K24a2 into 09 SI
Rep Power: 0 K24a2 into 09 SI
Whatsup guys
I'm planning on dropping a K24a2 out of an 08 TSX into my 09 SI, had a few questions. First off from my research the K24a2 does better with a K20a2 head is this true? I've heard also that the stock bottom end does'nt do to well after 300+ hp, and I plan on turboing it eventually, what would be needed to be switched out in order to drop a turbo in there? I am aware that the oil pump needs to be switched out in order to rev it passed the stock red line. I was told that the engine should drop right in to my 09 SI, and bolt right up to the transmission minus an extra mounting bracket, is this true? I am also aware that the motor only comes with 25 degree VTC, and I need to upgrade to a 45 degree for more VTEC fun. Was wondering if anyone would suggest a better K24, or if there is anything that I missed that I should remember to do to the engine once I put it in there. Thanks!
2002civic1.7
02-10-2013 05:39 PM
2002civic1.7
02-09-2013 01:49 PM
