Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-16-2004   #1 (permalink)
Pn0ybOiLiKehOy
Diamond Member
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
just got 2 10's
today i just got 2 10 inch kickers with box for $100. it didnt come with an amp, i have an amp from my old sub which was one 10, can i use that old amp for my new subs? it says on the amp 150 watt rms which is pretty weak i think. but can i use this in the meantime or will i mess somethign up? im such a n00b at this. thanks for any help guys To remove this ad, register today for free or log in if already registered!
Pn0ybOiLiKehOy is offline   Reply With Quote
Sponsored Links
Old 10-16-2004   #2 (permalink)
MegaHurtz
MegaHurtz's Avatar
MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of
Send a message via AIM to MegaHurtz Send a message via MSN to MegaHurtz
you will want to select an amp to use based on the power requirements of the subs. 150w definitely isn't very much for 2 subs, I don't recall seeing too many subs rated for 75w apiece. Pick an amp that will at least match the subs rated RMS power. You may be able to use the amp you have, but possibly not depending on the configuration of the subs and amp. Because that amp is so small however, you may not want to use it, becuase it will be at its peak capacity while the subs are still demanding more and it will eventually start to distort and it could be bad for your subs.
__________________
Proud member of West Coast Extreme SPL
Come to the Mid-A meet 2007! This could be you!
MegaHurtz is offline   Reply With Quote
Old 10-16-2004   #3 (permalink)
Pn0ybOiLiKehOy
Diamond Member
ok thanks man
Old 10-16-2004   #4 (permalink)
J187
J187's Avatar
J187 is a glorious beacon of light J187 is a glorious beacon of light J187 is a glorious beacon of light J187 is a glorious beacon of light J187 is a glorious beacon of light J187 is a glorious beacon of light J187 is a glorious beacon of light
Send a message via AIM to J187
Depends on a couple things. First off, it depends on what subs we're talking about. Kicker Comp C10s are rated at 125 rms I believe 75watts would DRASTICALLY underpower those. Also, is your amp rated at 150rms @ 4ohms? is it a mono amp or a 2 channel? Lets say its 150x2@4, well then you might be all set if you parellel the subs depending on their impedence. Basically we need more info.
J187 is offline   Reply With Quote
Old 10-16-2004   #5 (permalink)
MegaHurtz
MegaHurtz's Avatar
Me thinks that if it says 150 watts rms on the amp then it's total not per channel
__________________
Old 10-16-2004   #6 (permalink)
darklegacy540
Super Member
darklegacy540's Avatar
darklegacy540 is on a distinguished road
Send a message via ICQ to darklegacy540 Send a message via Yahoo to darklegacy540
^ Same thinking here. Get a different amp. Distortion=f*#ks things up.
__________________
MECP First Class Certified Installer
Quote:
Originally Posted by shaman
My 2002 civic tops out at 180 km/h........
Quote:
Originally Posted by bradmanuwf
dude, that's gay. you are going to have people going out to their cars now to see what 180 km/h is in mp/h....lol
darklegacy540 is offline   Reply With Quote
Old 10-16-2004   #7 (permalink)
Pn0ybOiLiKehOy
Diamond Member
hmm ok guys...thanks for all the help! whats a good amp that would work and is pretty cheap?
Old 10-16-2004   #8 (permalink)
Ed
Ultimate Member
Ed's Avatar
Location: Deathie Elaine and Pecosa Land, Hudson, Ohio, US
Ed will become famous soon enough Ed will become famous soon enough
Send a message via AIM to Ed
Which kickers are they exactly? Is the box ported or sealed?
__________________
Signatures are for crazy people.
Ed is offline   Reply With Quote
Old 10-16-2004   #9 (permalink)
jttegx
OMNES AD UNUM
jttegx's Avatar
jttegx has a spectacular aura about jttegx has a spectacular aura about
Quote:
everyone is gonna give you many different selections of amps. should start off stating what kind of subs, model number and the specs of it.
any brands you wont consider?
__________________
they call me "82"
jttegx is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
