Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-18-2003   #1 (permalink)
MangoEX
Just Be
MangoEX's Avatar
MangoEX should not be trusted
Send a message via AIM to MangoEX
BEST and EASIEST tool to cut sheet metal?
I tried my dremel out yesterday with that super thin disc attachment wheel @ 35,000 RPM, it cuts EASILY, but the WHEEL wears down so fast right before my eyes before i can cut a fair amount of steel (for my components installation) is there a better or easier tool out there? im like 80% done cutting on the pass. door and im so tired of changing discs every 10 secs. Thanks. To remove this ad, register today for free or log in if already registered!
MangoEX is offline   Reply With Quote
Sponsored Links
Old 07-18-2003   #2 (permalink)
LudlamTheory
i boogie for the raindrops
LudlamTheory's Avatar
Send a message via AIM to LudlamTheory
they sell fiberglass reinforced discs and tehy actually have a sheet metal bit that looks like a hardcore drill bit. walmart has a buttload of dremel attachemnts, bits, discs, everything
LudlamTheory is offline   Reply With Quote
Old 07-18-2003   #3 (permalink)
MangoEX
Just Be
MangoEX's Avatar
Not talking about that tungsten carbide bit right? I cant use that thing, kicks back too much. Got a pic or part# for that fiberglass wheel? The area where I cut is so jagged and ghetto, but looks like it will work
Old 07-18-2003   #4 (permalink)
Yukonart
Platinum Member
Yukonart's Avatar
Yukonart will become famous soon enough
Send a message via AIM to Yukonart Send a message via Yahoo to Yukonart
Jigsaw with metal blade.
__________________
http://69.73.145.197/yukonart/Sigs/STi-Sig-20050208.jpg
"Power is NOTHING without control."
Yukonart is offline   Reply With Quote
Old 07-18-2003   #5 (permalink)
MangoEX
Just Be
MangoEX's Avatar
#456 1 1/2" Cut-Off Wheel
Found it. Thanks bro! Hey another question ludlam... whats the best kind of screws to tap into the chassis for ground? I guess im going to redo my ground for my amp, i used a cheesy screw, i checked itt out again..... It doesnt need to be self tapping cause ill drilla new hol using my dremel just so the screw will thread... and you know the little metal thing at the end of the ground cable (the terminal i guess), how do you clamp that down tight on the cable? My crimper didnt do that good of a job, or i guess i wasnt strong enough, and it IS a bit loose. Grr. The right tools make a world of difference. Dont they make some sort of terminal where i can feed the wire thru, then tighten it with a hex key so it will actually bite down on the wire strands?
Old 07-18-2003   #6 (permalink)
MangoEX
Just Be
MangoEX's Avatar
Please answer all my questions if you have time
Old 07-18-2003   #7 (permalink)
Yukonart
Platinum Member
Yukonart's Avatar
If it's a piece of sheet metal you can get to both sides of with your hands, I would recommend a lock-washer and nut on a threaded screw. Then take your ground wire and crimp on a spade end to it, and put the spade under the head of the screw just before tightening the screw down. Nice thing is this can easily be taken-off or added-to.
Hope that helps a little.
__________________
Old 07-18-2003   #8 (permalink)
alex053
alex053's Avatar
any screw with a star or lock washer will work fine. be sure to sand the paint away also.
__________________
2006 Smoke Nissan Titan LE
2002 IBP Lexus IS 300
2006 Yamaha Rhino
alex053 is offline   Reply With Quote
Old 07-18-2003   #9 (permalink)
MangoEX
Just Be
MangoEX's Avatar
Thanks, Im kind of TOOL-illiterate, could you show me a pic of a screw with a lock washer or star? Is that one of those ones you can tighten by hand? Well, anyway, i dont think t his works on a one side application huh? the area im working with (the brace right under the passenger seat is obviously one sided. My friend said he could weld it to the chassis for me hehe... but i dont really want to go that route, i guess im going to go to the hardware store and look for soem kind of screw with a flat mounting surface
Old 07-18-2003   #10 (permalink)
tom1178
tom1178's Avatar
tom1178 is an unknown quantity at this point
Send a message via AIM to tom1178
The crimper i usually use works great for crimping ends together for speaker wire and crimping wires together when installing head units, but i didn't have a big enough crimper for the ground wire on my car either, i was crimping one of those ring clamp things that you were talking about, all i did instead of using a crimper was i put the wire in, and took a hammer and used the pavement outside my house and the hammer to "crimp" the clamp onto the wire, worked as good as a crimper would have i guess, the wire is on there as solid as ever.
__________________
My whole existance is for your amusement and that is why I'm here with you.
tom1178 is offline   Reply With Quote
Old 07-18-2003   #11 (permalink)
PopcornPlaya
Electric Boogaloo...
PopcornPlaya's Avatar
PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold PopcornPlaya is a splendid one to behold
nibbler will make quick work of the sheet metal... you could also try some of the rotozip bits for the dremel (not sure if they'll interchange though) but my rotozip works great witht the metal bit in there... or you could use a jigsaw or sawzall(reciprocating saw) with a metal cutting blade, as far as crimping on the connector to the wire, you can buy some larger crimp tools at home depot/lowes for around 10 bucks...
PopcornPlaya is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
Sound Deadening DIY
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
Its that time again...post your systems...
MTX Jackhammer! Don't they know when to draw the line?
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
