Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-15-2003   #1 (permalink)
twizzx
Super Member
twizzx's Avatar
twizzx is an unknown quantity at this point
wiring harness problem
So I was all ready to connect the two harnesses but I ran into a problem. While I was cutting the wires to expose the copper, I pulled the red wire too hard and it came out. I can put it back in but I don't know where it goes. There are 10 holes on the top row and 10 on the bottom. This harness is the one that connects to the car.
From my left to right it reads,
Top 10
(1)Blank, (2)Blank, (3)Blank, (4)Blank, (5)purple w/black stripe, (6)green w/black stripe, (7)gray w/black stripe, (8)white w/black stripe, (9)orange w/white stripe, (10)black
Bottom 10
(1)blue, (2)Blank, (3)Blank, (4)Blank, (5)purple, (6)green, (7)gray, (8)white, (9)orange, (10)yellow
So there are 7 blanks. I don't know which one it belongs in. Or does it even matter at all where the red one goes?
twizzx is offline   Reply With Quote
Sponsored Links
Old 08-15-2003   #2 (permalink)
justplainbad
Victory is Mine!
justplainbad's Avatar
justplainbad is on a distinguished road
Send a message via AIM to justplainbad
Your best bet will be to go to the vehicle wiring database, click on the link on the left of your screen under the bold word MENU, and then enter the make model and year of your car. The red wire (On an aftermarket harness) is the accesory wire, so you are looking for the RADIO SWITCH wire), note the color of the wire, and then plug the wiring harness into the stock harness. Locate the position of the RADIO SWITCH wire (Yellow/Red on an 02 Honda), and then plug in the red wire in the cooresponding pin. Basically, find the wire color you need on the stock harness, and then plug in the pass through harness, and find which pinhole the stock wire is going into.
Hope this helps
__________________
"Anything can be done if you're a liar..."
justplainbad is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
Sound Deadening DIY
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
Its that time again...post your systems...
MTX Jackhammer! Don't they know when to draw the line?
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
