Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
Closed Thread
LinkBack Thread Tools
Old 10-19-2003   #46 (permalink)
dups
Super Member
dups's Avatar
dups is an unknown quantity at this point
Send a message via AIM to dups
its a good chance its the line out converter. I've had troubles with those in the past. What brand did you buy because the quality of those can also make a difference in your sound. I used some sosche ones before that picked up a LOT of noise and caused really bad alternator whine, replacing those fixed a few problems for me so that could be it as well. To remove this ad, register today for free or log in if already registered!
dups is offline
Sponsored Links
Old 10-19-2003   #47 (permalink)
jwalker87
Bodacious Member
jwalker87's Avatar
jwalker87 is an unknown quantity at this point
Send a message via AIM to jwalker87
its a rockford fosgate. My amp has speaker-level inputs, so the first thing I'll probably try is to use those instead of the external one and see if that works. If that works, I can return like $45 of stuff (hopefully).
jwalker87 is offline
Old 10-19-2003   #48 (permalink)
jwalker87
Bodacious Member
jwalker87's Avatar
The Rockford Fosgate is the hi-lo converter. The amp is Sony. Since the light comes on on the amp and everything, the sound input seems logical.
Old 01-01-2004   #49 (permalink)
yellowcoppy95
Member
yellowcoppy95's Avatar
yellowcoppy95 is an unknown quantity at this point
Send a message via AIM to yellowcoppy95 Send a message via Yahoo to yellowcoppy95
does anybody out there know what the best capacitor is to buy (like specifications and other shi'ite like that) and how to install it
yellowcoppy95 is offline
Old 01-02-2004   #50 (permalink)
WhiteRabbit
Ultimate Member
WhiteRabbit's Avatar
WhiteRabbit should not be questioned WhiteRabbit should not be questioned WhiteRabbit should not be questioned WhiteRabbit should not be questioned WhiteRabbit should not be questioned
Send a message via AIM to WhiteRabbit
you install it like any amplifier. ground the - terminal, and wire the + terminal to your distribution block.
the two important specifications are capacitance and electrical series resistance. capacitance is relatively simple to understand, the higher the capacitance, the higher potential charge storage. the ESR is the speed at which that charge can be delivered.
Did you know your cell phone has several one farad capacitors in it? they wouldnt work very well for audio usage, their ESR is way too big! one way to lower ht eESR is done through some sort of engineering that I dont understand, but its manifested through the size of the capacitor. so you can *kind of* get an idea of ESR by phisical size. two capacitors of the same capacitance but of difference sizes *should* be indicative of which has a lower ESR. ESR is usually not advertized in big letters on the box like capacitance is.
realistically, any capacitor designed for audio use will work, and the higher capacitance, the better. I have a two farad capacitor, and when it was in my car, I never had any light dimming. ever
WhiteRabbit is offline
Old 01-04-2004   #51 (permalink)
7thGenerasianCivic
7thGen Junkie
7thGenerasianCivic's Avatar
7thGenerasianCivic is just really nice 7thGenerasianCivic is just really nice 7thGenerasianCivic is just really nice 7thGenerasianCivic is just really nice
So DON'T run the power and rca wires through the same path or I will get road noise?
7thGenerasianCivic is offline
Old 01-05-2004   #52 (permalink)
WhiteRabbit
Ultimate Member
its not really a factor most of the time, ive noticed. We did that as standard practice at my shop and we didnt get any noise 90% of the time.
but its a definite potential culprit if you happen to have alternator whine.
Road noise is the noise you get from driving. ever notice that a mercedes has a quieter cabin than a gutted civic, both going 70 on the freeway? thats road noise!
Old 01-05-2004   #53 (permalink)
7thGenerasianCivic
7thGen Junkie
Deleted*
__________________
i ♥ my daily hooptie- staggered- coils- frame low
Old 01-05-2004   #54 (permalink)
7thGenerasianCivic
7thGen Junkie
Deleted*
__________________
Old 01-07-2004   #55 (permalink)
greggdogg
Member
greggdogg's Avatar
greggdogg is an unknown quantity at this point
Send a message via AIM to greggdogg
OK, I'm clueless.
I found that grommet, and I *think* I found where it comes out in the engine bay. My questions are:
That grommet is PACKED, I mean no room at all. There's a bundle of wires going through the center hole. There are two side holes as well (smaller).
- Can I go through the holes on the side?
- What are the possibilities of hitting and damaging a wire in that bundle with a coathanger?
- Assuming I wire from the inside out, How am I supposed to grab the wire in the engine bay? It's behind all sorts of crap.
Also, this may have been asked before but I can't read through this thread : How big a fuse do I need if my amp has 2 20A fuses in it already?
...This is a 2003 sedan, dunno if that changes anything.
greggdogg is offline
Old 01-11-2004   #56 (permalink)
dups
Super Member
dups's Avatar
The grommet in my car wasn't packed at all. I'd be surprised if that changed between models. Be sure you're looking in the right spot. And if you're unsure about where the grommet is in the engine bay you can always get a coat hanger and carefullly push it through and then use it to feed the wire back into the car. Thats what I did to get mine done.
dups is offline
Old 01-16-2004   #57 (permalink)
ComPort X
Member
ComPort X's Avatar
ComPort X is an unknown quantity at this point
Hate to bring up old topics but I need some help on running the wires (power rcas, and remote). I have the power through the firewall, is there anything on the passenger side to keep the wire from? As far as running the wires through the car how do you get the trim pieces pulled up by the door and in the rear cabin. The car is a 2k4 coupe ex. Any & all help is greatly appriciated.
bty: are there any pics of the whole install process, i searched but couldn't really find anything
ComPort X is offline
Old 01-17-2004   #58 (permalink)
7thGenerasianCivic
7thGen Junkie
Quote:
Originally posted by greggdogg
OK, I'm clueless.
Ill try to take a pix tomorrow if I remember. And point out where the gromet is.
Run the wire from the gromet, under the carpet, the door pieces just pull straight out. Dont be afraid, just pull hard!!! Believe me. Then you'll have to lift up or take out (what I did) the rear seats. And just feed the wires under the carpet and up the body frame.
__________________
Old 01-17-2004   #59 (permalink)
7thGenerasianCivic
7thGen Junkie
*Sorry but I don't know where to host these pictures.
Grommet:
From the engine bay. Where the intake area is, just look straight down and towards the firewall.
__________________
Old 01-17-2004   #60 (permalink)
7thGenerasianCivic
7thGen Junkie
In from the passenger's foot well.
__________________
Closed Thread
Tags
02 , 2001 , 2003 , 2007 , amp , civic , honda , install , installation , installing , power , run , threw , wire , wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
