Avoid Sylvania XtraVision in your DRL/High Beam bulbs
Old 02-18-2014
CraigW's Avatar
My factory bulbs lasted 4 years/ 75k miles and the glass stayed clear.... these have a dark rusty color buildup inside the glass after 2 MONTHS/1500miles.
And if you order bulbs through Honda you can only get Sylvania, and not Stanley bulbs.
They suggested running the high beams....how the hell are you supposed to accomplish that feat ?? And why did original bulbs remain clear for 4 years ??
Old 02-18-2014
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: Avoid Sylvania XtraVision in your DRL/High Beam bulbs
I have been running Philips 9003 X-treme Power Headlight Bulb since Jan 2011 with no issues. Great bulbs. Brighter than the Sylvania's.
Only $33 back then. Looks like $40 now.
Old 02-18-2014
Were the originals Stanley?
Were your new bulbs sealed, never touched by (human?) fingers?
I was gonna say Osram was always top notch back when I dealt with Euro.....but it looks like they own Sylvania (US market).
http://en.wikipedia.org/wiki/Osram_Sylvania
Old 02-19-2014
CraigW's Avatar
Are you running them as DRL bulbs though ?? These bulbs are very similar to original but the DRL is making them brown very quickly.
I cannot say, do remember they were still clear inside, the glass (on sides) was deformed/bubbled above the filament somewhat and may have been what killed one. I have always been impressed with the bulbs that Honda uses. I'm running my 2010 rear bulbs to failure just to see how long they make it.
Yes, by the book with top notch tech
Osram Sylvania - Wikipedia, the free encyclopedia
Yes, nothing stays the same these days.
Here is a quote from Sylvania:
Browning occurs when the lamps are powered for prolonged periods of time at reduced voltages ~ as in the case of a DRL. We recommend that these lamps be operated at a minimum of 6.4 volts for the halogen regenerative cycle to be effective. If the bulb isn't supplied sufficient voltage, the bromine inside the lamp will deposit on the bulb wall and cause a brown stain. Eventually the brown stain will heat up during the full lamp operation (high beam use) and may cause the glass to bubble and in some cases shatter. In the case of extreme browning, the bulbs should be replaced with new bulbs which should be powered in full high beam mode on a more regular basis to prevent future bromine build up.
Regards,
Customer Service"
Old 02-19-2014
TiggerDX's Avatar
No, I am running them as regular headlights. Sounds like the ones you are using are not effective at lower voltages.
Sorry.
Old 02-19-2014
Call customer assistance!
Old 02-20-2014
CraigW's Avatar
Sorry.
They are awesome bulbs, up to the point they browned up. Very close to oem. Does seem strange original were fine after 4 years of cooking half brightness.
I did, they sent me the info on browning I posted.... and the bulbs from Honda are now from Sylvania.
ezone, can you check with your parts dept about any remaining
33115-S84-A11 bulbs that they may have left. They are the Stanley bulbs. I would appreciate it. Need to find something that will work.
Old 02-20-2014
That # supersedes to A01, the Sylvania 9005 bulb. No A11 on our shelves. Sorry.
Old 02-20-2014
CraigW's Avatar
Called our dealer, and the one 45 miles away, no go on the A11 Stanley bulbs.
Not even going to try another Sylvania unit....even from Honda.
Thanks for checking.
Old 02-22-2014
Just got to look....Mine have a brownish color on them.
Old 02-22-2014
Eh, Houston?
Old 02-23-2014
CraigW's Avatar
Certainly NOT the crystal clear quartz glass they started out with.
Old 02-26-2014
CraigW's Avatar
The xtravisions have been returned back to advance, and new plain jane Wagner BP9005s are in place.
Let the long term testing begin.
Old 12-03-2014
CraigW's Avatar
Update: Wagner BP9005s have gotten extremely blackened inside glass and will need replacement very soon. Stayed fine for quite a while, now look terrible.
The search continues.....
Old 12-04-2014
That was fast....
Old 12-04-2014
CraigW's Avatar
That was fast....
I'd say, they were great for a while, had not checked them lately but was walking toward car with drl on and they looked strange.
Now, not sure what to buy.
2-25-14 -- 12-3-14 13k miles.
Old 12-04-2014
"Honda - tried, true & tested...!"
brags's Avatar
brags is an unknown quantity at this point
thanks for the heads up...
but why not just use the O.E.M from Honda..?
Old 12-04-2014
CraigW's Avatar
^^^ Because Honda switched from Stanley as the supplier to Sylvania. I tried to find some leftover Stanley bulbs with no luck
The Sylvania Xtra-visions were in a very short time before getting brown buildup.
Original bulbs lasted over 4 years.
Have a set of Philips on order and they list them as being DRL (not that that makes any difference likely)
Edit: Put the Philips VisionPlus bulbs in place today. Let the long term test begin.
cferry7
10-18-2015 06:32 PM
General DIY
09-25-2015 08:02 PM
Mc7602
09-17-2015 02:01 PM
blward6
09-16-2015 05:32 PM
MamaBear2015
09-04-2015 09:04 PM
Quick Reply: Avoid Sylvania XtraVision in your DRL/High Beam bulbs
