Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-18-2004   #1 (permalink)
MegaHurtz
MegaHurtz's Avatar
MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of
Send a message via AIM to MegaHurtz Send a message via MSN to MegaHurtz
Amp ground points?
Are there any spots in my trunk that I can easily ground my amp to?
I don't really want to have to drill more holes than I have to, so if there is a nice place from the factory, I'd like to know about it.
I have 2 units that need to be grounded, my amp and my cap.
__________________
Proud member of West Coast Extreme SPL
Come to the Mid-A meet 2007! This could be you!
MegaHurtz is offline   Reply With Quote
Sponsored Links
Old 04-18-2004   #2 (permalink)
civicstyle82
7thGen Junkie
civicstyle82's Avatar
civicstyle82 is a name known to all civicstyle82 is a name known to all civicstyle82 is a name known to all civicstyle82 is a name known to all civicstyle82 is a name known to all civicstyle82 is a name known to all civicstyle82 is a name known to all civicstyle82 is a name known to all
Send a message via MSN to civicstyle82
Where is it mounted?
I had my ground on a bolt near the taillights
__________________
Puerto Vallarta Pictures
civicstyle82 is offline   Reply With Quote
Old 04-18-2004   #3 (permalink)
MegaHurtz
MegaHurtz's Avatar
Either on the left or right side my trunk (not sure where it will go yet), but probably the left. As close to the rear seats as possible. Definitely closer to the rear seat than to the taillights.
Old 04-18-2004   #4 (permalink)
civicstyle82
7thGen Junkie
I guess anything is possible with the right length of ground wire.
__________________
Old 04-18-2004   #5 (permalink)
MegaHurtz
MegaHurtz's Avatar
Of course, but as you know the limit on length for a ground wire should be 36"
Old 04-18-2004   #6 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned
i used the upper strut mounting, just make sure to clean it to bare metal and the shorter the better
__________________
169.8whp / 154 ft lbs tq @ 7psi with an auto trans!
Click Image for my turbo install!
Or
Check out my 1966 OLDS 442 Project in the works!
DIY Mechanical O2 simulator
DIY Head gasket
DIY Front Wheel Bearing
How to tune short term/long term fuel trim
tfnaaf is offline   Reply With Quote
Old 04-18-2004   #7 (permalink)
MegaHurtz
MegaHurtz's Avatar
Where is that located? Pics?
Old 04-19-2004   #8 (permalink)
custom2k1
Senior Member
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
Send a message via AIM to custom2k1
It doesnt matter how long your ground cable is as long as you have the proper gauge for the length that you are using. The older PPI power class amps told you to have a ground run directly to the battery and to the chassis. My ground is to my seatbelt bolt and I've never had any problems.
custom2k1 is offline   Reply With Quote
Old 04-19-2004   #9 (permalink)
MegaHurtz
MegaHurtz's Avatar
It is a theory and a rule of thumb that grounds should be <= 36".
How this was derived I do not know but should I find out, I will post it
Old 04-19-2004   #10 (permalink)
PopcornPlaya
Electric Boogaloo...
PopcornPlaya's Avatar
PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold
If you remove the jack access cover (plastic piece at rear of trunk) there will be a grounding bolt behind it. There should be about 6-10 wires already grounded there. The screw should be green. If you don't want to ground it there, find a bolt somewhere in the trunk, or do like I did, and find a place that's near where you're going to mount the amp and cap, get a piece of sand paper, a stripping bit in a drill, anything really, scrape off/sand off the paint to bare metal, and run a self tapping metal screw in it, and ground there.
PopcornPlaya is offline   Reply With Quote
Old 04-19-2004   #11 (permalink)
gizcivic
Senior Member
gizcivic's Avatar
gizcivic is an unknown quantity at this point
i grounding mine to one of the two bolts that hold the trunk lach to lock the trunk NO PROBLEMS
gizcivic is offline   Reply With Quote
Old 04-19-2004   #12 (permalink)
coop
coop's Avatar
coop is a jewel in the rough coop is a jewel in the rough coop is a jewel in the rough
if you pull up your rear seat you will notice unpainted metal - I used one of the seat belt bolts. All grounds consolidated to a distribution block accordingly.
coop is offline   Reply With Quote
Old 04-20-2004   #13 (permalink)
phuviano
Slowest 7thgen in the GTA
phuviano's Avatar
phuviano has a spectacular aura about phuviano has a spectacular aura about
I bolted mine to the one bolt that hold down your rear seats. I was testing out all the grounding points in the trunk, and found out that most of the metal of the trunk, willing not ground. All the bolts you see will ground (goldish colour bolts).
If you got a volt meter try it out. Get your remote wire and connect that to your positive terminal on your volt meter, and then keep touching suitable grounding points with the negative terminal.
Well that's what I did at least.
phuviano is offline   Reply With Quote
Old 04-20-2004   #14 (permalink)
Mystic3030
Yup, i'm an A$$hole.
Mystic3030 has a spectacular aura about Mystic3030 has a spectacular aura about
Send a message via AIM to Mystic3030 Send a message via Yahoo to Mystic3030
The bolt that holds down the rear seat cushion is where I have my amps grounded too...it's a good spot.
Mystic3030 is offline   Reply With Quote
Old 04-20-2004   #15 (permalink)
phuviano
phuviano's Avatar
Quote:
haha... I'm not the only one. I had to use a longer bolt though. The stock bolt was too short. I have a grounding block connected to my ground wire, and that's why it would not fit.
I could have just bought a connector, but I was too lazy to go to the stereo shop.
__________________
http://www3.sympatico.ca/phuvong/7thgenhondasig.jpg
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
