Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
Closed Thread
LinkBack Thread Tools
Old 06-26-2003   #31 (permalink)
dups
Super Member
dups's Avatar
dups is an unknown quantity at this point
Send a message via AIM to dups
lx-sport? To remove this ad, register today for free or log in if already registered!
dups is offline
Sponsored Links
Old 06-30-2003   #32 (permalink)
chriscivic
Super Member
chriscivic is an unknown quantity at this point
What is the lx-sport?
chriscivic is offline
Old 06-30-2003   #33 (permalink)
dups
Super Member
dups's Avatar
thats what I wanted to know... lol
dups is offline
Old 08-21-2003   #34 (permalink)
coop
coop's Avatar
coop is a jewel in the rough coop is a jewel in the rough coop is a jewel in the rough
NOTE - the 2k1 coupe does NOT have firewall access through that velcro'd spot.
I had to run my power wire through the same grommet as the wire bundle pictured on the left....
coop is offline
Old 08-22-2003   #35 (permalink)
dups
Super Member
dups's Avatar
You pull up the carpet where that velcro spot is, if you look there is a rubber grommet right next to the velcro that runs into the engine bay through the firewall, this is where you should run the wire. I have a 2k1 EX Coupe and that is exactly where my power wire ran.
dups is offline
Old 08-27-2003   #36 (permalink)
tmd438
Member
tmd438 is an unknown quantity at this point
Do i connect the + power line directly to the car battery ?
i got a 300 watt amp and alpine type S sub
do i need any capacitor in order to run the sub safely?
tmd438 is offline
Old 09-11-2003   #37 (permalink)
Lvl7Civic
Member
Lvl7Civic's Avatar
Lvl7Civic is an unknown quantity at this point
Send a message via AIM to Lvl7Civic
From what i understand... you need to put a fuse between the battery and that power wire. Someone else please verify this.... im gonna be doing the same thing before the end of the week. :-p
Lvl7Civic is offline
Old 09-11-2003   #38 (permalink)
Mystic3030
Yup, i'm an A$$hole.
Mystic3030 has a spectacular aura about Mystic3030 has a spectacular aura about
Send a message via AIM to Mystic3030 Send a message via Yahoo to Mystic3030
you need a fuse within 18 inches of the battery, and no you dont need a capacitor.
Mystic3030 is offline
Old 09-11-2003   #39 (permalink)
Regularjoe
Super Member
Regularjoe's Avatar
Regularjoe is on a distinguished road
Send a message via AIM to Regularjoe
Yes, you need a fuse right off the battery. Genereally within 18" of the battery. Generally this fuse should be equal to or a little above the total of all the amps in the system. Your Sony has two 30 amp fuses. Any fuse from 60 to 100 amps would work fine for you. If you get that kit it will have a fuse holder and fuse included just for this purpose (ATC in-line fuse holder).
Heres the one that is included w/ the kit I believe: http://www.scosche.com/efx/products/fuses/P8FH.asp
The purpose of this is to protect you if anything goes wrong. Thats why the closer the the battery the better (thats the within 18" part). Does it happen often if ever, no. I personally have never had a problem. But if you did it could save your car from an exploding battery, wiring meltdown, and the car catching on fire.
I did see it happen w/ my brother once. He put in his first stereo and routed in the power wire. Fired it all up and the system was just a bumpin (four JL 10" on a MTX amp). So then he goes for a cruise and go show it off. He pulls in the parkin lot and presses the e-brake pedal (truck was standard and needed to be running cause the amp used so much power). Well f course he wasn't so careful in the wire placement up under the dash. That brake pedal cut the wire casing and grounded it out quicker than he knew what happened. Nice big shower of sparks, it was scary. Thank god the fuse blew right away, shut the whole system down quick, and saved us. He felt like an ass and we were done for the night. Try finding a 60amp fuse 10PM at night in a small town.
Good luck.
I still say get that package. Its gots everything to do it right...... might even have directions.
__________________
Pics_of_my_ride!
Regularjoe is offline
Old 09-15-2003   #40 (permalink)
tcar
Member
tcar is an unknown quantity at this point
do you have a picture from the engine bay (where the cable comes out and how you connected it to the battery)?
Thanks
L.
tcar is offline
Old 10-19-2003   #41 (permalink)
jwalker87
Bodacious Member
jwalker87's Avatar
jwalker87 is an unknown quantity at this point
Send a message via AIM to jwalker87
thats what I need to know...how do i get the wire from the battery to the gromet?
jwalker87 is offline
Old 10-19-2003   #42 (permalink)
dups
Super Member
dups's Avatar
coat hanger or something. I just took a coat hanger and bent it and then shoved it through from the inside of the car, taped the wire around the coat hanger and pulled it back through.
dups is offline
Old 10-19-2003   #43 (permalink)
jwalker87
Bodacious Member
jwalker87's Avatar
i did that too. Worked out just fine. I got my amp all wired up, but have one problem; there's no sound. The amp power light is on, so the power aspect is good, but there is absolutely no sound coming from the subs. I fooled around with all the switched on the back, which did nothing, so it has to be a connection somewhere. Any hints on the most likely suspects? I really don't want to have to unbolt my sub box and take it apart....so I hope it isn't in there. Thanks.
Old 10-19-2003   #44 (permalink)
dups
Super Member
dups's Avatar
Do you have another speaker you can plug in to eliminate the sub and wiring inside? Also make sure your RCA connections are good and that the RCA cable works. Its pretty simple really, there is only 1 in and 1 out, so do some process of elimination. Try different cables, different speakers, you could try also a different source if you have a portable cd player with line-out outputs and just keep the volume really low to see if its your headunit. Just eliminate everything till you find the culprit.
dups is offline
Old 10-19-2003   #45 (permalink)
jwalker87
Bodacious Member
jwalker87's Avatar
i have a high to low converter hooked up to wires spliced off the rear speakers, so that might be it. I'm not sure if the + and - are hooked up correctly on the right one; would that affect the sound like this? I'll see if I can get some speakers to test, thats a good idea.
Closed Thread
Tags
02 , 2001 , 2003 , 2007 , amp , civic , honda , install , installation , installing , power , run , threw , wire , wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
