send a message via AIM to dawg311
Removing the rear seats is a snap, and there is a great DIY in that section under the rear speaker installation. It only takes a few minutes.
dawg311 is offline
Old 02-25-2002   #11 (permalink)
CrankinCivic
Member
CrankinCivic is an unknown quantity at this point
Send a message via AIM to CrankinCivic Send a message via Yahoo to CrankinCivic
general a rule of thumb .. we tell our FNG .. F$#@in New Guys .. to try to get teh power wire ran down the same side as the battrey... path of least resistance .. and that will also try to help In anycar now ... if something is going wrong with the spark plug wires or alternaor whine .. depending on the car of course...
Rca's shhould be ran i believe IASCA rules state they shoulld be 36 inches apart MIn... and there should be a fuse with a foot of the battery ... what length cables do you need .. well get 16.4 feet .. yeah its a little long but do you know where your gonna moutnt the amp and exactly how much you will need.. not even most installers know that... doggin myself out i know . just get the prefab kits .. unless you need 2 ga. or 0 ga .. then buy the exact ..
CrankinCivic is offline
Old 03-01-2002   #12 (permalink)
mohawkboom
Post Master General
mohawkboom's Avatar
Send a message via ICQ to mohawkboom
16ft of 4 guage wire leaves you with about a foot of slack...
16ft Rca's leave you with some slack.. Slack is always good..[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
mohawkboom is offline
Old 07-25-2002   #13 (permalink)
sham01ski
Member
sham01ski is an unknown quantity at this point
Send a message via AIM to sham01ski
if you take the seats out it makes you feel like a real pro doing the install.. cause everyone knows if you get a hot install job done they take out most of the interior of your car...lol
sham01ski is offline
Old 08-02-2002   #14 (permalink)
kenji4861
Member
kenji4861's Avatar
kenji4861 is an unknown quantity at this point
Send a message via AIM to kenji4861
Having problems.
1) if you were to go from outside in, how or where do u poke the hole to get into the passengers seat?
2) if I were to go inside to outside, is this the right place to be poking through?
3) I need to rip these two things under my passenger's door off? I tried pulling a little, but not coming off easily, just want to make sure if I'm pulling on the right thing.
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] ACF50FC.jpg (79 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] ACF50FE.jpg (95 Kb)
kenji4861 is offline
Old 08-02-2002   #15 (permalink)
civic510
Member
civic510 is an unknown quantity at this point
Send a message via AIM to civic510
1) I used a thick bait threader to get through the passenger side grommet. I started from the inside.
2) Looks right to me.
3) Yeah, I took off the kick panel and the side panel and ran my power and remote wire under there. Just give them a good tug and they'll come off. They're held in by clips.
civic510 is offline
Closed Thread
Tags
02 , 2001 , 2003 , 2007 , amp , civic , honda , install , installation , installing , power , run , threw , wire , wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
