Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-25-2004   #16 (permalink)
turboslug
Super Hoser
turboslug will become famous soon enough turboslug will become famous soon enough
Quote:
Originally Posted by 82801BA
I can fit a SPX speaker with a 0.75 but it hits the rear torsion bar. I use both aftermarket spacer and the one Alpine supplied in the box together.
The SPX speaker will make the door not closing properly, but it won't hit the plastic anyway. It's the spacer itself that make this happen. But it also helps to prevent hitting the plastic panel anyway. Both good and bad.
torsion bar? are you talking about rear speakers? i dont care about the rear ones right now..i can fit whatever back there after the trunk shocks mod.
i'm concerned about the front speakers right now. so only reason the plastic door panel wont go back on is because you made the spacer too wide? i currently have a 0.75" spacer and the door panel goes back on no prob...you can make the spacer exactly the same size as the grille ring, right? also, did the spx align exactly in the same posistion as the stock speaker? if it's not aligned exactly the same way, it's the reason why the door panel hits the speaker?
turboslug is offline   Reply With Quote
Sponsored Links
Old 05-25-2004   #17 (permalink)
82801BA
Super Member
82801BA's Avatar
82801BA is an unknown quantity at this point
Send a message via ICQ to 82801BA Send a message via AIM to 82801BA Send a message via MSN to 82801BA Send a message via Yahoo to 82801BA
Sorry, my fault....Not the torsion bar, but the lower door beam.
0.75" spacer is fine for the door, but it is a little too thin for the speaker, either R or X. I had the SPX speaker sit at the center of the hole.
Anyway, I can only tell you that, whatever aftermarket speaker you put into our Vic, it is going to have phase problem. If you have speakers in door, you can align for the midrange by reversing DRIVER'S SIDE woofer polarity(after crossover), then center stage at center of dashboard(then LOWs out of phase). Or you can leave the midrange out of phase by having all speakers in phase(LOWs in phase). I did the research and trial and error for about a year I figured out last night. PM me or IM me if you want to discuss that with me.
That's the reason why I go 3-way.....
82801BA is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
