Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-21-2003   #1 (permalink)
turboslug
Super Hoser
turboslug will become famous soon enough turboslug will become famous soon enough
is it possible to bridge a 4channel to 1 channel mono?
i can bridge my 4channel MTX Blue Thunder to 2 chanels but is it possible to combine those two channels in parallel to use the amp as a monoamp?
why would it not work?
turboslug is offline   Reply With Quote
Sponsored Links
Old 09-21-2003   #2 (permalink)
LudlamTheory
i boogie for the raindrops
LudlamTheory's Avatar
Send a message via AIM to LudlamTheory
it would not work because a 4 channel amp is 2 different 2 channel amplifiers in a common case... are yout rying to run 1 single sub off it?
LudlamTheory is offline   Reply With Quote
Old 09-22-2003   #3 (permalink)
turboslug
Super Hoser
in theory it does work because an amp is just basically a varying ac voltage source
when an amp is bridged, there is one positive terminal where the voltage is positive relative to ground and one terminal has a negative voltage relative to ground
on a bridged amp, the positive and negative terminals in reference to each other will then have double the voltage than if they were in reference to ground...
now if you had two of those bridge channels and had them in parallel.....
the positive voltage terminal in parallel with the other exact same parallel signal/voltage you'd have the same voltage output but double the amperage capbility...same thing with the negative one...
now the only probs i see with running amps like this is if both parallel amps were not outputting exactly the same voltage...will there be a higher current going from one of the bridged channels to the other?
another prob i see is that if the EQ isnt set exactly the same, the frequecies might be slightly off and again there might be a high current going straight from one of the parallel channels to the other?
Old 09-22-2003   #4 (permalink)
turboslug
Super Hoser
anyways....i was hoping someone could give me a quick answer but i guess i'll have to lugout the oscilloscope and figure it out myself in a lab...
Old 09-22-2003   #5 (permalink)
LudlamTheory
ok.. in theory it could and would work, and heres how youd have to set it.
first of all, youd need a multimeter and a test tone to get the exact same output voltage, secondly, youd probably want to bypass the onboard crossovers. also, lets say each separate amp was 4 ohm stable, your new bridged amp would only be 8 ohm stable.
thats assuming you can... thats why a lot of the larger class d amps claim to be "strappable" so one can do so...
Old 09-22-2003   #6 (permalink)
Logan3024
Sunkist_em2 = Fagness
Logan3024's Avatar
Logan3024 is a name known to all Logan3024 is a name known to all Logan3024 is a name known to all Logan3024 is a name known to all Logan3024 is a name known to all Logan3024 is a name known to all Logan3024 is a name known to all Logan3024 is a name known to all
Send a message via AIM to Logan3024
Re: is it possible to bridge a 4channel to 1 channel mono?
Whats the point of doing this on a 50x4 watt 4 channel amp, to get a whole 150 watts rms?
All your doing is trying to figure out a way to fry your amp. Why not just go buy your self a cheap class D amp?
:zbsflag:
Logan3024 is offline   Reply With Quote
Old 09-22-2003   #7 (permalink)
doubledeuce2k2
Ultimate Member
doubledeuce2k2's Avatar
doubledeuce2k2 is just really nice doubledeuce2k2 is just really nice doubledeuce2k2 is just really nice doubledeuce2k2 is just really nice doubledeuce2k2 is just really nice
Send a message via AIM to doubledeuce2k2
you couldn't run a left and right channel to the amp, that's for sure. but if you split one side (red or white) enough times, i'm sure it would work. i don't get the b.s. thing because you would have to have the gains matched exactly. and for most 4 channel amps under $400 8 ohm stability would exist.
to the post starter, the only way using that amp on a sub makes sense is if you bridge the channels and use it to power each voice coil independantly, on a DVC 4 ohm sub. otherwise don't bother
doubledeuce2k2 is offline   Reply With Quote
Old 09-22-2003   #8 (permalink)
turboslug
Super Hoser
finally...thanks for some answers..haha
anyways...reason why i even bothered to ask is because i got the amp for free...it was originally completely blown to smitherines
i've done all the repairs and also recalibrated the biasing on the amp
now i'm too cheap to buy a new amp right now and dont mind pushing this thing to its limits cuz it was free...
Old 09-22-2003   #9 (permalink)
turboslug
Super Hoser
anyways..right now it'll prolly be bridged for 100watt rms X2...
i'll just lug a scope out and make sure both channels are in phase and have the same amplitudes going into my DVC sub..
btw...reason i asked if the bridge channel can be hooked in parallel is because my sub was 2 ohm X 2 DVC...2ohm to a bridged channel will not work.....
anyways..i've recently just traded that sub for a 4 ohmx2 DVC...problem solved..haha
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
Sound Deadening DIY
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
Its that time again...post your systems...
MTX Jackhammer! Don't they know when to draw the line?
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
