suspension stability
Rep Power: 0 suspension stability
What performance modifications should I start with to give my 2008 EXL better high speed stability. I drive mostly freeway, the car seems loose in moderate crosswinds and freeway grooves.
I want to start with simple bolt-ons and not replacing springs and or struts as of yet. The car has only 45k miles btw.
Received 1,146 Likes
Rep Power: 485 Re: suspension stability
Increasing your rear sway bar size would just increase oversteer/decrease understeer. Unless, of course, I'm mistaken and a suspension guru chimes in.
The strut bar would tighten up your steering just a bit. I took mine off when I put my coilovers on because it was a bitch to get on. When I took it for a test drive with the new suspension, I immediately turned around to put it back on.
Received 1,440 Likes
Rep Power: 338 Re: suspension stability
not sure how them would affect the reaction for cross winds, never really bothered with them. have been too long since i changed the springs and did not think about it.
Both comments about over/understeer and roll are correct.
sorry but am not a suspension guru but chimed in!
Rep Power: 787 Re: suspension stability
i think he just needs better tires. most suspension mods are just gonna make the car more sensitive to steering input.
How do you clear all the hardware over top of the Driver's side strut mount on a Gen 8? The strut bar was the first mod I was going to do on my 2010 EX-L's suspension and I can't figure out how any of the bars can get clearance under all the crap mounted there.
I had planned on adding a strut bar first, then swaybars. Lowering springs are out because my car scrapes too much as it is in stock form -driveway issues.
Vince
Vince
the strut bar in the 8th gen does not seem to make much difference? they seem to be buried under the windshield frame, so not much gain to be achieved there? they seem to have a stiff enough frame in the mounting point. The ones i saw that ties to the front seems... dangerous from a potential frontal crash.
