Honda lower control arm
Rep Power: 0 Honda lower control arm
Will a lower control arm make the back ed of my civic extremely bump and feel every tiny pothole, Could it be suspension? If indeed it is the control arm what brand do you suggest?? etc... Thank You
Rep Power: 210 Re: Honda lower control arm
No, it would be bad bushings or worn struts or springs. More than likely you need new struts or springs. Push down on that end of the car, at the most it should go down then up then settle. Any more movement than that and I would replace at least the struts, if not the springs too. Also, inspect all the bushings and replace them if cracked or worn.
Received 1,440 Likes
Rep Power: 338 Re: Honda lower control arm
2006+ civics are slightly different from your suspension - BTW, you do not have a 2006+, which is the 8th gen, which is the section you posted.
^^ The brand new '01 I had before this one did that right out of the box, I just thought it was normal it being a small car and all. Hmmm... this calls for further investigation.
GolNat
09-10-2015 08:25 PM
Dorval Andre
05-01-2015 09:37 AM
jessicakaybby
04-20-2015 12:11 PM
