Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-19-2003   #1 (permalink)
02CivicEX
Member
02CivicEX's Avatar
02CivicEX is an unknown quantity at this point
Send a message via AIM to 02CivicEX
anyone know how to bypass alpine dvd saftey
i just bought the iva d900 and dont want to hook up the two wires to the brakes, to me it is stupid that u have to do a combo of things just to get the dvd to go on, i didnt know this before i bought it, so now i am stuck. Is there some way to bypass this phase so that i just have to flip one switch or no switch at all. i know it is illegal to play this while driving , i am not stupid enough to do so because of distraction, but at those stop and go cruises (Shows) it would be nice if i could show off that i can play dvd's with the 7" screen instead of just playing my music.
Anyone Know how to bypass that saftey lock on the video that would like to share?
thanks, john
__________________
do what u like not what others like
02CivicEX is offline   Reply With Quote
Sponsored Links
Old 07-19-2003   #2 (permalink)
EnProceso
EnProceso's Avatar
EnProceso has a brilliant future EnProceso has a brilliant future EnProceso has a brilliant future EnProceso has a brilliant future EnProceso has a brilliant future EnProceso has a brilliant future EnProceso has a brilliant future EnProceso has a brilliant future EnProceso has a brilliant future EnProceso has a brilliant future EnProceso has a brilliant future
not 100% sure but i believe they have you hook up the ground to the e-brake so when the e-brake is on the ground is connected, just hook that wire up to a reg. ground and that should do it.
EnProceso is offline   Reply With Quote
Old 07-19-2003   #3 (permalink)
LudlamTheory
i boogie for the raindrops
LudlamTheory's Avatar
Send a message via AIM to LudlamTheory
first look in the manual and find if the wires require a ground or a + signal to work for the bypass. if they require a ground, connect it to the black wire behind the radio, if they require a +, connect it to the yellow wire behind the radio... easy enough
LudlamTheory is offline   Reply With Quote
Old 07-20-2003   #4 (permalink)
02CivicEX
Member
02CivicEX's Avatar
Yeah it says connect this wire to the parking brake lead, then connect this one to the foot brake lead, so i believe the wires are positive .
Old 07-20-2003   #5 (permalink)
LudlamTheory
easiest way to find out
go to the parking break lead and the regular brake lead and test to see what they are
Old 07-20-2003   #6 (permalink)
02CivicEX
Member
02CivicEX's Avatar
Problem is i dont know what the p-break lead & the foot brake lead wires are. i need a wiring diagram of our cars for me to make sure i have the right one.
Old 07-21-2003   #7 (permalink)
WhiteRabbit
Ultimate Member
WhiteRabbit's Avatar
WhiteRabbit should not be questioned WhiteRabbit should not be questioned WhiteRabbit should not be questioned WhiteRabbit should not be questioned WhiteRabbit should not be questioned
Send a message via AIM to WhiteRabbit
check out yrou dealer or neighborhoof friendly honda tech. theyve always been very friendly and willing to help me with any tech info i needed
WhiteRabbit is offline   Reply With Quote
Old 07-21-2003   #8 (permalink)
bzrollin
Senior Member
bzrollin's Avatar
bzrollin is an unknown quantity at this point
ok, alpine's tvs need to sense that you pressed the brake while you set the parking brake, you WILL NOT be able to bypass it just by hooking wires up to 12v or a ground, so to bypass it you will need two switches, a momentary switch and an on/off switch.
hook up the momentary switch to the wire that is to be hooked up to the brake wire, and then the other side of the switch to 12v+, then take the on/off switch and hook one side up to the parking brake lead on the tv, and the other side of the switch to a ground.
then all you will have to do to watch a video source is hold the momentary switch while you turn the on/off switch to on.
OR, you can get a bypass from PAC that will do this automaticly, but that part costs i think about $50.
bzrollin is offline   Reply With Quote
Old 07-23-2003   #9 (permalink)
02CivicEX
Member
02CivicEX's Avatar
would it work if i hooked up the foot brake lead then used a switch for the parking brake one side to a ground the the other to to the parking brake lead wire off of the wire harness?
do u know the exact part i need from pac to do this? is it safe?
Thanks for the help!!!
Old 07-26-2003   #10 (permalink)
02CivicEX
Member
02CivicEX's Avatar
Sweeet !!! I found one good way to do it, for anyone that has the iva d900 to bypass the video safty u do that^(above).
items needed-------->curcuit tester and a switch
Run the foot brake lead to the wire that lights up on the tester when the brake is applied, then take the switch and wire the red wire, (or positive side to the parking brake lead wire off of the wire harness for the brain unit, and the black((ground) wire to a solid ground source
that is it. in order to play dvds while your driving when u get in your car and start it hold the foot brake then flip the switch off on off on and your set!!!!!!!!!!!!!!!!!!!!!!!! ( u need to do this everytime u start the car)
but u can watch while you are driving!!!
Old 08-19-2003   #11 (permalink)
SODJAZERO
Diamond Member
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Send a message via AIM to SODJAZERO Send a message via Yahoo to SODJAZERO
cool, ill need this info one day
SODJAZERO is offline   Reply With Quote
Old 06-04-2009   #12 (permalink)
tbohar
Senior Member
tbohar's Avatar
tbohar is on a distinguished road
Smile Re: anyone know how to bypass alpine dvd saftey
Works like a charm with the IVA series Alpine. I did mine with the IVA W203 and it worked
Whoe this is an old post!
tbohar is offline   Reply With Quote
Old 06-04-2009   #13 (permalink)
WhiteRabbit
Ultimate Member
wow, I can't believe someone replied to a thread from 2003. I remember this thread too. Like a piece of history.
I imagine that there isn't one person who posted in this thread who still own a 7th generation civic.
Old 06-04-2009   #14 (permalink)
tbohar
Senior Member
tbohar's Avatar
True, but its not bad to refresh it I guess. It does work for newer models of Alpine decks
Tags
alpine , brake , bypass , d900 , diagram , driving , dvd , ground , ivad900 , parking , play , sale , video , watch , wire , wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
