I.C.E. & ElectricalPost all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
Recently my front left speaker has started rattling at certain frequencies. Is it most likely just a matter of tightening something up? It's not too annoying yet but I'd like to fix it soon. Should I try it myself or should I take it back to CC and be like "that speaker you installed is rattling. Can you fix it?"
__________________ The best uncensored weightlifting community online eZine Forum
K&N FIPK II / HP Top Portion Header / Neuspeed Front Upper Strut Bar / RSX 19mm Rear Sway Bar
Generic Rear Upper Strut Bar / 15" Silver Rota Slipstreams (11.8lbs) / 205/60/15 Falken ZE-512's
Sponsored Links
Personally, I'd ask CC if they wouldn't charge me to look at it. If there was any possibility of a charge, I'd take a peek myself first. COuld be anything.
I'd ask CC to look at it like J187 said. My door vibrates as well with certain bass lines though. I think that maybe there are some bad resonance properties of the door because I've tightened and retightened everything. Maybe I'll finally have to buy some deadening material.
I have to take my car back to best buy every couple months or so for that darn rattle.(2 times so far) And its rattling again, this time im gonna tell them to do whatever it takes to fix it. Gah, ill never have bestbuy or cc install audio stuff again, they allways f it up.
Adding damping pads to our doors is the one easy thing to do on our cars. The doors pop off and on easily and you can add damping pads on the sheet metal and behind the speaker with relative ease.
__________________ 02 EX coupe, heavily insulated.
Oops, I forgot about this thread. It just started happening so I don't think it's just certain frequencies. I mean, it is certain frequencies but the same songs didn't used to rattle so something has become loose I think.
Dude I bet they did a lousy job installing it. I had to redo the entire install because they didn't know how to drill and part of the spacer had cracked loose.
__________________
Restore Performance, Reduce Costs www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
