Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
Closed Thread
LinkBack Thread Tools
Old 09-13-2004   #106 (permalink)
matthewrward
New Member
matthewrward is an unknown quantity at this point
I guess those are the benefits of getting one new... got mine from my buddy. It didn't have any of the mounting brackets, just straps. I think I'll use some nuts and bolts and washers to attach it to the cardboard-ish spare tire cover. It will likely roll around a tad, but I think the nuts and bolts with huge washers will distribute the weight enough to keep the whole setup solid. To remove this ad, register today for free or log in if already registered!
matthewrward is offline
Sponsored Links
Old 09-13-2004   #107 (permalink)
Mystic3030
Yup, i'm an A$$hole.
Mystic3030 has a spectacular aura about Mystic3030 has a spectacular aura about
Send a message via AIM to Mystic3030 Send a message via Yahoo to Mystic3030
You could go to the hardware store and get some pipe strapping, spraypaint it black, and use that to make your own metal brackets.
Mystic3030 is offline
Old 09-13-2004   #108 (permalink)
thoughthard
Senior Member
thoughthard's Avatar
thoughthard is an unknown quantity at this point
Quote:
Actually mine was a "used" clearance item at CarToys. I think the metal mounting brackets are an option. I have no idea why mine came with them though. I don't even think they are used. Not a bad deal getting a Bazooka RS6A-HP tube, with metal brackets, new wiring harnesses, for $49.99
thoughthard is offline
Old 11-17-2004   #109 (permalink)
sigtrap
New Member
sigtrap is an unknown quantity at this point
quick tip for people running amp wires
instead of removing the rear seats, this is what i did
if you fold the rear seats down, you will expose a small panel door in the plastic.
if you open that panel, you will see other wires running in there as well as the black wire that runs from the front of the car to the rear underneath the door (maybe for the trunk open...who knows.)
anyways, you should have also seen this black wire when you removed the panel underneath the door
i just used a coat hanger and fished the amp wire up the side panel (this is where your right arm would be if you were sitting in the rear passenger seat), then grabbed it from the small plastic door.
you dont actually feed it through the door, just use that to grab a hold of your wire, because you can actually lift up the small carpeting in the trunk and have direct access through the trunk into that small panel opening.
hard to explain i guess...let me know if there are any questions
sigtrap is offline
Old 02-02-2005   #110 (permalink)
AznChinksta
Diamond Member
AznChinksta's Avatar
AznChinksta is just really nice AznChinksta is just really nice AznChinksta is just really nice AznChinksta is just really nice AznChinksta is just really nice
Send a message via AIM to AznChinksta
Where is the best place to put the ground wiring?
AznChinksta is offline
Old 02-02-2005   #111 (permalink)
nitz123us
New Member
nitz123us's Avatar
nitz123us is an unknown quantity at this point
Quote:
- The rear seat bolt on the left side of your car below where the back and bottom of the rear seat meets. It's great because it will be only around a foot or two away from where you're going to be installing your amp, plus you don't have to drill any holes or anything like that. just make sure you have it connected perfectly so it can't come loose and put lots of electrical tape over it once it's covered up. Look at the DIY for details.
nitz123us is offline
Old 02-02-2005   #112 (permalink)
MegaHurtz
MegaHurtz's Avatar
MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of
Send a message via AIM to MegaHurtz Send a message via MSN to MegaHurtz
another good place is an existing ground on the passenger side at the back of the car kinda by the tail lights... look around there and u will find
__________________
Proud member of West Coast Extreme SPL
Come to the Mid-A meet 2007! This could be you!
MegaHurtz is offline
Old 03-03-2005   #113 (permalink)
paradoxblue
Ultimate Member
Send a message via ICQ to paradoxblue Send a message via MSN to paradoxblue
Quote:
Originally Posted by CIVIC9782
That's right .........always outside in not inside out ...
aAHAHHHAHAHAHAA...!!
paradoxblue is offline
Old 03-04-2005   #114 (permalink)
jttegx
OMNES AD UNUM
jttegx's Avatar
jttegx has a spectacular aura about jttegx has a spectacular aura about
to hook up the remote wire and rcas behind the deck, what exactly do i need to remove or disemable in order to push the deck out? out of the top of my head, i know the plastic panel right underneath the passenger side feet, glove department, and what else?
__________________
they call me "82"
jttegx is offline
Old 05-03-2005   #115 (permalink)
civic2001mtx
New Member
civic2001mtx is an unknown quantity at this point
in my 01 civic all i had to do to get the cd player out was pry off the panel where the cigarette lighter is. then there are 2 bolts holding the whole console thing in that are a pain to get out. then try pushing it out but i had to gently pry along the side of the console to get the tabs out. then it just comes right out.
when i ran my power wire i couldnt find any gromets anywhere so i had to drill a hole by the passengers feet and ran the power wire throught there. what do u guys think of that?
civic2001mtx is offline
Old 05-03-2005   #116 (permalink)
Bires
Senior Member
Bires's Avatar
Bires is an unknown quantity at this point
Send a message via MSN to Bires
Quote:
What do I think?
OK...
I think you didn't look long enough. The gromet is there; it's huge, and it's in a great position, about 3" to the right of the center console, about 8" up from where the passenger-side metal floor starts to be covered but the rubber whateverthatthingiscalledthatgoesupthefirewall.
Since you drilled, invest in some high-temp silicone to seal the hole so you don't let hot air into your cabin or risk cutting your power wire on sharp/jagged metal.
__________________
02 EX coupe, heavily insulated.
Bires is offline
Old 05-03-2005   #117 (permalink)
civic2001mtx
New Member
i already sealed the hole with silicone so its good
Old 08-28-2005   #118 (permalink)
brent_01civic_e
Senior Member
brent_01civic_e's Avatar
brent_01civic_e is an unknown quantity at this point
i hope these pictures can help... its pics of how to get thru your "firewall" and i kno i searched for a while looking for some pics to help me out.. so i hope to help out some newbies like myself
and the hole in the background is where you would put the wires..and then u can use the wire hanger
brent_01civic_e is offline
Old 09-16-2005   #119 (permalink)
RS4DUKE
Member
RS4DUKE's Avatar
RS4DUKE is an unknown quantity at this point
Send a message via AIM to RS4DUKE
if you dont want to mess with the wires in the gormmet then do what i did, i drilled a new hole in the fire wall and used a firewall bushing to protect and secure the power cable. you can get the bushing from crutchfield.
RS4DUKE is offline
Old 10-12-2005   #120 (permalink)
gameboi499
New Member
gameboi499 is an unknown quantity at this point
i want to route the rca and the speaker wires beneath the middle console, how do i take off the middle console? i know this has already been posted somewhere, i tried to search, but just couldn't find it. so somebody please give me the link. also this link doesnt work for my car http://www.7thgencivic.com/forums/sh...d.php?t=176750.
i have a 02 civic coupe
gameboi499 is offline
Closed Thread
Tags
02 , 2001 , 2003 , 2007 , amp , civic , honda , install , installation , installing , power , run , threw , wire , wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
