Positive/Negative?
Old Aug 9, 2004
takumi's Avatar
takumi is on a distinguished road
Positive/Negative?
My rear speakers in my 04 Civic have 2 wires going into it. One is a blue one with a yellow stripe, the other is a pink wire on the right speaker. One the left speaker, there's a blue wire with a white stripe and a blue wire with a black stripe. Which one is positive and which one is negative?
Old Aug 9, 2004
MegaHurtz's Avatar
LF SPEAKER
grn/blk -
lt green +
RF SPEAKER
grn/yel -
gry/red +
LR SPEAKER
blu/wht +
blu/blk -
RR SPEAKER
pink +
blu/yel -
Old Aug 9, 2004
takumi's Avatar
OK, one last thing. On the ciggarette lighter, there's a yellow wire with a green stripe and a black wire. I'm assuming the black is ground, but just wanted to make sure. Is that right?
Old Aug 9, 2004
MegaHurtz's Avatar
Check it with a test light
In fact I *THINK* it's the opposite, but you will definitely want to check that one
Old Aug 9, 2004
takumi's Avatar
Test light?
Old Aug 9, 2004
MegaHurtz's Avatar
It's a little thing that looks like a screwdriver, has a probe on one end and an alligator clip on the other which is for ground.
You hook up the alligator clip (which is on the end of a wire) to a ground source then use the probe to find a power source and when u do the light inside the handle lights up
useful tool to own
Old Aug 9, 2004
doubledeuce2k2's Avatar
yellow is +, black is -
i've grounded out the black when trying to solve noise problems
Old Aug 9, 2004
MegaHurtz's Avatar
Grounded it out how?
Old Aug 9, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Darker colors are almost always ground. hence: blue w/black = - and blue w/white = +
Old Aug 9, 2004
MegaHurtz's Avatar
Ya but I know better than to NEVER trust colors
Old Aug 9, 2004
takumi's Avatar
Thanks, hope you're right DoubleDeuce. I don't wanna go and buy a test light because I don't think I'll ever use it again, lol.
Old Aug 9, 2004
MegaHurtz's Avatar
If you ever do electrical work it's a good thing to have
I think they used to have a complete wiring diagram/chart on the site when it was in it's old incarnation, but I haven't seen it since they changed the site
Old Aug 10, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
i think the wiring diagram has been moved to the section for alarm install...
i swear they keep making this site harder and harder to use....i cant get this forum to auto subscribe to threads i replied to...i have to subscribe to them manually but then the webmaster made it harder to manually subscribe to threads...i now have to click two links to subscribe...
btw, i think test lights suck..hehe...not very versatile...just my opinion but i think it's better to spend a few more dollars to buy a multimeter and learn how to use it.
Old Aug 10, 2004
jjj784's Avatar
jjj784 is an unknown quantity at this point
i just use my multimeter. i haven't gotten used to using the test light.
Old Aug 10, 2004
MegaHurtz's Avatar
Ya well if doesn't have a test light you can be damn sure he doesn't have a multimeter either
I love my DMM, stays in the car with at all times
Old Aug 10, 2004
takumi's Avatar
Lol ya, I don't have a meter lying around either. Anyway, I was just gonna tap the ciggarette lighter for the remote wire. The worst that can happen is the amp won't turn on if it's the wrong wire, right?
Old Aug 10, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
are you using a aftermarket deck? if you are why not use the remote wire on that?
If you are using a stock deck then that is a good idea.
Old Aug 10, 2004
takumi's Avatar
Lol, factory deck. I don't wanna buy an aftermarket deck right now so I need another source for the remote wire.
