Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
Reload this Page
Fook! Speakers don't fit!
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
LinkBack Thread Tools
Old 08-02-2004   #1 (permalink)
Schizophonic
Member
Schizophonic's Avatar
Schizophonic is an unknown quantity at this point
I got these the other week.
Brought them to my Garage to fit them in and they won't go in. I have to trim the metal door panel to do so which i don't
The actual speak frame at the back don't go in properly even with spacers - the speakers are gonna be too wide to fit in.
This is the list of speakers i was chosing.
Speakers
Do you have any of them and which one will actually fit.
NOTE: This is for a UK spec Civic 03 1.4i but i'm sure it wouldn't be a problem. BTW, are the back speakers 6 1/2 as well?
Schizophonic is offline   Reply With Quote
Sponsored Links
Old 08-02-2004   #2 (permalink)
civic2uner
Diamond Member
civic2uner's Avatar
i have the alpine type s and i bought a spacer for the speaker.
civic2uner is offline   Reply With Quote
Old 08-03-2004   #3 (permalink)
coop
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
I don't know if there is an aftermarket speaker made that will fit without at LEAST a spacer....
coop is offline   Reply With Quote
Old 08-03-2004   #4 (permalink)
BlueTroll
Diamond Member
BlueTroll's Avatar
BlueTroll is an unknown quantity at this point
sonys will fit.
BlueTroll is offline   Reply With Quote
Old 08-03-2004   #5 (permalink)
fonto
The LA Clipper
fonto's Avatar
Dude, all you need is a spacer...or cut out a spacer with 3/4 inch MDF.
...it should be all good
fonto is offline   Reply With Quote
Old 08-03-2004   #6 (permalink)
NoLeadEmSoMuch
NoLeadEmSoMuch's Avatar
NoLeadEmSoMuch will become famous soon enoughNoLeadEmSoMuch will become famous soon enough
My Boston Acoustics fit fine in the rear but needed the well cut up front. No big thing.
NoLeadEmSoMuch is offline   Reply With Quote
Old 08-03-2004   #7 (permalink)
MegaHurtz
MegaHurtz's Avatar
Quote:
Did you buy a component set or just the 6.5" driver?
MegaHurtz is offline   Reply With Quote
Old 08-03-2004   #8 (permalink)
MegaHurtz
MegaHurtz's Avatar
Quote:
*pic removed*
Speakers
You need spacers, they don't make em for nothing
I believe rear speakers in a sedan are 6.5, but in a coupe they are 6x9
Old 08-03-2004   #9 (permalink)
civic2uner
Diamond Member
civic2uner's Avatar
Quote:
not sure they were 100$, look like this....
Name:	searcy fest 007.jpg
Old 08-03-2004   #10 (permalink)
MegaHurtz
MegaHurtz's Avatar
Ahh coaxials
Components are the 3-piece set including 6.5" driver, tweeter, and xover
The reason I ask is that spacers for a 7gen are included with the component set.
Old 08-03-2004   #11 (permalink)
Schizophonic
Member
Well the good news was that i removed my back stock speakers (6 1/2 btw) and they fit in just perfectly. Only 2/3 screw holes fit easily. The 3rd is a no go. But i an't too bothered. The reason why they didn't fit was becuase the frame was too big to fit in the door panel. The actual width doesn't fit in properly. I will need to go out and but some thinner speakers.
But was this speaker set a good set to go with? Whats the differance between the 2way and 3 way. Would i have got more out with a 3 way.
And yeah i need a new head unit to go with the speakers, the stock HD just isn't making good use of the new rear speakers.
I DID MY FIRST CAR MOD!
Old 08-04-2004   #12 (permalink)
brash
Senior Member
brash is an unknown quantity at this point
2 way = two separate speakers, almost always woofer + tweeter.
3 way = three speakers, generally woofer + tweeter + supertweeter, I believe. Sometimes woofer + midbass + tweeter. I don't know which it is for the specific model you are looking at.
IMHO "3 way" (and especially "4 way") is mostly just a gimmicky term to try to make people think the speakers are better.
brash is offline   Reply With Quote
Old 08-04-2004   #13 (permalink)
Ed
Ultimate Member
Ed's Avatar
Location: Deathie Elaine and Pecosa Land, Hudson, Ohio, US
yeah, i don't think a 3 way is necessary at all, I got a set of cheap 3 ways from a member here and the highs seemed extremely piercing, i turned my treble down a lot to be comfortable
Ed is offline   Reply With Quote
Old 08-04-2004   #14 (permalink)
MegaHurtz
MegaHurtz's Avatar
Most high end systems use only a coaxial or component system in the front which is 2 way
Old 08-05-2004   #15 (permalink)
Schizophonic
Member
My back speakers are not at full use! Should i get an amp to power the speakers first or wait to find an KICK ASS head unit?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Amp Wiring 2k1civic coupe
DIY: Head unit install
Sound Deadening DIY
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
MTX Jackhammer! Don't they know when to draw the line?
DIY: Custom Trunk II !with access to spare tire!
*** The big I.C.E. & Electrical sticky (DIY's, links, POSTING GUIDELINES, more) ***
HID in TYC setup. With no projector conversion. Video on pg 17.
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
