Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
Reload this Page
DIY Make Under Body LED
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
LinkBack Thread Tools
Old 03-21-2004   #1 (permalink)
KalliGarri
A.K.A BlackCar --- Not From Califorina!
KalliGarri's Avatar
KalliGarri is on a distinguished road
this is gonna be my next project..
Make Led Under Body Lights..
Pvc Tubes.. $5
Leds- $10
Shrink Tubes - $10
Resistors - $6
in all.. itll be about 30-35 bux.. good enuff for a bored man doin his own stuff
heres a diagram of it.. ill be makin instructions in about a week.. with sum pics..
seems like a stupid thing to do but.. hey.. why not? i already have alota pointless things in mah car.. VTech light.. Hyper Blinker..
EDIT: quick question.. when hooking up the positive wire up... would u hook it up striaght to the battery? ive seen sum cars with lights and what not... and ive looked in the hood... and theres no wries heading to the battery but the subs positive wire...
would there be another place to put the POSITIVE wire?
Name:	diy under body.jpg
KalliGarri is offline   Reply With Quote
Sponsored Links
Old 03-21-2004   #2 (permalink)
custom2k1
Senior Member
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
Just make sure that when you do it that you shave the top of the LED, otherwise it will be very focused and give you hot spots. Shaving the top diffuses the light alot more.
custom2k1 is offline   Reply With Quote
Old 03-21-2004   #3 (permalink)
LudlamTheory
i boogie for the raindrops
LudlamTheory's Avatar
where do you plan on buying your led's
alsoooooo
if you use white tubing thats really really translucent it could help give it that softer look like a neon light has
LudlamTheory is offline   Reply With Quote
Old 03-21-2004   #4 (permalink)
KalliGarri
KalliGarri's Avatar
leds from a friend of mine... works at lowes.. hes juss gonna get emm for me
Old 03-21-2004   #5 (permalink)
gearbox
Super Moderator
gearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant future
Make sure the LEDs are VERY bright for the amount you're using. I would go with a minimum of 5000mcd or the light will never reach the ground. Also, the power gets hooked up to the battery, but you could also wire a switch inbetween to turn them on or off. The sub power wire also comes directly from the battery, so you could wire it to that. You still need a switch or they'll stay on all the time. Good luck. Sounds like a sweet project.
gearbox is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Amp Wiring 2k1civic coupe
DIY: Head unit install
Sound Deadening DIY
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
MTX Jackhammer! Don't they know when to draw the line?
DIY: Custom Trunk II !with access to spare tire!
*** The big I.C.E. & Electrical sticky (DIY's, links, POSTING GUIDELINES, more) ***
HID in TYC setup. With no projector conversion. Video on pg 17.
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
