Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
Reload this Page
DIY: Head unit install
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
LinkBack Thread Tools
Old 12-18-2006   #121 (permalink)
AequitasVeritas
Member
AequitasVeritas's Avatar
AequitasVeritas is an unknown quantity at this point
i mounted my radio to the factory brackets and then put the radios trim ring on it and it looks pretty sweet. no kit needed
AequitasVeritas is offline   Reply With Quote
Old 12-08-2007   #122 (permalink)
flotsamm
Ultimate Member
flotsamm's Avatar
Re: DIY: Head unit install
This is in reply to the user who broke his trim plate...
The reason you broke this is due to the fact that on certain models that dont have an armrest you have to remove the center console first. As you learned, there are 6 screws that need to be removed after you remove the center console.
flotsamm is offline   Reply With Quote
Old 05-05-2008   #123 (permalink)
Diego
New Member
Diego is an unknown quantity at this point
Nice tutorial. However I'm wondering if anyone has tips on removing that center panel around the shifter in a manual? Basically step 2 for a 5speed.
Mine just won't budge, I pull and pull but it seems like any more force and it's going to snap in half. After seeing the unit with a snapped plate I'm doing my best to avoid such results. Just for reference mine does have an armrest.
Any advice?
Diego is offline   Reply With Quote
Old 05-05-2008   #124 (permalink)
gearbox
Super Moderator
gearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant future
the whole console has to come off. you cant just take the trim off, its not possible wiithout breaking it.
gearbox is offline   Reply With Quote
Old 05-05-2008   #125 (permalink)
Diego
New Member
Perhaps I have the terminology mixed up.
This is what I'm referring to:
It doesn't seem like I can just pull this out without breaking it.
Old 05-05-2008   #126 (permalink)
christmaspie
Super Member
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Unclip the shift boot by pulling it down (grab the silver ring right below the shift knob and pull down). Untwist the shift knob (twist it counter clockwise until it comes off). Lift up entire trim panel and shift boot.
christmaspie is offline   Reply With Quote
Old 05-05-2008   #127 (permalink)
gearbox
Super Moderator
i guess its different for an auto. mine goes on from the bottom and cant pull up from top without taking the console out. circuit city actually broke mine when trying to pull it when i first got the car.
Old 05-06-2008   #128 (permalink)
sl33pyriceboi
Ultimate Member
sl33pyriceboi's Avatar
sl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to behold
manual and auto is diff...not to mention center consols for 01/02 are different than 03-05. kinda gay huh....
sl33pyriceboi is offline   Reply With Quote
Old 05-10-2008   #129 (permalink)
DeX
Ultimate Member
DeX's Avatar
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Quote:
2001 - 2003 and 2004 - 2005
DeX is offline   Reply With Quote
Old 1 Week Ago   #130 (permalink)
carlitoi930
New Member
carlitoi930 is an unknown quantity at this point
Quote:
Originally Posted by MegaHurtz View Post
As this was long overdue, I decided to make a head unit install DIY for the 03-04 Civic. This may apply to other years as well, but AFAIK, it is only for the 03-04. This DIY was created using an 04 LX coupe.
NOTE: The first 3 pictures are for an install on an auto, the following 4 will be for an install on a 5 speed. After the first 3 steps for each, there are no differences.
1) Stick your hand under the trim ring and pull
2) The ring comes off easily
3) Stick your finger in the location shown and pull up HARD. It can be very stiff but it does come out. There is a hole there to stick your finger in and make it easier.
4) The console piece does come off but it can be a pain in the ass sometimes. If it seems stuck in one part, look very closely to where the clip is (the console piece will be cut out a little just above it), stick a very small screwdriver and try to push the clip out. It will come out eventually so be persistent.
NOTE: The following 3 steps are for an install on a 5 speed. Following these steps, starting at number one again are instructions that apply to both manual and auto.
1) This is what the 5 speed center console looks like
2) Pull up on the shifter console area like how I am in the picture. You want to pull from inside the shiftboot area. You may want to pull with both hands. One hand on the left side, and one on the right side. Its easier if you do it with both. The only reason I have one hand in the pic, is the simple fact I used the other to take the pic. After you pull the left and right sides up, the front and back should just come off. There is nothing but clips holding this area down.
3) You should be able to turn the area around the shifter sideways. Once this is done, you can follow the steps from the DIY for the auto, its exactly the same. As you can see in the pic, its not necessary to take off the shift knob.
NOTE: The remaining steps apply to both manual and automatic vehicles
1) Use a phillips head screwdriver to remove the 2 screws located near the cup holders on either side of the console
2) Stick your hand under the "horseshoe shaped piece" as shown and pull it out. It is simply held in by clips, 2 on each side. Pull the sides out first and then pull the entire piece out by pulling up and back. Unplug the cigarette lighter and set this piece aside.
3) This is what your dash should now look like, and you can start taking the head unit out.
4) Remove these 2 screws to allow you to take the panel containing your HVAC controls, hazard light and head unit to come out. You can use either a very short phillips head screwdriver or an 8mm socket and ratchet. I highly recommend the ratchet. One screw is in the center and one is towards the right, but they are up underneath the dash and you may have to get under there at a wierd angle to see them, but they are very easy to get out using a ratchet.
5) Stick your hand behind the metal bar that you just took the screws out of and push it kind of up and forward. The top of this bar is part of the panel containing the head unit and the bottom half is part of the car. Push on the bar so that the head unit pops out. It may be stiff if it hasn't been removed before but it does come out.
That's all there is to it, and reassembly is the exact opposite of disassembly.
If you get stuck, please feel free to post any questions in this thread.
hey im stuck at the last part i push on the metal thing and i see my radio move a little but it wont come out what do i do?
carlitoi930 is offline   Reply With Quote
Old 1 Week Ago   #131 (permalink)
manahoonie
manahoonie's Avatar
manahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questioned
/\/\ push harder... at least with my car, it was really in there...
ALSO, double check to make sure you took out the two screws up under there! :P
manahoonie is offline   Reply With Quote
Old 1 Week Ago   #132 (permalink)
DeX
Ultimate Member
DeX's Avatar
There's 2 metal bars.
a) One that stays in the dash and is what your radio holder is bolted to.
b) One that you're actually removing from the dash as part of the radio holder.
You need to get your hand up behind the dash bar and pull towards you on the other bar....you'll feel one move independently of the other. Then when you got it towards you a bit, you won't be able to keep pulling it out because the dash back is in the way. Take your hands out and grab a hold of the dash piece around the actual headunit and HVAC controls, it'll come right out.
Old 1 Week Ago   #133 (permalink)
ampong
Member
ampong's Avatar
ampong is an unknown quantity at this point
Great thread. Thanks for this DIY mate.
ampong is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Amp Wiring 2k1civic coupe
DIY: Installing Rear Speakers in a Sedan
Sound Deadening DIY
Post pics of your trunk w/ subs, amps and whatever!
MTX Jackhammer! Don't they know when to draw the line?
DIY: Custom Trunk II !with access to spare tire!
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
*** The big I.C.E. & Electrical sticky (DIY's, links, POSTING GUIDELINES, more) ***
**FINISHED** HU relocation
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
