Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-18-2003   #1 (permalink)
iLLuMiNaTi
Senior Member
iLLuMiNaTi's Avatar
iLLuMiNaTi is an unknown quantity at this point
Send a message via AIM to iLLuMiNaTi
what gauge??
Hey,
My friend currently has 4 gauge power and ground wires that power his 1000watt class D sony xplod amp. (we know, it's not really 1000watts). Now, he wants to buy a pioneer amp that gives out 150wrms at 4 ohms. He doesn't know what kind of wiring he should get. He wants to upgrade his sub amp wiring to 0 gauge and is wondering if it's possible to use the 4 gauge on his new amp. Is there any way that the wiring can be "too powerful" and/or harmful to his amp??
Thx in advance
-Axel
__________________
Proud SoundSplinter RL-p12 owner.
Two of these will own your honda:
vid of Djdilliodon's 2 SS RL-p12's sealed, powered by PG MS1000 TA
iLLuMiNaTi is offline   Reply With Quote
Sponsored Links
Old 08-18-2003   #2 (permalink)
Mr.Modify
Mr.Modify's Avatar
Mr.Modify is a name known to all Mr.Modify is a name known to all Mr.Modify is a name known to all Mr.Modify is a name known to all Mr.Modify is a name known to all Mr.Modify is a name known to all Mr.Modify is a name known to all Mr.Modify is a name known to all
Send a message via AIM to Mr.Modify Send a message via Yahoo to Mr.Modify
hmmmm i didn't know the wiring could be too powerfull..dope...if anyone knows the anwser pleas efill me in to!!!
Mr.Modify is offline   Reply With Quote
Old 08-18-2003   #3 (permalink)
LudlamTheory
i boogie for the raindrops
LudlamTheory's Avatar
Send a message via AIM to LudlamTheory
you cant overkill...
imo, 8 gauge is PLENTY for a pioneer 150 watt amp
LudlamTheory is offline   Reply With Quote
Old 08-18-2003   #4 (permalink)
IDQcivic
Diamond Member
IDQcivic's Avatar
IDQcivic should not be trusted
I say install the 0 gauge, that way if you upgrade later, you'll already have the wire ran....
IDQcivic is offline   Reply With Quote
Old 08-19-2003   #5 (permalink)
tom1178
tom1178's Avatar
tom1178 is an unknown quantity at this point
Send a message via AIM to tom1178
he can stick with the 4 guage that he is curently running and be fine. f he later replaces the two amps he's running with amps that are pulling more amps then he can go out and buy 0 guage, i'd see no point now in spending more mney on 0 guage until he buys one or more likely two even more powerful amps.
__________________
My whole existance is for your amusement and that is why I'm here with you.
tom1178 is offline   Reply With Quote
Old 08-19-2003   #6 (permalink)
WhiteRabbit
Ultimate Member
WhiteRabbit's Avatar
WhiteRabbit should not be questioned WhiteRabbit should not be questioned WhiteRabbit should not be questioned WhiteRabbit should not be questioned WhiteRabbit should not be questioned
Send a message via AIM to WhiteRabbit
toms got it, the 4 guage can handle both amplifiers no problem.
he should save his wiring money till he plans on getting something that truly needs the upgrade.
lud is righ ttoo, however, there is no such thing as overkill.....
WhiteRabbit is offline   Reply With Quote
Old 08-20-2003   #7 (permalink)
LiceLocket
Member
LiceLocket's Avatar
LiceLocket is an unknown quantity at this point
Send a message via AIM to LiceLocket
anyone know if its necessary to use any higher than a 4 gauge? i have a 100x4 amp and i'm installing the wiring to the components this friday.
LiceLocket is offline   Reply With Quote
Old 08-20-2003   #8 (permalink)
LudlamTheory
i wouldnt bother with anything higher than 4 unless youre over a kilowatt
Old 08-20-2003   #9 (permalink)
alex053
alex053's Avatar
i run 0 and 2 guage just cause thats what i have laying around. 4 and 8 are fine for 90% of installs out there.
__________________
2006 Smoke Nissan Titan LE
2002 IBP Lexus IS 300
2006 Yamaha Rhino
alex053 is offline   Reply With Quote
Old 08-20-2003   #10 (permalink)
iLLuMiNaTi
Senior Member
iLLuMiNaTi's Avatar
wait.. does that mean you can power 2 amps through one powerline..? I thought you needed some kind of splitter thing or something..?
__________________
Old 08-20-2003   #11 (permalink)
LudlamTheory
technically you could string amps up from one wire like christmas lights if you wanted...
people use those "splitter" things called distribution blocks strictly for neatness and also to drop gauge. wire can handle a certain amount of power over a certain distance, and amps usually take small wire inputs. my sub amp for example takes a 4 gauge input max, but if i were to run 17 feet of 4 gauge directly to that amp, itd have some trouble with that wire. 1600+ rms over 17 feet of 4 gauge is a bit excessive. you add another 350 watts of a/b for my component set and it gets to be too much for 4 gauge, but my amps dont accept 1/0 gauge.
Old 08-20-2003   #12 (permalink)
iLLuMiNaTi
Senior Member
iLLuMiNaTi's Avatar
How do you know how big of a wire you can use for your amp? also, does anyone have a DIY on how I can use one cable for multiple amps..?
Old 08-20-2003   #13 (permalink)
Regularjoe
Super Member
Regularjoe's Avatar
Regularjoe is on a distinguished road
Send a message via AIM to Regularjoe
You use one wire to get into the trunk and then a splitter like this one:
http://www.sounddomain.com/sku/ROCCPPD4
The power wire (4-gauge) goes to the splitter which will be in the trunk. Then from the splitter you run power wires to the amps. This splitter can take 4 gauge wire in and runs four 8 guage wires out. So this could power 4 amplifiers.
They come in all sorts of different arrangements.
Personally I bought a 4-way splitter. I power 2 different amps and then my relay off of it. Plus I have one spare still.
__________________
Pics_of_my_ride!
Regularjoe is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
