Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
Closed Thread
LinkBack Thread Tools
Old 04-18-2004   #91 (permalink)
MegaHurtz
MegaHurtz's Avatar
MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of
Send a message via AIM to MegaHurtz Send a message via MSN to MegaHurtz
Thanks. To remove this ad, register today for free or log in if already registered!
MegaHurtz is offline
Sponsored Links
Old 04-18-2004   #92 (permalink)
nitz123us
New Member
nitz123us's Avatar
nitz123us is an unknown quantity at this point
No prob. The ground is the easy part. Going through everything for the rest of the wires is the hard part. If you need any clarification beyond the DIY's feel free to message, I just did the entire thing like 5 days ago and it's still really fresh in my mind.
nitz123us is offline
Old 04-18-2004   #93 (permalink)
MegaHurtz
MegaHurtz's Avatar
Well my wires are all in it's the aftermath of the wiring that I am worrying about...
In fact do you use MSN? I have a few questions that I might want to ask you
I am at rollz2low_420@hotmail.com
Old 04-19-2004   #94 (permalink)
ChunkyMonkey
New Member
ChunkyMonkey's Avatar
ChunkyMonkey is an unknown quantity at this point
Thanks
ChunkyMonkey is offline
Old 05-27-2004   #95 (permalink)
manahoonie
manahoonie's Avatar
manahoonie should not be questioned manahoonie should not be questioned manahoonie should not be questioned manahoonie should not be questioned manahoonie should not be questioned manahoonie should not be questioned manahoonie should not be questioned manahoonie should not be questioned manahoonie should not be questioned manahoonie should not be questioned manahoonie should not be questioned
Send a message via AIM to manahoonie Send a message via MSN to manahoonie Send a message via Yahoo to manahoonie
Cool Subs
Thanks for the info. I've got some subs that I'm currently getting a box and wires for. I'll check for that spot in the fire wall to run my power wire through. I had another route planned, but I'll check that one out as well.
I'll try and remember to post some pics of my stuff. 2-2" Memphis subs, 2-200w Pioneer Amps. No box yet (any help in qualityrice, e-mail me @ manahoonie@yahoo.com) and getting a wire kit.
Anyone want help installing subs? I will travel a little. e-mail me..
+ manahoonie
manahoonie is offline
Old 06-21-2004   #96 (permalink)
jta
Member
jta's Avatar
jta is an unknown quantity at this point
Dmitri
Thanks for your steps but you think you can put pictures with your steps.
jta is offline
Old 06-21-2004   #97 (permalink)
nitz123us
New Member
nitz123us's Avatar
I'm not about ready to take and post a bazillion pictures that are already on here in the DIY section. However, I've been taking my car's interior apart for around 5 months now and I can pretty much give you an exact step by step over messanger if you need it.
Old 06-22-2004   #98 (permalink)
jta
Member
jta's Avatar
Thanks man for your offer, I am going to start tommoro on this project (headunit, amp, 12" sub-box hookup).
My question is the amp kit tells you how to hookup everything from the batt. to the amp but does not tell you how to hookup the amp to the sub-box, so how do I hook them up?
I got a Bazooka 4channel 600watt amp and two 12" sub (300watts each) with 4 inputs.
please help
jta is offline
Old 06-22-2004   #99 (permalink)
jta
Member
jta's Avatar
where is the grounding point in the trunk for the amp.
jta is offline
Old 09-09-2004   #100 (permalink)
04civicvp
Member
04civicvp's Avatar
04civicvp is an unknown quantity at this point
Send a message via AIM to 04civicvp
Quote:
This was answered, but here it is again. The easiest spot to ground the amp is under the driver side rear seat where the seatbelt is bolted in. Loosen that bolt and attach your ground wire. This should give you a nice short ground run.
__________________
-Jeff, MECP certified installer
2004 Civic VP coupe auto - custom CAI, OBX Type R exhaust (rear section)
Best 1/4 Mile: 17.098 @ 79.16 mph
04civicvp is offline
Old 09-10-2004   #101 (permalink)
DaiCa86
New Member
DaiCa86 is an unknown quantity at this point
2004 Civic Coup
Did any one have problems running the power cable down the passenger to the trunk? Any advice in removing panels?
DaiCa86 is offline
Old 09-10-2004   #102 (permalink)
MegaHurtz
MegaHurtz's Avatar
It was easy
The only advice I have to give is take extreme care when putting everything back together
__________________
Proud member of West Coast Extreme SPL
Come to the Mid-A meet 2007! This could be you!
Old 09-10-2004   #103 (permalink)
DaiCa86
New Member
Honda Civic 04 Coup
Any advice/instruction in removing body panels and consoles to wire the power down the passenger side? I took out the wiring on my 4 runner that was easy b.c it was all screws. Is the civic more of snapping pieces together? Wuts the easiest way to take everything out?
DaiCa86 is offline
Old 09-12-2004   #104 (permalink)
matthewrward
New Member
matthewrward is an unknown quantity at this point
mounting?
Hey all,
I've been running my bazooka in the trunk of my civic 2k3 coupe for a while now, and it's been workin' great. Thanks to all the posters who posted stuff that made my install work.
Unfortunately, the only way I could figure out to mount it before was to screw through the mounting strap, through the trunk carpet, into the board-thing that covers the spare tire. Obviously, this doesn't offer much strength in the mounting, and the whole deal came loose yesterday.
Any suggestions for a new mounting setup?
matthewrward is offline
Old 09-12-2004   #105 (permalink)
thoughthard
Senior Member
thoughthard's Avatar
thoughthard is an unknown quantity at this point
Quote:
Originally Posted by matthewrward
Hey all,
I am waiting for a 15A AGU fuse to finish installing a Bazooka RS6A-HP in my g/f's 2k3 EX coupe. Mine came with some metal Bazooka brackets that clamp around the sub casing. I am planning on cutting a piece of MDF, size yet to be determined, for the sub to bolt onto. Big enough so that the tube will not roll around. Will be carpeted with some cheepo black Walmart automotive carpet I had leftover. To make sure the platform does not float around, I will put some of that no-slip rug material under it, and under the trunk carpet.
thoughthard is offline
Closed Thread
Tags
02 , 2001 , 2003 , 2007 , amp , civic , honda , install , installation , installing , power , run , threw , wire , wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
